Question about Cisco 7945G IP Phone
How do you unlock cisco 7945 voicemail? - Cisco 7945G IP Phone
Hi, How to change Cisco IP Phone voicemail password on router. Thank you
on the CLI you need to change the username and password on the ephone for that phone. Then you need to session into the CUE module and change the password there as well. do a show run and find the username and password that you need to change and then do config t and change the password. The user can also do this on the phone if they know the previous password.
Aug 31, 2017 | Cisco Computers & Internet
I have a Plantronics headset on Cisco 7945 and after about 30 seconds you have to hit the headset button to continue the call
The issue is most likely because the Electronic Hookswitch Control setting is disabled on the phone. You can check it by following the instructions below. This setting can be changed by the phone system administrator and only applies to Cisco 7900 Series sets.
Press the settings button on the phone (checkbox icon).
  1. Choose "Device Configuration"
  2. Choose "Media Confirguration"
  3. Note the value "Headset Hookswitch Control"
Best of luck from Macondo Networks
Jan 24, 2017 | Plantronics Radio Communications
Voip settings
I've been having the same issue, I tried playing with the channel slider switch on the right side (letters A - I) and one of them worked for audio and mic. D was the magic letter for me, could be diff for you.
Feb 28, 2013 | GN Netcom GN 8000 Amplifier
The very first password that comes with the phone new out of the box. I can't access the voice mail without a password.
The voicemail password is typically set on your PBX or Callmanager. The phone is only a registered extension, when you enter the VM password it is simply passing those digits to your PBX for validation.
Sell Cisco Phone Equipment
Aug 31, 2012 | Cisco 7942G IP Phone
CISCO 7912 Ip Phone,Red lights are continuously on.
Well, in most Cisco VoIP phones those lights are used to tell you if you have a voicemail. Have you checked your vm and cleared any new ones? This might be your issue ;)
Oct 14, 2008 | Cisco 7912G IP Phone
Cisco 7945G IP Phone Logo
83 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
