Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Sandisk cruzer came with no instructions--I have a mac laptop
I have never used a memory device before. I put it into the port and went to Finder/applications and found the Cruzer listed under idisk. So I clicked on it and window thumbnails came up for several different things, but when I clicked on them they either did nothing or came up with some kind of computer speak language no one could read.
On one of the windows it asked me for a password for something I have never heard of before. It did have my email address listed first. Is this necessary to open the device and save?? I have no idea what the password would be. I tried my mac password and that did not work.
Any help would be greatly appreciated!
    Scholar:
  • 109 Answers
It should just plug and play. Try finding it under the usb devices list.
Posted on Jun 23, 2009
New SanDisk 16GB Cruzer not being recognized by computer
Check ur usb port with other devices.It they were not working properly,
ur usb port is damaged,then put ur device to another usb port.if is not working properly then,ur device is damaged,u can do nothing.
Jun 16, 2012 | SanDisk Cruzer Sdcz36-016g-b35 16 Gb Flash...
I need instructions how put my files on sandisk cruzer 8GB
click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope this helps you
Jan 10, 2012 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I have a sandisk 2gb cruzer micro usb flash drive but it is not working from last some days what cani do , can i replace it from nearest sandisk centre.
You might be able to if it is under warranty, otherwise no.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
Nov 24, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
PC is not detecting my Cruzer micro pendrive but
I have experienced this type of problem before. But what I did was to install an Avira Anti-virus on a system using windows xp and eventually it did open.
So you can try it as well or insert your flash into any another system that had a strong anti-virus which can enable you scan/format the drive.
Best of Luck
Nov 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cruzer micro 4gb will not format. Also, PC will not reveal contents.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My computer keeps saying it cant find my 4GB
Does the device work in *ANY* USB port on your computer?
Do other USB devices (mouse, keyboard, printer) work in the USB port that you are trying to use?
Does the device work in any *OTHER* computer (laptop/desktop) ?
Sep 16, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk cruzer 2gb flash drive
Reset the whole memory stick via the PC should jog the memory and make it work.
Jul 07, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
How to use flash drive
Cruzer Micro is an USB external memory where you can store files.
It is automatically detected and installed on all Windows OS from Windows 2000 onward, same on Mac OS and recent Linux versions.
All you have to do is plugging the device into USB.
After the flash drive had been automatically installed , it will be displayed under Computer as an external disk.
You can copy and transfer files using Cut, Copy and Paste functions, or Send to function in windows, or the file manager, depending on the OS used.
In Windows, before unplugging the memory from USB , it is better to turn off the computer or use the 'safely remove USB' function located near to the clock, on the lower right hand corner.
Read also the documents below:
Introducing the Cruzer Micro
Find Answers || BeCompliant Corporation
How to Use Sandisk Cruzer Flash Drive
May 15, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Can't open my sandisk cruzer 16gb
Dont worry about being prompted, that is an OS option and you may of turned off by accident. When you insert the flash drive into your USB port, does th elight on the drive ligh up? If not your flash drive may of gone bad.
If it does light up, click on "My Computer" and see if it shows up there.
Apr 03, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
104 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
