Question about Audiovox ACD-12 CD Player
Is there a reset for the audiovox rrampage acd-12
I installed the stero but forgot to disconnect the negative battery cable,
2 Suggested Answers
  • 108 Answers
SOURCE: Lost my audiovox ACD wiring harness. any help?
My guess, is that you have a metal block of stereo with a receptical for a plug that has all the convienient labels, and no plug.
Fortunately, all is not lost, With a little exploration inside the stereo unit, each connector on the back can be identified. As little as two are necessary to make your stereo operate, most likely eight or ten will get your stereo fully functioning.
It's important to write down solutions and processes as you discover them; then later you can refer to them as a guide in the event that you need to retrace your steps as we go along. By freeing our attention from trying to remember everything, we have more energy to discover new things.
In my teenage days, several decades ago, I was handed many car stereos, with no wiring harnesses and I succeeded in wiring them up, 99% of the time; . . Mabe 98%.
The process is fairly basic, If you're willing to use a screw driver on your stereo; I'd be willing to show you what to do.
If you're more the, "buy a new piece to plug into that socket, then I'd reccomend posting a "Wanted . . " item in Craigslist, I always say, "If they made one, they made a hundred of them, so there's bound to be one around someone willing to part with."
I'll send a picture or two to try this system out, I'll use my desk stereo as a model, it's a Sony CDX-S2210, with no connector, I retrived from the recycling bin , On the inside, all brands have to do essencially the same thing (when it comes to the connectors on the back),
If we can share some clear pictures, this will be 100 times simpler.
That's ok.
Not too bad, 150Kb files is the most we can get right now, this will work well.
More to come, I have to sleep.
Cheers,
Richard.
Posted on Jun 21, 2009
How to change a battery in a Saturn ion 2003?
1. Open the trunk
2. Lift the carpet/flooring of the trunk to reveal the battery.
3. Disconnect the negative battery cable (8mm)
4. Disconnect the positive battery cable (8mm).
5. Remove the battery hold down block (13mm).
6. Remove the battery vent tubes from the top of the battery.
7. Lift the battery out of the trunk.
8. Install the new battery in the trunk.
9. Install the hold down block.
10. Install the battery vent tubes.
11. Install the positive cable.
12. Install the negative cable.
13. Lay the flooring/carpet back down where it fits correctly.
14. Close the trunk.
Feb 25, 2015 | Saturn Ion Cars & Trucks
How to change the starter . for olsmovile aurora 1997.
Starter REMOVAL & INSTALLATION 3.5L Engine
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Disconnect the negative battery cable.
  3. Remove or disconnect the following:
    • Lower front air deflector
    • Starter electrical connectors
    • Torque converter cover
    • Starter bolts and shims
    • Starter Fig. 1: View of the starter - 3.5L engine 9306xg02.gif
    To install:
  4. Install or connect the following:
    • Starter. Torque the bolts to 37 ft. lbs. (50 Nm).
    • Starter electrical connectors. Torque the positive battery terminal nut to 84 inch lbs. (10 Nm) and the "S" terminal nut to 20 inch lbs. (2 Nm).
    • Negative battery cable
  5. Lower the vehicle.
3.8L Engine
    • Splash shield
    • Flywheel cover
    • Starter Fig. 2: View of the starter - 3.8L engine 9306xg03.gif
    To install:
    • Starter. Torque the bolts to 32 ft. lbs. (43 Nm).
    • Flywheel cover. Torque the bolts to 22 inch lbs. (7 Nm).
    • Starter electrical connectors. Torque the positive battery terminal nut to 12 ft. lbs. (16 Nm) and the "S" terminal nut to 22 inch lbs. (2.5 Nm).
    • Splash shield
4.0L Engine
  2. Remove or disconnect the following:
    • Intake manifold
    • Starter Fig. 3: Exploded view of the starter - 4.0L engine 9306xg04.gif
    To install: WARNING
    Before installing the starter, torque the inner solenoid and battery terminal nuts to 70 inch lbs. (8 Nm). If not properly tightened, the starter may fail due to terminal or cap damage.
  3. Starter. Torque the bolts to 22 ft. lbs. (30 Nm).
  4. Starter electrical connectors. Torque the positive battery terminal nut to 70 inch lbs. (8 Nm) and the "S" terminal nut to 26 inch lbs. (3 Nm).
