Question about Garden
I have model #917276813 lawn tractor by craftsman would the seat sensor cause it to shut down or not run when i try to engauge blades
When I was cutting grass the engine just shut down
  • 49 Answers
SOURCE: mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Posted on Feb 05, 2009
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
wadembly
  • 462 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
  • 496 Answers
SOURCE: I have a Craftsman Lawn tractor. Blade leaves grass uncut.
Hi Tom,
Check your spindle shafts for loose play. If your bearings are worn out and sloppy, the belts pull the spindle to one side and an angle cut results... close cut grass at outer edge and high in center will leave this grass trail you are describing. I'd replace the bearings next year for sure.
I hope this helps... Good luck!
Posted on Oct 05, 2009
harlan301
  • 205 Answers
SOURCE: 46" craftsman lawn tractor shuts off when engaging
check the wire from your clutch to were it plugs in. should be on your right side. some have a yellow cover. make sure the wire is not broken. check under your deck and make sure you don't have a large grass build up
Posted on Oct 13, 2009
Manual pdf Repair manual Lt 3000 Model 917276813
http://www.searspartsdirect.com/partsdirect/user-manuals/10409/917276813-Craftsman-Parts-TRACTOR-manual?pathRender=fromManualTabPage
Jun 02, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Dies when try to engage blade
there is a switch underneath seat that shuts blades off if not pushed down or there is another one on the reverse that shuts off blades off when mowing one could have went bad hope it helps
Apr 16, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My blades stay engaged at all times model # 917273012
if the blades are staying engaged all the time try and unplug the switch if they still stay on you have a short also try getting off the seat that should shut them off as well shifting into reverse should shut them off as well if they stay on threw all that you have a shorted wire in the system
Jul 09, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
HAVE LTX1000 GOLD IN COLAR blades will not engauge cable to engauge is broke .WHERE CAN I GET CABLE MODEL NUMBER IS WORE OFF?
You can try this model # 917.272440 and go the Sears Parts Direct http://www.searspartsdirect.com
If you are from the US you can get it directly from sears. Here is the part # for the cable 175067
Jun 25, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 15.5 hp ohv briggs n stratton on a craftsman riding mower when I engage the blades or let out on the clutch the engine dies out tried disconnecting seat switch ,replaced spark plug and fuel...
There is a switch underneath the seat that will shut the engine down if the mower is engaged and you are not on the seat...that switch is bad and it thinks you are not on the seat so it shuts you down...
heatman101
Aug 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden tractor engine shuts off
Sounds like the operator present seat switch is not working. You can run the motor out of the seat, but not with the blades engaged. You didn't list what model, but usually hte seat switch is connected to the negative side of the battery, and grounds out the magneto, so you can't test it to ground. Put your tester on 12+ battery, and then to both sides of the seat switch. There is usually 4 terminals on seat switch. Some moodels have grey wires for the mageneto circuit, you can tell by whatever color also goes to the clutch switch too.
Aug 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 15.5 HP Sears Craftsman 42" riding lawn mower that shuts down when I release the clutch OR engage the blade. Starts and runs fine, but engaging blade OR releasing the clutch to go shuts her down....
I'm betting that you need a new safety kill switch - probably the one underneath the seat (the spring-loaded plunger switch that won't let you use the machine without your *** in the seat). Could also be the one behind the "dash" that is associated with the blade engagement mechanism.
I know that the under-seat-switch cannot be bypassed or it will disable the machine in the exact way that you described. Why do I say this? Because I just tried to bypass my own "***-in-the-seat-safety-switch" on my very own 15.5 HP, 42" Sears tractor, and it responded by punishing me - the absense of the switch caused the motor to cut out when I tried to put the machine in gear AND/OR engage the blade. It seems to have some measured capacitance - the absense of same seeming to interrupt the ignition timing enough to shut the motor down when you attempt to get anywhere past neutral or engage the blade. These "safety" switches may be needed by a very few who prefer to be drunk while they mow lawns on steep slopes that their tractor mowers were not designed for, but I find these items to be troublesome and enfuriating. My trees shed a lot of sticks in high winds, and I can't stand shutting the machine down and restarting it EVERY SINGLE TIME I have to dismount to clear sticks or other obstructions out of my mowing path. This is an obnoxious, "nanny-design" feature that desparately needs to be discontinued. It also makes both jump-starting the tractor and electrical troubleshooting much more difficult than they should be. The tractor should let you dismount without shutting down, as long as you have disengaged the blade and shifted into neutral. It should also let you jump start with jumper cables - impossible to do with your rear end in the seat. By the way, call Manufacturer's Supply, Inc. at 1-800-826-8563. They may have a replacement - their item number 31-9664 might do it, but talk to them first. I'm calling them tomorrow. Good luck.
Mar 09, 2010 | Craftsman Garden
Sears Riding Mower stops running when the blade is engaged
check the deadman sensor under or in the seat. if it don't "see" you on the seat then the mower will shut down. good luck and hope this helps
Jul 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When I engage the mower blades, the tractor tries to stall
Hi..my name is Keith..and the newer mowers have all kinds of safety switches..and the mowers will shut off..if you put the mower in reverse with the blades on..so i would suspect you have a bad reverse safety switch..i hope this will help..if not please write me back
Jul 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
May 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
