Question about Konica Minolta bizhub C250 All-In-One Laser Printer
What is the konica minolta black imaging unit ?
  • Konica Minolta Master
  • 6,161 Answers
Its the image unit below the black toner lower right. the image units go from left to right yellow magenta cyan and black.
Posted on Dec 29, 2015
  • 12 Answers
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
Posted on Apr 06, 2009
  • 5 Answers
SOURCE: Konica Minolta C353 has a C4551 error, how do I fix it?
try replacing the imaging unit with a new one not a reset imaging unit
Posted on Sep 02, 2009
  • 13 Answers
SOURCE: Reset Chip on Konica Minolta 8031 Imaging Unit
I can provide you with a programmer to reset the chip. They are only about $500-$700. Still interested?
Posted on Sep 13, 2009
  • 44 Answers
SOURCE: Konica Minolta dirty copies
If your dropping toner your losing bias on your Image Unit. You will probably need a new unit.
Posted on Dec 14, 2009
SOURCE: The toner and imaging unit were replaced on a
Pull out the blue knob on the imaging unit a few times and replace. This will get rid of the black line across the print
Posted on Mar 04, 2010
How to reset Konica Minolta bizhub c203 colour copier c-2558 error
Black image unit, Is the black image unit OEM or third party? Remove the unit and replace. is the Toner OEM? or third party? remove and replace with OEM parts. Open close front door to reset code. If comes back get a tech out to look at could be a bad Sensor.
Nov 06, 2015 | Konica Minolta Office Equipment & Supplies
Konica minolta bizup c550 printing black copy what will i do?
The corona housing for the back drum need to be replaced. Get a new black image unit drum and developer units
Aug 15, 2014 | Konica Minolta Bizhub C 353, Bizhub...
Error C2557 Konica Minolta bizhub c353
Replace the black image unit or take unit out and shake the the unit to spead the developer along the entire length of the image unit. also ensure properly seated.
Jun 17, 2014 | Konica Minolta bizhub C250 All-In-One...
Error C2251 konica minolta
Black developer unit motor failure to turn. Remove the Black image unit not the toner. Shake the image unit so that the developer inside is spread out along the entire length of the image unit not sitting at one end. Are you storing all your image unit flat??? If not they should be!!!!!. Hope fully you did not burnout the black image developer motor. or worse the control board. if that does not fix it get a new black image unit OEM!!!!!!!! nor third party. if does not work get a tech out, will need to be old school you have a legacy Minolta machine. A very strange one at that. P version is quite rare.
May 23, 2014 | Konica Minolta bizhub C450P Laser Printer
I have konica minolta bizhub c550,it showing me P21 and P6,what is the causes?and the black is not printing well
P6 : cyan image unit problem. P21 come after P6, and it's also too a cyan unit image problem. replace the cyan image unit.
Nov 18, 2013 | Konica Minolta Bizhub C550 Color...
I have a trouble code C-3727 showing on my photocopier konica minolta bizhub C353. What does that mean?
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.Or in case You Still Having Konica Printer Problem Then Follow Us For On: Konica Printer Support
Oct 06, 2013 | Konica Minolta Konica Bizhub C353 Drum...
Trouble code C2558
Hi rosemarie860,
C2558 on a Konica Minolta C250 means the machine is detecting an unusually high toner level in the
Black Imaging Unit. I suggest you take the Black Imaging Unit out, give it a gentle shake and pop it back in.
This usually does the trick, although sometimes only for a short period Other than that, you you might be
looking at replacing Black Unit.
Regards
m-press.biz
Feb 21, 2011 | Konica Minolta bizhub C250 All-In-One...
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
remove the filter and housing from the i/u and vac out the spilt developer, do the same on the underside, if background/halo is still there increase the seconary transfer value by 2 for plain paper
Jun 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
29 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