  5. Intake manifold
  6. Negative battery cable
Feb 04, 2011 | 1994 Oldsmobile 88
I need to replace the driver's side brake light.
Rear Combination Light- 2007 might vary from these diagrams:
Removal & Installation 2004 (Early Production) 4 Door To Remove:
  1. Disconnect battery negative cable.
  2. Disconnect electrical connector. Rear Combination Light kia-06-18-7495.gif
  3. Remove 2 screws and 2 nuts and remove light assembly.
To Install:
  1. Install light assembly and 2 screws and 2 nuts.
  2. Connect electrical connector.
  3. Connect battery negative cable.
5 Door To Remove:
  2. Disconnect electrical connector. Rear combination light kia-06-18-7496.gif
  3. Remove 2 screws and push light assembly toward outside of vehicle. CAUTION
    Use care to not damage gasket.
  4. Pull rear combination light from vehicle.
To Install:
  1. Install rear combination light and 2 screws.
  2. Install 2 screws.
  3. Connect electrical connector.
  4. Connect battery negative cable.
2004 (Late Production), 2005-2009 To Remove:
  2. Remove 2 screws and cover inside trunk.
  3. Remove 4 nuts and disconnect electrical connector (A).
  4. Remove rear combination lamp.
To Install:
  1. Install rear combination lamp.
  2. Install 4 nuts and connect electrical connector (A).
  3. Install cover inside trunk and install 2 screws.
Oct 28, 2010 | 2007 Kia Spectra5
How to replace egr valve on 1995 crown vic 4.6. Valve is in hard place to get to.
On 1995 Crown Victoria the EGR valve is located at the rear of the engine compartment. While the attaching bolts can be gotten out with a little bit of a problem the egr tube that atteches the EGR valve to the right exhaust manifold is a pain. It is possible to do though. Here are the removal and installation instructions. If you are sure that the EGR valve is the reason for any check engine light then you can remove the battery cable for about five minutes to reset the light, but if the light is on for a differant reason then you just got rid of the code plus any freeze frame data that a shop could have used to diagnose the problem.
Check this procedure about REMOVAL & INSTALLATION...
PFED Sensor
See Figures 9, 10, 11 and 12
Fig. 9: Detach the connector for the DPFE sensor
Fig. 10: Matchmark and remove the vacuum hoses for the DPFE sensor and ...
Fig. 11: ... remove the retaining nuts from the DPFE sensor and ...
Fig. 12: ... remove the DPFE sensor from the intake manifold
  1. Disconnect the negative battery cable.
  2. Label and disconnect the wiring harness from the DPFE sensor.
  3. Label and disconnect the vacuum hoses.
  4. Remove the mounting screws and remove the DPFE sensor.
To install:
  1. Position the DPFE sensor and tighten the mounting screws.
  2. Attach all necessary hoses and wiring to the sensor.
  3. Connect the negative battery cable.
EGR Valve Control Solenoid
See Figures 13 through 17
Fig. 13: Detach the connector for the EVR solenoid
Fig. 14: Match mark the vacuum hoses for the EVR solenoid and ...
Fig. 15: ... remove the vacuum hoses from the EVR solenoid
Fig. 16: Remove the retaining nut for the solenoid and ...
Fig. 17: ... remove the solenoid from the intake manifold
  2. Label and detach the vacuum hoses from the EVR solenoid.
  3. Detach the electrical connector from the solenoid.
  4. Remove the retaining hardware, and remove the solenoid.
To install:
  1. Position the solenoid and install the retaining hardware.
  2. Attach the main emission vacuum control connector and the wiring harness connector to the EVR solenoid.
continue...
Jul 16, 2010 | 1992 Ford Crown Victoria
How do you remove a 1999 Nissan Altima starter?
