Question about Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer
Water level sensor fault
Machine thinks it is full of water
  • Amana Master
  • 5,323 Answers
Use a multi meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle?
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well.
Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open.
Another test u can make with a multi meter is by testing the prongs individually.
# 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch.
(where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open.
Posted on Apr 11, 2015
Hi i have a lg washing machine wft8061dd,can u please tell me why PE appear when it turn on
Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch. It is rare to see this error code on LG washers.
On non-display panel models this fault code can be shown by the lights for fuzzy, heating and speedy or super, normal and hold being lit or flashing.
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
Jun 13, 2016 | LG Washing Machines
E5 error on Onida washing machine Need solution
5E. This means the washing machine has a "water drain error". It's basically timed out on empty, it's tried draining out the water for 10 minutes and the water level still hasn't fallen below a specified level (or at least it thinks it hasn't). This error should be reset by pressing the Start/Pause button though if there is a fault it will need fixing or the error will just return.
A washing machine not emptying the water can have various causes as can a washing machine thinking it hasn't drained the water because it's possible that the signal telling the machine that the water has gone can sometimes not be triggered if a fault in the pressure system prevents it.
To troubleshoot this problem the first thing to check is the pump filter, which could be blocked. I have extensive advice on diagnosing pump faults here Washing machine won't drain water (stuck full of water) ' Faults on pressure system
May 17, 2015 | Washing Machines
Samsung model wa 7584C1. has 1E error code have changed pressure switch and tub hose still shows the same error please help
IE - Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch
  • Apr 06, 2015 | Samsung Washing Machines
    I have a Saeco Incanto classic, the low water light is on, tank is full, and I have steam coming from the steam wand.
    try descaling the machine it could be that the water level switch is clogged with water calcium and not lifting when water is added, or it is defective and needs replacement. I hope this was helpful.
    Oct 22, 2014 | Saeco Incanto Classic Espresso Machine
    Water sensor
    common faults include the rubber pressure hose rubbing and a hole forming causing the pressure switch not to recognise the water level. un plug the appliance, take the top off, find the pressure switch and you will see a rubber black or clear hose running from what is normally a circular item approx 2" diameter and a hose running doen to the drum, check this hose for splits or tears.
    Apr 10, 2014 | Washing Machines
    Will not rinse and will not empy water out and will not spin
    Possible fault in the water level sensor. IF the sensor does not work then the program controller will not proceed to go to the next cycle as it thinks there is no water to rinse. similar problem when it does not spin or activate the drain.
    May 02, 2011 | Hotpoint Washing Machines
    Washer won't fill or start cycle fault codes indicate pump failure. Changed the pump but problem persists
    Seems that the controller thinks your machine is full of water. Water level pressure sensor may be sticky. May be blockage down air line to pressure sensor - try blowing into sensor end to clear.
    (Always disconnect from power before attempting repairs).
    Feb 28, 2010 | Kenmore HE2 Plus Front Load Washer
    Washer fills up only half way but water keeps trying to fill tub
    That is because the water level switch get stuck when water level reaches that particular point.
    The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
    On washing machines it is usually a membrane switch, and that is faulty on your machine.
    Feb 20, 2009 | Admiral AW22 Top Load Washer
    Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer Logo
    41 people viewed this question
    Top Amana Washing Machines Experts
    Dan Webster
    Dan Webster
    Charles T Nevin
    Charles T Nevin
    Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
