Question about Bionaire BAP1300 Air Purifier
Why won't won't turn on
Won't turn on
Might be a fuse BUT it is enclosed in the unit. You would have to take it apart to see. IT could also be other parts in the power supply that have failed, With that in mind, if you do take it apart, take pictures so that you can put it back together.
Aug 27, 2012 | Sharper Image Ionic Breeze 3.0 Air...
Alpine Air XL-15 Air Purifier - never taken out of box - won't turn on whatsoever. Plate is accurately placed and the rear filter is properly fitted.
Is the fuse in properly? Try popping it out and put it back in, also check it when it is out..just to be redundant since you did it already. push on the bottom of the filter the switch pushes in . I at pushed down my first time.
Jul 06, 2012 | Alpine Air XL-15 Air Purifier
Brand new fresh out-of-box ecoquest purifier won't turn on at all.
Well you need to promptly contact the seller and inform them then ship it back and ask for a replacement or money back, this is all one can really do, as to tamper with it would void any warranty, it should work out of the box, first time.
Also try "other" power points, actually make sure it isn't working?
Oct 12, 2011 | Ecoquest Fresh Air Air Purifier
My oreck air purifier xl won't turn on
With the Air 8 Models there is a number of issues from the motor to the power supply to the circuit boards. With these old units it is hard to find parts for them. as oreck no longer manufactures them. but if the parts were availible i would estimate around 100 to fix your power issue
Sep 15, 2011 | Oreck XL Professional Air Purifier
Change filter light won't go off
The Change Filter indicator light is controlled by a timer, rather than detecting the condition of the filter. After changing the filter, hold down the timer and speed buttons for about 5 seconds. This turns off the indicator light and resets the timer.
Jul 22, 2011 | Vornado AQS35 Air Purifier
My Fresh Air Eqo Quest shut off yesterday and I can't get it to go back on. I have hit the reset button, I unplugged and replugged, I even cleaned everything. It won't turn back on. Is there a...
There is a fuse in where the AC cord plugs into the purifier. Remove the back cover, and you should be able to remove the fuse by prying the fuse cover off with at straight screwdriver. It takes a 1.6 amp fuse for 120Volts
Jun 06, 2011 | Ecoquest Fresh Air Air Purifier
Bionaire BAP1300 Air Purifier Logo
37 people viewed this question
Top Bionaire Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Tim Whalen
Are you a Bionaire Air Purifier Expert? Answer questions, earn points and help others