Nissan Car Altima & Sentra 1999-06 StarterRemoval & Installation
  1. Remove or disconnect the following:
    Negative battery cable Air duct Harness protector from the harness Starter wiring at the starter Starter-to-engine bolts Starter from the vehicle
    Fig. Starter location and mounting detail-3.0L Maxima with a manual transaxle
    Fig. Starter location and mounting detail-3.5L Maxima
To install:
  1. Install or connect the following:
    Starter and torque the long bolt to 57-72 ft. lbs. (77-98 Nm) on Altima and Maxima and 41 ft. lbs. (55 Nm) on 350 Z. torque the short bolt to 22-30 ft. lbs. (30-41 Nm) Starter wiring Harness protector Air duct Negative battery cable
    Negative battery cable Air inlet tube Harness bracket Wiring at the starter Starter
To install:
    Starter and torque the bolts to 60 inch lbs. (7 Nm) Starter electrical connectors Harness bracket Air inlet tube Negative battery cable
1.6L & 2.0L Engines
    Negative battery cable Wiring at the starter Bolts attaching the starter to the engine Starter
To install:
    Starter and torque the bolts to 70 inch lbs. (8 Nm) Starter electrical connections Negaative battery cable
1.6L, 1.8L & 2.0L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
To install:
    Starter and torque the bolts to 70 inch lbs. (8 Nm) Starter electrical connections Negative battery cable
1.8L & 2.0L Engines
To install:
2.4L & 2.5L Engines
To install:
2.4L Engine
To install:
2.5L Engine
    Negative battery cable Air cleaner cover and duct Harness bracket Wiring at the starter Starter
To install:
3.5L Engines
    Negative battery cable Air cleaner case (upper) and air cleaner to electric throttle control actuator tube. Harness protector from the harness Starter wiring at the starter Starter-to-engine bolts Starter from the vehicle
    Fig. Starter location and mounting detail-3.5L engine
continue...
Apr 05, 2010 | 1999 Nissan Altima
How to I get a new tension arm on a 1998 Chevrolet Cavalier.
  2. Remove the drive belt.
    1. Remove the tensioner bolts.
    2. Remove the tensioner.
      1. Install the tensioner. NOTICE: Refer to Fastener Notice in Service Precautions.
      2. Install the tensioner bolts.
        • Tighten the bolts to 50 Nm (37 ft. lbs.) .
      1. Install the drive belt. Connect the negative battery cable.
        • Tighten the bolts to 16 Nm (12 ft. lbs.) .
Oct 01, 2009 | 1998 Chevrolet Cavalier
I have an electrical problem. When unhook my negative clamp form battery i can get 12 volts from my negative post to a body ground. So I have a short somewhere. Where would it be.
IF YOU UNHOOK THE NEGATIVE CLAMP FROM THE BATTERY AND YOU STILL GET A READING FROM NEGATIVE POST ON THE BATTERY TO THE FRAME YOUR METER IS COMPLETING THE 12 VOLT CIRCUIT AND THAT IS WHY YOUR READING 12 VOLTS ON YOUR METER. SOME BATTERY CABLES HAVE A SECOND GROUND FROM THE CABLE TO THE FRAME BUT IS CONNECTED AT THE BATTERY POST SUCH AS A FUSEABLE LINK WHEN YOU DISCONNECT THE CABLE YOU DISCONNECT THE GROUND. IF YOU HAD A SHORT AND READ 12 VOLTS THRU THE GROUND YOU WOULD DEFINETLY SEE SMOKE
Sep 26, 2009 | 2005 Mercury Mountaineer
Owner's manual info for rampage acd-12 car stereo
You will get your owner's manual in the following link.
http://www.retrevo.com/s/Audiovox-ACD-12-Car-Receivers-review-manual/id/362ci673/t/1-2/
Hope it helps,
~regards,
Jegan
Jun 03, 2009 | Audiovox ACD-12 CD Player
BATTERY IS DRAINING EVEN WHILE CAR IS NOT IN USE
I stated "such as a light " there are many, many other causes of 12 volt drains such as a seat switch that might hang up and stick. Empty that battery overnight. First install a 9V Battery Radio memory / and clock or you will have to reset both. Disconnect BLACK negative cable of battery. Using a 12V testlight, connect one end to the disconnected cable, and the other to the negative battery terinal. It should light. Remove the 20A BODY and LIGHTER fuse first . This will eliminate the courtesy light circuit . If light goes off the drain is on that circuit. STILL LIT ? drain is on another circuit. Start by eliminating fuses. Hope this helps.
Apr 12, 2009 | 1995 Cadillac DeVille
Audiovox ACD-12 CD Player Logo
19 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
