Question about Troy Bilt Tb70ss Gas Trimmer
Troybilt tb70ss wont stay running
Choke
2 Suggested Answers
  • 4 Answers
SOURCE: can i buy a carb cleaning kit at lowes, h depot or
you can buy on any auto parts carburator cleaner. And make sure you have a clean filter inside the fuel tank use a little hanguer or any kind of wire for catch the filter be careful came loose easy some times. Cleaned with carburator cleaner and let dry or use air. another think is could be yor carburator is dirty inside in that case you need to remove the cover and remove the 2 screws. Mark your lines top and bottom them removed, now remove carefully the carburator be careful with the gasket remove the 4 Little screws and remove carefully the black Gasket spray carburator cleaner inside the holes and line tubes. Second remove the 1 Big screw on the other side of the carburator be carefull with the gasket spray carburator cleaner and do the step for installed
Posted on Apr 24, 2010
The string on my Troybilt tb70ss just keeps coming out of the spool when I try to weedeat. I am pretty sure I have followed the directions. What is the problem?
there should be a small hole to put string in on center of spool.
you might be winding the line the wrong way around try winding line in other direction.
Jul 16, 2011 | Troy Bilt Tb70ss Gas Trimmer
How to get the fuel tank off the troy built Tb70ss gas trimmer
Go here and you will see the parts breakdown and diagram for this model...to give you an idea on the parts you will be working on:
http://www.ereplacementparts.com/troybilt-tb70ss-41adt70c711-gas-trimmer-parts-c-26780_27267_27463.html
Aug 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
The spool came unscrewed from the shaft - we can't
It's probably a left-hand thread, turn it counter-clockwise to tighten.
May 01, 2010 | Troy Bilt Tb70ss Gas Trimmer
It wont run without chokeing
one of the cause for not run right is dirty fuel filter or your carburator need to be clean in that case remove carburator and cleaned inside with carburator cleaner and try again
Apr 22, 2010 | Troy Bilt Tb70ss Gas Trimmer
Can i buy a carb cleaning kit at lowes, h depot or ace. i have a troybilt tb70ss, and am having some of the same problems, but my trimmer wont run at full speed. have to run the choke on mediun, instead of...
Apr 18, 2010 | Troy Bilt Tb70ss Gas Trimmer
Describe your troybilt tb70ss pull string Problem.
Do you have mfg instructions? Can be very tricky without following instructions
Sep 29, 2009 | Troy Bilt Tb70ss Gas Trimmer
Wont start was working two days ago
look for broken or crackd fuel lines maybe sucking air not gas
Sep 09, 2009 | Garden
Hi, I have a TB70ss trimmer and have to replace
the clutch it's self or the clutch cover if its the clutch its self take a pair of needle nose pliers & pull springs off then take a pipe wrench wrap something around it that wont alow it to tear up the crankshaft then take a wrench around the clutch nut & loosen let me know if i can further help
Jul 06, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Weedeater starsts and ildes won't run or accelerate
Make sure your gas supply is fresh...not from last year...
Secondly, clean and service the air filter element... you may need to reoil it before installation...check your manual.
Disconnect the fuel line and drain it and what little is in the carb...push on the prime bulb if it's got one...
Then with a clean air filter and fresh gas... give it a start and after start, disengage the choke..
Let me know how you do..
K
May 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt Tb70ss Gas Trimmer Logo
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
