Question about Konica Minolta Office Equipment & Supplies
How to replace black imaging unit Konica Minolta Printers & Copiers?
  • Konica Minolta Master
  • 6,161 Answers
Which model????? open the front door, follow the instructions and gental push and pull out.
Posted on Dec 29, 2015
Gunslinger
  • 62 Answers
SOURCE: Printing from an IBM AS/400 to a Konica Minolta 350 printer
An HP5si PCL5e driver may work for just basic printing.You will not have any extras like finishing or dulpexing.
Posted on Oct 21, 2007
SOURCE: Konica Minolta C450- error code c-2251
It's been a while since you posted that but you may just need to slide it back out and shake it back and forth (long ways) a few times. We had the same problem and the konica minolta tech told us to do that. It worked. DO NOT turn it upside down though.
Posted on Jul 18, 2008
  • 12 Answers
SOURCE: Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Posted on Apr 06, 2009
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Service Call error C0F32 in Konica minolta copiers
Since you did not include the Model number I will suggest the following:
This code means pretty much the same on all Konica/Minolta machines.
The ATDC or automatic toner density control has experianced a problem. Have you run the copier out of toner by chance?
You can try resetting this code to see if it comes back. If it keeps coming back then you are going to need the process unit serviced. Or depending on the model you can replace the "Imaging Unit" yourself.
Posted on Oct 27, 2009
How to reset Konica Minolta bizhub c203 colour copier c-2558 error
Black image unit, Is the black image unit OEM or third party? Remove the unit and replace. is the Toner OEM? or third party? remove and replace with OEM parts. Open close front door to reset code. If comes back get a tech out to look at could be a bad Sensor.
Nov 06, 2015 | Konica Minolta Office Equipment & Supplies
Konica minota c650 Printing balck baground copies
replace the black image unit. and ensure modification lock is installed to ensure proper connection if you pull out the black image unit is there black developer piled up in the rear???????
Jun 20, 2015 | Konica Minolta BizHub C650 Copier
Hi piz Error code P9 and P21 appears on screen and
check The Transfer Belt or it can be the Black Image Unit . (P9 & P21 normally: black Imaging unit) but P21 can also be refered to Transfer Belt). ..
Aug 08, 2014 | Konica Minolta bizhub C250 All-In-One...
Error C2557 Konica Minolta bizhub c353
Replace the black image unit or take unit out and shake the the unit to spead the developer along the entire length of the image unit. also ensure properly seated.
Jun 17, 2014 | Konica Minolta bizhub C250 All-In-One...
What is the konica minolta black imaging unit ?
its the image unit below the black toner lower right. the image units go from left to right yellow magenta cyan and black.
May 09, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica minolta bizhub c200 error code c2557
replace the black image unit using 3rd party toner? if so replace with OEM and USE OEM image units
Apr 25, 2014 | Konica Minolta bizhub 200 Printer
Konica minolta bizhub c200 erroe codes c255c
Black Imaging Unit Failure.
remove-shake-and reinstall black IU
Replace IU-K, if not then PRCB faulty.
Feb 03, 2014 | Konica Minolta bizhub Office Equipment &...
Trouble code C2558
Hi rosemarie860,
C2558 on a Konica Minolta C250 means the machine is detecting an unusually high toner level in the
Black Imaging Unit. I suggest you take the Black Imaging Unit out, give it a gentle shake and pop it back in.
This usually does the trick, although sometimes only for a short period Other than that, you you might be
looking at replacing Black Unit.
Regards
m-press.biz
Feb 21, 2011 | Konica Minolta bizhub C250 All-In-One...
18 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
