Question about Fuji FinePix J10 Digital Camera
L55 battery chamber will not open - Fuji FinePix J10 Digital Camera
Where is the battery on a l55-a5284
I take it you mean the CMOS/BIOS battery. If you are trying to remove a power on password it won't work. it is only used to store date and time + info on HDD type and the boot method.
If the battery is flat unlikely on a recent laptop you will need to remove the mobo and the battery will either be a 2032 type or soldered on with 2 little tabs.
Oct 17, 2014 | Toshiba Satellite Computers & Internet
How do i know if battery is fully charged
Every new camera needs at-least 10 hours to get fully charged. you can count that way may be.. hence there may not be any proper notifications for fully charged battery...
Sep 16, 2012 | Fujifilm Finepix L55 12 Mp Digital Camera...
Fujifinepix L55
You may download a copy of the manual here.
Jul 24, 2012 | Cameras
Manual for fuji fine pix l55 digital camera
you can find it here
http://www.fujifilm.eu/uk/products/digital-cameras/easy-to-use/model/finepix-l55-1/overview/
cheers
Jan 03, 2012 | Cameras
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Battery Exhausted
You have to replace the batteries.
Here is a link that leads you to download the manual in english language for free. When you open the manual, you would see instructions on how to replace the batteries and the type of batteries which are compatible with your device.
Also, if you do not want to go to the manual, here is a step by step instruction on how the battery should be replaced.
1. Switch off your camera and open the battery/memory card chamber.(ensure that the power light and monitor have gone off before opening the chamber).
2. After opening the chamber, slide the orange battery latch upward and remove the battery using your hand.
3. Use the new battery to push or slide the orange latch upward and make sure that the positive and negative terminals of the battery are on the left and right side respectively(doing otherwise would damage your camera)
4. After pushing the battery in completely, the orange latch would lock into place and then you can close the battery/memory card chamber.
You should charge the new battery for a couple of hours before turning it on.
The device uses a rechargeable Li-ion battery EN-EL10.
If you need links on where you can purchase the batteries, you can comment here and i will send you some links.
Hope this solution was helpful? Please comment for more information. Thank you for using fixya.
Jan 16, 2011 | Nikon Coolpix S3000 Digital Camera
Fuji FinePix J10 Digital Camera Logo
19 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
