Question about CHOICEMMED OxyWatch CF309 Pulse Oximeter
How do i get out of pedometer mode? - CHOICEMMED OxyWatch CF309 Pulse Oximeter
  • 3 Answers
The unit powers on in the last mode it was in when it was powered off (Oxygen Tester or Pedometer). If it is in pedometer mode, do this: Hit power button once to start. If in pedometer mode, simply keep pressing the power button and watch the tiny curser jump between the four symbols. When it lands on the "Return Arrow" hold down the power button for a few seconds until the unit returns to the Oxygen Tester mode. ~jim
Posted on Oct 08, 2014
Lost instruction manual for pedometer I want to reset it
Instructions 1. Press the "Mode" button until you advance to the "Step Count" feature. 2. Hold the "Reset" button for three seconds. A screen will appear asking you if you wish to reset. 3. Press the "Start/Stop" button to select "Yes." 4. Press the "Mode" button to continue and return to the pedometer mode. You have now reset a New Balance sport pedometer.
Oct 06, 2014 | Exercise & Fitness
I just purchased the ChoiceMMed pulse oximeter with pedometer. I cannot figure out how to get the pedometer part of it to work. There is nothing about it in the quick operation guide that came with it....
Perhaps you could ask the person / firm who sold the oximeter, or you could try reading the manual? Far easier than trying someone else to find and read the manual and type here, what you have in print already?
Jun 18, 2014 | Exercise & Fitness
Why does my pedometer goes into sleep mode ewhen I stop and wont go back on when I start walking again. What do I havwe to do to get it started again?
This pedometer is programmed to go to sleep for a couple of reasons.
  1. To save battery life.
  2. To not inadvertently add steps to jostles or shakes. This pedometer has been programmed to only start counting steps at your 10th step from the sleep mode. This is to help with the accracy of the device.
May 08, 2014 | Ozeri 4x3motion Digital Pocket 3D...
Beeping won't stop in Sportline 370 pedometer
Use MODE button to scroll to ALM (alarm) then press INFO button to change from ON to OFF. If that doesn't work use MODE button to scroll to PACE, then press INFO button to toggle from ON to OFF.
Feb 27, 2012 | Sportline 370 Traq Motion Sensor Pedometer...
I have a new sportline belt clip pedometer. It has 3 buttons: mode,set and r/s. How can the length of stride be entered into it so an accurate mileage reading is possible?
I have an older Sportline pedometer with the same three button arrangement.
My pedometer is set as follows:
First press Mode to get the unit in the Distance mode. Note if the unit is in Kilometers or Miles. (Press and hold Reset for 5 seconds to switch the setting. This will reset the entire pedometer.) Press and hold Set for 2 seconds. The current (or default) step length will appear and flash. Press Set repeatedly until your step length is displayed. It changes by 1" or 1 cm at a time. Then release the Set button. (The pedometer will return to the normal operating mode if you do not press a button for 5 seconds.) When you reach the maximum step length, the unit will advance to the lowest step lenght when you press Set again. Since my step length is actually not a whole number, I rounded down.
A different Sportline step and distance pedometer (the 340) is set slightly differently. To switch from Miles to Kilometers, press and hold Mode when in the Step mode. Then switch to the distance mode and press and hold Set until the step length flashes. Press Reset to advance the current step length by 1" or 2 cm. Then release the button when you have the correct step length displayed. The pedometer will return to the normal mode after 5 seconds with no button presses.
Many Sportline pedometer manuals are available from the company's web site on the product site: http://www.sportline.com . You can look up the model number.
If you add your Sportline pedometer model, I'll be glad to give the specific setting procedure for you.
I hope this helps.
(on her third Sportline pedometer, two had the plastic spring clip fail. They all had similar programming details.)
Aug 18, 2011 | Sportline step and distance Pedometer New...
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    Voicezone talking pedometer instructions, turn off alarm
    Push both the up and down buttons at the same time. You might have to repeat this two or three times. It will tell you when the alarm is off.
    Jun 22, 2009 | Exercise & Fitness
    How do you set the gaiam pedometer alarm?
    yes - after setting time for alarm, press mode and set to get alarm icon on screen
    Jun 04, 2009 | Gaiam Walking Fit Kit Pedometer...
    Reset distance mode in miles/not km
    http://www.sportline.com/manuals/345.pdf
    to change from km to miles or from miles to km... press and hold the reset button for (at least) 5 seconds (while in the distance mode.) This will reset your already walked info.
    Jan 12, 2009 | Sportline 345 Electronic Pedometer
    CHOICEMMED OxyWatch CF309 Pulse Oximeter Logo
    1,186 people viewed this question
    Top CHOICEMMED Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a CHOICEMMED Health and Beauty Expert? Answer questions, earn points and help others
