Question about Gateway ML6721 Notebook
Gateway Notebook ML6721 going back and forth between battery & AC
I am having a power problem with this Gateway notebook. It's my fiance's. The problen is the the laptop wasn't alwasys charging or moved back and forth between the 2. I replaced the power adapter board twice. the problem was resolved for a while but the issue keeps coming back. Is there a know issue that maybe the powercard and the motherboard aren't working right together?
  • dsczepanski Jun 24, 2009
    I've replace the power card twice and the cables the connect it to the motherboard. Any ideas?
My gateway laptop ml6721 doesn´t working very well, the lcd screen doesn´t turn on, only I can see something in bad way, besides lcd is almost dark.
Posted on Jan 14, 2010
    Sergeant:
    Champion:
  • 233 Answers
The issue could be even due to the battery of your notebook.
I recommend you to try the steps in the below link once:
http://notebook-solutions.blogspot.com/2009/05/battery-does-not-charge-or-will-not.html
Posted on Jun 23, 2009
    Sergeant:
  • 199 Answers
The socket where the cord plugs into the back of the laptop gets wattered out and does not make a good connection when it gets this way. I suggest that not move it so much it kinda defeats the purpose of a laptop. though
How can remove the battery from gateway cx 2618
  1. Close the LCD panel.
  2. If your notebook is on and connected to AC power, or has a charged multi-bay battery installed, go to Step 4. If your notebook is on, is not plugged into an AC outlet, or does not have a charged multi-bay battery installed, save your work, and then shut down Windows® and turn off the computer.
  3. Turn your notebook over so that the bottom is facing up.
  4. If the notebook is equipped with a battery lock, slide it to the unlocked position.
  5. Slide the battery release latch, and then slide the battery out of the bay.
  6. Slide the new battery into the bay until it snaps into place.
  7. If the notebook is equipped with a battery lock, slide the battery lock to the locked position.
  8. Turn the notebook over.
  9. Reconnect the optional port replicator.
  10. Open the LCD panel and press the power button.
Mar 01, 2011 | Gateway CX2618 Notebook
Wondering if I need a new fan - it will only power on for about 5-10 seconds.
Hi. This symptom is more than just replacing the fan. You have to have the laptop checked for motherboard issues at your local computer service center. Good luck!
Feb 15, 2011 | Gateway ML6721 Notebook
Hi, I have a 1.5 yr old gateway NV52 laptop that has stayed in sleep mode for two days...I've tried turning it off and cutting back on but it is still in sleep mode...please help
Hi aiomason.
Remove the AC cord and the battery from the notebook. Re-attach battery and AC cord and power up the notebook. This will clear the Ram memory and force the operating system to "Cold Boot", in other words start the operating system loading up from the beginning instead of resuming from Ram the last time it was active. This proceedure should restore your Gateway Notebook to normal operation. Post back your results and good luck.
Jan 24, 2011 | Gateway 450ROG Notebook
Gateway laptop mx6437 turns on but won't boot
It migt be resolved by a power drain. Disconnect the AC adapter, takeout the battery, and press the power button for 30 secs. Put everything back again and try to turn it on.
If your Noterbook is still not turning on, then you might need a phillips screwdriver, or if its in warranty you might want to take it to Gateway technicians, as opening the notebook by urself might void the warranty.
** Before trying the steps below, disconnect the AC adapter and take out the battery.
Turn your notebook upside down, and look for bays, look for screws which has a rectangular comb like structure next to it, unscrew it and you will find RAM chips in there take it out and put it back in. Do this for all the chips you have in the notebook.
Put everything back again and your Notebook might be up and running, else there might be some hardware issues and you need to go to gateway or some local tech.
Regards,
Shrey
Jul 14, 2010 | Gateway MX6437 Notebook
How to reformat my gateway ML6721 Notebook without the recovery disk
Read this link, it'll help you quite a bit! If you cannot get connected, just turn your pc on and keep pressing F10 until the system recovery option appears....
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07145
Otherwise You must boot either on/from USB DVD and using a third party boot disk, say UBCD, and use the "Tools" on that DVD or USB to format and do as you want.
Feb 16, 2010 | Gateway ML6721 Notebook
Computer switching between battery & AC power.
Hi friend,
You can release the battery then use the ac adapter for run the computer..if your computer is runing then you need to change the battery...
Jan 06, 2010 | Dell Inspiron 9300 PC Notebook
Battery charger not working. Power adapter checks out ok. Laptop operates on battery only. 7325gz.
if it is not charging the battery will go dead.soo recharge it if it doesnt work then it could possibly be your charger.but alot of times the soldier on the input plug becomes loosened and doesnt get a connection. how did u check the chager
Oct 10, 2009 | Gateway 7325GZ Notebook
Batter AC constant switch back nd forth
several possible causes -- bad power supply (AC adapter, bad battery, bad connection to AC adapter, bad connection to battery - or both.
May 26, 2009 | Acer Aspire 5040-3810 Notebook
Gateway ML6721 Notebook Logo
208 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
