Question about Garden
Craftsman 675 series Briggs & Stratton power propelled model 917.370431 I think fuel or oil jelled over winter how can I resolve problem!
  • 93 Answers
SOURCE: BRIGGS/STRATION 675 SERIES, 190CC SELF PROPELLED
Rust on the Flywheel and Magneto wire brush off., Pluged Fuel Filter or Bad Gas.
Posted on Sep 14, 2009
  • 468 Answers
SOURCE: Pull cord broken. After removing red hood and
You don't need to remove the rivets. There should be two metal tabs that bend over the nylon retractor, or it'll have a screw in the middle of the retractor pulley inside the cover. you bend those up a little, or remove the screw, remove the retractor, be careful, because that spring can be fun if it gets away from you, take the old rope out, put the retractor back in place, wind it back as far as you can, feed the rope in, tie the knot, and let it draw the rope in. Put everything back like you found it, and your pull rope if fixed.
Posted on Mar 12, 2010
  • 48 Answers
SOURCE: what kind of oil do I use in my 675 series engine
4 stroke synthetic is most likely what you'd want to run if it's a new unit to yourself. Otherwise any 4 stroke motor oil is fine, you can find it at any retailer that sells small engine machinery.
Posted on Apr 21, 2010
rycgl
  • 1545 Answers
SOURCE: where is the carburetor on
The carburetor would be located BEHIND the air filter housing and air inlet tube. The air filter housing should have a removable (by screw or clip) cover.
Posted on Apr 13, 2011
  • 1383 Answers
SOURCE: I have a Troy Bilt
Best oil for small engine for most moderate climates is 30wt non-detergent. The pump can use mineral oil (air compressor oil ) sold at most auto stores and lumber outlets.
Posted on Jul 02, 2011
Where do you spray carburetor cleaner in 675 series Briggs & stratton engine
Remove the air cleaner cover and the air filter then spray into the filter box.
Jul 14, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
What kind of oil goes in my craftsman 625 model 944.367600
Tecumseh engines usually recommend SAE 30 oil. Briggs engines allow 5W 30 or 10W 30.
Aug 01, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Briggs and stratton 15.5 horse power over head valve
could be to much oil in engine are bad rings in engine or bad valve seals one of those three i would go with bad valve seals
May 14, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Briggs & Straten 5.5 oil spraying out the muffler
Check the compression, probably you need need a valve job
Mar 20, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman Briggs and Stratton 675 series Mower fuse location
Is battery powered, did you try calling sears tech center for further info ?
i have found them to be very helpfull with mower problems.
Sep 12, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman 675 series wont start
can you pull the rope and it doesn't start or is it stuck like the engine is locked up?check for spark also how old is the fuel gas is only good 30days from the pump for small engines
Jun 11, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Lawn mower 675 series 190 cc Briggs Stratton 22
did this happen after hitting a rock?and you sheeredthe flywheel key is the gas older than 30 days?drain and refill if still no good clean the carb
May 03, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
The front drive self propelled wheels stick and squeal
why is the back wheels of my briggs stratton wont stop turning
Aug 29, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
I have a Briggs & Stratton 675 series and accidentally put 2-cycle oil in. Realized this as soon as I did it but now I need to drain it and the instructions indicated to warm mower up for 10 minutes...
Yes, u can drain it without warming it up,But i would drian the oil refill it with new oil run it for a minute shut it off drain the oil again so u will get any residue out of the eng......
Apr 13, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Where is the carburetor on the Craftsman 675 Series 190cc 22" cut self-propelled lawn mower?
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
