Question about Revo Home Security
Revo r16dvr3 password - Revo Home Security
I have a 16 channel Revo DVR and I need to reset the password so I can get to the set up page. My alarm will not stop
Go here http://www.revoamerica.com/Support/tabid/189/Default.aspx because it's a password on a security system you will need proof of ownership.
You will have to provide them with the problem and you will also find a toll free tech support number.
Jul 23, 2011 | Cameras
EVERY TIME I SWITCH THE DADIO ON, I HAVE TO ENTER MY WIRELESS PASSWORD. SURELY THERE SHOULD BE A WAY OF JUST DOING THIS ONCE?
The unit should remember your wireless password, you do only have to enter it once.from the manual
Pico will remember the security key or
password, you will not be required to enter
it again, even after Pico has been used on
another network in a different location.
You can check your settings in System setup, internet setup. If It is not storing the key I suggest you contact revo support here
Please vote and give a testimonial if you believe my answer was helpful. Thank you.
Feb 25, 2011 | Revo PICO WIFI WIRELESS NETWORKED PORTABLE...
HOW I CAN UNINSTALL DEEP FREEZR FROM MY PC?
- you should know the default password for deep freeze -remove password, reboot pc, uninstall it using revo uninstaller and reboot pc again it should work...
cheers
Feb 23, 2011 | Computers & Internet
I want to uninstall mcAfee family protection from my pc but it is asking for a password and i dont know the password......it is asking for a code
use REVO uninstaller pro software->install it->click on Revo uninpro icon->see on its tool bar"FORCED UNINSTAL" ->select path or program 's exact name->click NEXT follow indication given by software..I HOPE YOUR PROBLEM WILL BE SOLVE..
Oct 23, 2010 | Computers & Internet
I have cyberdefender registry cleaner on my pc. How do I get it off? It won't let me delete it.
Go to www.filehippo.com download a program called "Revo Uninstaller" run the installer. All of your installed programs show up in the main window, double click on the program you want to delete. It will ask you if you're sure, Choose the advanced button and click next. Revo will initiate the programs uninstaller, if the uninstaller fails, that is ok because Revo will then take over. No matter what, do not reboot the machine until Revo is done. Once the programs uninstaller is finished, Revo will then search for any left over files and registry settings, if will be show up to two additional screens with files. Select all and delete all that is shown, when Revo is finished, you can now reboot the machine and the program will be gone.
Jul 17, 2010 | Dell Dimension 2400 PC Desktop
Revo iBlik Wifi, LED Display Dim
Not a solution, but I have the same problem with my unit.
In addition it has started (sometimes) to continue any adjustment of the volume to the extreme end: If I try to lower the volume a bit, it will turn it completely down, and likewise if I try to adjust it up a bit, it will continue to max.
Apparently Revo does not offer any support other than sending it for service for
Apr 11, 2010 | Audio Players & Recorders
Can't get Lavasoft Ad Aware to load. Just started doing that. I uninstall/re installed. Same result.
Download revo uninstaller from below link.
Click here
Download revo from above link and install it in computer then ope revo and select your software then remove all registry kets when revo ask for delete.
Your registry keys need to remove from computer revo can remove your software reg key.
Then install software then it will work fine.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 03, 2010 | Computers & Internet
My acer aspire revo is asking me to install OS
Is it a new computer?
It has no operating system.
You need to buy a disk drive for it, preferably a dvd drive, which you will use to install the operating system.
Or you can attach an external drive to the usb and install the operating system.
Dec 26, 2009 | Acer Computers & Internet
Revo problems
try checking the auxillary fans if its working, replace it if its not. hope this helps
Jul 03, 2009 | Traxxas Rc Revo Nitro Monster Truck
Home Security Logo
81 people viewed this question
Top Revo Home Security Experts
Lawrence Oravetz
Are you a Revo Home Security Expert? Answer questions, earn points and help others
