NO HOT WATER MAYTAG WASHER Model # LAT9706AAE
Top Load Maytag Washer Model # LAT9706AAE - no hot water coming into machine, only cold. How to fix?
    President:
  • 744 Answers
Replace the dual inlet valve located in the rear of the machine. have included a link to help you...you can also purchase the part from the same link. http://www.partselect.com/repair.aspx?appliance=washer&part=replace-water-valve
Posted on Jun 23, 2009
No cold water to my Maytag Top loading washer
Pull the washer out from the wall and disconnect the water lines from the washer. Check to see if a build-up of minerals is clogging the screen on the cold water line where it enters the washing machine.
May 14, 2009 | Maytag PAV2300 Top Load Washer
Hot water will not work on my washer
call the maytag repair people. sounds like the water solinoid valve is bad.
Mar 18, 2009 | Maytag SAV2655A Top Load Washer
Maytag Legacy Series Top Load Washer model SAV515DAWW When filling, the cold water just trickles in and takes a long, long time to fill. When I unscrew the hose from the washer and turn the water on it...
From what you have said, you may have a bad solenoid in your water fill valve. it's the rubber piece under the debris screen. if you can get that out and replace it, you'll be golden.
Feb 22, 2009 | Maytag Legacy Series Top Load Washer
Cold water inlet on maytag top load washer not working
switch the hoses fill hoses and if no hot enters you have a defective inlet vavle,,replace...onthejob
Jan 13, 2009 | Maytag PAV2300 Top Load Washer
Warm water temp Maytag PAV1000aww washer
Perhaps you need to simply open the hot and cold water faucets all the way.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 05, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
No hot water for a Maytag topload washer
Turn the water off and disconnect the hot wat hose from the spigot and the machine. There should be a screen filter in one end. Check to see if the screen is clogged. If it is then replace it. If not then replace the water valve
Jan 10, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
122 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
