Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
How do you fix a loose door handle on model 105.55620400
Handle is loose and needs to be tighten
SOURCE: door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Posted on Feb 13, 2009
SOURCE: door handle loose on 10656542400 kenmore
I got it!!! Okay, the most common problem is the fridge handle at the top is coming loose from the mere fact that the fridge gets opened more than the freezer and people grasp the handle higher than lower. Okay, open the door until you can look at the handle sideways where it attaches to the door. What is happening is the screw that slides into the bracket is simply backing out. Try lifting the handle straight up, only about an inch plus. The bracket is the same on the bottom of the handle as the top. If you cannot get the handle to lift, get a very slim standard screwdriver and push the retaining clip down (away from the handle) so the screw head can get passed it. You may have to push the retaining clip pretty good to get it down. When you have it pushed away from the screw head, lift the handle and it should pop up. Take the handle away from the door and tighten the screw. The screw head takes a torques screw head (star shaped, like a philips but different) Tighten it until it stops the just realign the TWO screw heads into the upper and lower bracket and slide the handle down gently. No problem! You can do it!
Posted on Mar 31, 2009
  • 531 Answers
SOURCE: Freezer handle is loosed and needs to be tighened
with not driver
Posted on Apr 07, 2009
SOURCE: Bottom Freezer door handle
I had the same problem. It took me an hour to figure out that the bottom freezer handles clips onto the door using butterfly clips. To tighten the clips you have to remove the handle by sliding it to the right (or left??) It snaps right out with a quick **** exposing the clips underneath. A quick tightening of the clips and the handle snaps back in.
Posted on Sep 07, 2009
BIKER T
  • 909 Answers
SOURCE: My Kenmore Coldspot side by side door handle is
Normally on the handle is a cosmetic cover. Use a small flat screwdriver and pry it loose. underneath are the 2 screws you are looking for.
Posted on Oct 23, 2009
Handles loose on Frigidaire fridge doors
Jeff, If you can not see any visible screws, look for molded removable trim caps on the handle, remove and tighten screws. If no trim caps then your handle is probably mounted to fridge with screws in slotted slide, which get slid off by pulling straight up on handle, normally takes a lot of force to slide up and out. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix loose Refrigerator Handle
How To Fix Your GE Refrigerator Handle by removing the cap and tightening...
Refrigerator Door Handle How To Replace
Refrigerator Repair Replacing the Door Handle Frigidaire Part 218428101
Jul 10, 2016 | Frigidaire Refrigerators
How does someone tighten the handle it is very loose
go to www.youtube.com
refrigerator door handles out loose
see if anyone has idea on how to fix it
most of the time is the way people word there questions or answers to get the right help
manufactures name, make or model #, handle are loose
how to fix
www.howto.com/manufactures_name/model#/service_manual
/ door_handle_diagrams
www.wikipedia.org/manuf./model#/doorhandlediagram
Mar 25, 2015 | Refrigerators
How do I tighten door handle on whirlpool fridge how do I get to the screws model gb2fhdwq02
Hello Tim;
My name is Peter. I am a retired field service refrigeration technician.
You have one of two door attachments:
1.) There are two 3/32" K set screws (Allen Head) at the top and bottom of each handle. Back off these screws until the handle comes off. The is a stud with a screw - tighten and reattach the handle.
2.) There are two brackets mounted to each refrigerator door. One at the top and one at the bottom. At the top of each bracket is a oversize hole. On the back of the handle there are two screws. These screws fit into the oversize hole. Then you push down into a slot to secure the handle. To remove the handle you push up on the handle until the door handle screws are into the oversize holes.
The screws on the door bracket often become loose. Tighten these screws. Sometimes the mounting screws on the door handle become loose as well.
Be careful, if you tighten everything up too much you will not be able to remount the door handle. Adjust the screws for a tight fix
Oct 31, 2014 | Refrigerators
Bosch refrigerator door handle is loose
there is only one screw on the handles from what i found out from fixing my loose handle. the bottom of the door handle has one screw. once you loosen that one up then you lift it and it comes out at the top enough to slide the handle out and tighten it.
Aug 03, 2014 | Bosch Evolution 800 B20CS80SNS Stainless...
The handle on my refrigerator door (Admiral side by side model LSD2615HEZ) is loose. How do you tighten the handle?
There is a plastic card that came with the refrigerator. Pull the handle towards you and slide the card between the door and handle on the top side of the lower handle. Slide the card until it stops, I believe its 11/16". Next slide the handle upward to release it. It may take some force to release the handle. Once its removed, you will see a bracket on the handle. In my case, the screws were loose. Tighten the screws and replace the handle and its fixed. To reinstall the handle, line up the handle with the brackets on the door. Slide down until you here a click that indicates that the handle is installed properly.
Dec 30, 2009 | Refrigerators
The driver's side outside door handle is loose, toyota celica '95
I assume that the entire handle unit is loose in the body work of the door.
The interior door trim will need to be removed to access the inside of the door to fix the loose handle.
Do not attempt his yourself unless you have some experience in this area.
Take the vehicle to the nearest reputable auto body repair shop and they can easily fix it for you. There could be a breakage on the retaining system on the handle or the retainers may just need tightening.
Typically door handles which have not been subject to damage or abuse will not usually loosen like this. It's possible the door was damaged and the panel repaired and repainted at some stage. If so the door handle may have been removed and refitted in a sloppy manner.
Dec 03, 2009 | 1997 Toyota Camry
On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
Sep 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
How to fix loose door handle on GE model DSF25KGTB BG side by sid
If the screws aren't obvious, they will be locater under a pop out plug on under a nameplate on the handle.
Feb 20, 2009 | GE GSS20IEP Side by Side Refrigerator
Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Jul 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Handle loose on Refrigerator
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
13 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
