Question about Cozy (W352E) Heater
Pilot not lighting burner
This heater has worked well for the past 20 years, the pilot will light , but when I turn up the thermostat it clicks and shuts off the pilot, I replaced the the 750 millivolt generator, but the problem persists, I then replaced the gas valve (model 710-502 robert shaw ) and the problem persists. the piolt lights and stays lit, till I turn up thermostat, and I here a click and the pilot goes out. bypassed thermostat and the same result. any advise would be appreciated.
  • 49 Answers
By pass stat wire.
Posted on Mar 18, 2015
3 Suggested Answers
  • 92 Answers
SOURCE: groen tilt skillet 750 mv control
you need to check the generator in series with flame present. remove one wire from gas valve.put 1 of your meter probes under gas valve terminal where you removed one lead from powerpyle generator.put generator on other probe anything over 600 mv and your generators is ok under replace
Posted on Feb 17, 2009
  • 59 Answers
SOURCE: new Cozy Enclosed Front Console 70,000. Pilote goes out, gas stay
its not the valve you have a problem with the heat exchanger a baffle issue have to change.
Posted on Nov 24, 2010
Any idea why my Atwood water heater will shut the main burner and the pilot light off at the same time? Sometimes runs for 20 minutes, sometimes 2. I hear a clicking sound, then they both shut off.
The thermostat shuts off the main burner.The pilot light gas is controlled by the thermocouple which the side of the pilot flame has to envelop. If the flame is too small or too far away from the flame, it shuts the gas off to the pilot. The thermocouple generates a small voltage which keeps the pilot gas open. It can over time fail itself, so look at replacing it. The thermostat sounds like it's failing too.
Apr 27, 2016 | Water Water Heaters
The pilot goes out when the heater cycles
The thermocouple is not working correctly. sometimes you can clean the soot build up from it and it will work again. sometimes they just need replacing. the thermocouple is what the pilot light flame heats up when you turn on the heater. when the thermocouple gets hot it sends a 20 to 60 millivolt signal to the gas valve to activate the gas flow to the main burner.
Feb 18, 2015 | Williams Wall Heaters: 50,000 BTU/Hr...
How do I light my janitrol ucs100-55 heater?
you need to turn on the gas supply. then turn the button on the valve to the "light" position. now press down that button repeatidly until the pilot light lights, when the pilot lights you will need to hold that button down for about 15 seconds. then when you release the button the pilot should stay lit. when it does... turn the button to the "RUN" position. thats it... turn up the thermostat and the heater should kick in.
Jan 06, 2015 | Heating & Cooling
Desa heater
For (fire) safety, there is usually a thermostat that will turn off the gas if pilot light goes out.
So when you try to light the pilot you will have keep press & hold the pilot gas supply for at least 10 sec until the thermostat is heated up. Then only when the pilot light stays on continually, can you turn on the burner.
Forget about changing to a High pressure regulator!
Dec 24, 2013 | Heating & Cooling
It happens every year. The heater will work, then when I really need the heater, it stops working. First I will set the thermostat. Then The heater will sound as if it is turning on. It doesn't. It...
this is very tricky because it could be one problem or a combination. first check to make sure the igniter is working. you may have the hot surface igniter, standing pilot or the direct spark ignition. if you have ignition then check the air pressure switch because it clicks when the correct air pressure is reached. these systems go through a sequence of operations and one failed operation can result in the furnace not working.
Nov 27, 2010 | Heating & Cooling
How do i relight my standing wall heater light, where is it?
There should be a removable panel on the bottom front. Remove this panel and you should see gas valve with two lines going into combustion chamber. The larger of the two will be for burner and the smaller to the pilot light. There may be lighting instructions on the inside of panel,or on front of burner compartment. If not look at gas valve and see if you can see where it is marked off pilot and on. Turn thermostat to lowest setting and gas valve to pilot ,locate pilot light and hold match to it while you depress pilot button . Pilot should light. If it does hold button depressed for 1 to 2 mins. Release pilot button and if pilot stays lit turn valve to on. Turn thermostat up to desired setting and see if burner comes on. If it does you should be done. Put cover back on. If pilot light does not stay lit or burner won't light I Would recommend you call a service tech as there are several things that could be wrong. Hope this helps you.Thanks
Nov 12, 2010 | Montgomery Ward (223600UP) Heater
We have a gas wall heater product number 4690011 and we do not know how to start it;
Remember if you smell gas, turn unit manual gas valve off and open a near by window, wait until smell is gone then proceed with these directions,turn manual gas valve back on, turn thermostat down.1.) turn combination gas valve knob to the pilot position and press down knob, if unit has a striker button, push striker while holding down knob until pilot lights, keep knob held down in the pilot position for 20 seconds then let up on knob and turn to the on position, turn thermostat up, main burners should light.
Mar 04, 2010 | Heating & Cooling
Have a 20yr + old vulcan gas heater and I cannot turn pilot off
Hi, If you are talking about the knob on a gas valve that you use to light the pilot and turn it off also, you have to turn the knob either ccw or cw to turn it off. To light the pilot is when you turn the knob to pilot and push down and hold it, light the pilot while you continue to push it down for a minute, and then slowly release it and pilot will stay lite. So, if this is the type you have just turn knob one way or the other and it will shut off. If you do not have this type set up, just turn off the gas to the furnace at the flex line as there should be a hand valve by code and by law that supplys gas to you're furnace. You can shut it off there and the pilot will also shut off.
Sincerely,
Shastalaker7
PS If you don't have either one of these shut off's, on the main gas valve it self, you should have a place marked pilot adjustment. Pop the small chrome cap and insert a very small screw driver to turn it cw to shut off pilot.This would be you're last choice.
Jan 19, 2010 | Heating & Cooling
Cozy (W352E) Heater Logo
185 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
jdthefixer
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
