Question about Neff Ovens
Why is my neff oven temp selector flashing 5
B4540.0
5 Suggested Answers
  • 1462 Answers
SOURCE: OVEN WON'T WORK
all you need to do is reset clock - get your book out and it gives instructions
Posted on Sep 25, 2008
  • 1462 Answers
SOURCE: neff oven won't work after a power cut
you need to reset clock - get your book out and it gives instructions
Posted on Oct 08, 2008
  • 228 Answers
SOURCE: I need to change my neff oven u1744N0GB selector
pull of control knob first, remove oven from housing and remove top panel undo 2 screws holding selector to fascia withdraw it back into top and change wires there will be quite a few dont get them mixed up! reverse to reassemble.
Posted on May 29, 2010
SOURCE: I have a 4 year
Neff Cooker manual, Neff instruction manual for ovens
Here is a link for you to download a PDF instructional manual for your Neff cooker or Neff oven.
how to use this service
1 click on Link,
2 on the left hand side click manufacturer (Neff)
3 then click on service
4 then click on service and select instruction manuals
5 enter your model number and download the PDF file .
http://kundendienst.consultens.de/gb/BSH_Appliance_Care.htm
I think you will find that it is your Thermistor, or Thermostat that has faulted, this is usually what it is... Sometimes it is the main controller that has been spiked.
You will in any event have to troubleshoot via your service manual
Posted on Aug 24, 2010
I have a neff double oven - When i try to use the top cooker the functions light up when selected then go off. The display shows -5- & the temp does not show on the screen when i turn functions on.
although it looks like a five it means safety activated or to be more precise child lock to switch off turn oven selector switch quickly 3 times off and back on between off and light only this will turn child lock off.
May 25, 2016 | Neff Ovens
I have a new Neff U15E52N3GB oven and I have to reprogram the clock each time I want to use it. Am I missing something on the original set up or is it a Naff Neff?
you are, that sounds like your setting the timer for cooking not the clock.....switch the hole thing off at the wall then put it back on, the clock should flash, then set it, check the manual for button config.
infact i just read it, & its on page 10 2nd paragraph on right hand side...........
You can only change the clock when no other clock function is
active.
ie switch it off & back on at the wall.
1.Press the < > clock function button repeatedly until
the< > O(pic of a clock) and symbols light up.
2. Set the clock using the rotary selector.
The setting is applied automatically
Dec 12, 2014 | Neff Ovens
How do the controls on a Neff Oven B1920W0GB/02 work?
NEFF B1320A2GB Manual Page 5
just click the arrows at either side of the pic to scroll from page to page,the link starts at page 5.
Sep 05, 2014 | Neff Ovens
What is rhe best temperature for cooking bread in the Neff 1451 oven?
On circotherm at around 210 in a preheated oven for first ten minute, then drop to 190 until finished. For a 2-2.5lb loaf that would be 10mins followed by 20-30mins depending how dark you want it. On the neff ovens down the left side the shelfs are numbered 4 at the top down to 1 at the bottom... you should use the shelf set on 1 or 3 (**NEVER IN POSITION 2**). Good Luck. Hope this helps.ps you can prove the bread in the oven by setting the selector to 'fan' but with no temp, the heat from the lamp will create enough heat (obviously the bulb/lamp need to be working!!)
Sep 14, 2011 | Neff B1451 Single circotherm plus Electric...
Hi - have a Neff U1721 double oven, the element in main oven went bang cracked the element and blow a hole in fan cover. replaced the element but now temp light comes on but doesn't heat up, can you...
Test element check for continuity across the terminals and it is getting power when switch onon. If both ok, chances are the front selector switch has blown.
Feb 01, 2011 | Neff U1721 Double circotherm Electric Oven
NEFF CIRCOFIRM OVEN HAS DIED? ITS 8 YEARS OLD, HAS ALWAYS WORKED WITHOUT FAULT BUT 2 DAYS AGO IT STOPED RESPONDING TO ANY CONTROL, AND THE WINDOW WHERE TEH TEMPERATURE RANGE IS DISPLAYED IS SHOWING -5- OR...
the chid lock is activated!! how did you manage to do that accidentally??? the instruction manual tells you how to disable it from memory it is turning the oven mode selector switch 3 times beetween the light position and off quickly.
Aug 27, 2010 | Neff B1641 Single circotherm super...
I need to change my neff oven u1744N0GB selector switch. I have a new one, but need to know how to change it out.
May 20, 2010 | Neff Ovens
Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Nov 23, 2008 | Neff U1661 Double circotherm super...
Child lock code -5- has appeared.
Here is what worked for me.
Turn left to light on, then off
on/off (light)
on/off
on/off
(4-5 times)
do not run through the complete cycle of options
just to the light and back off.
Ken
Aug 16, 2008 | Neff U1661 Double circotherm super...
Display on top electric oven
The oven is locked by childproof lock.
Rotate anticlockwise the function selector 3 times from the 0 position to the light bulb.
Oven light –5– goes out.
Jul 08, 2008 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
14 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
