Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Chamberlain 1/2 HP door opener will not work (102 1499A))
Door will open about 6 inches and then stop and motor just hums. Same with close. If you pull or push with motor then will open and close -- but considerable force required and every little bit either way, will stop unless manual assistance is continued. Disengage and opens and closes fairly easily. 3 flashes of the light whenever it stops and starts to hum -- after about 5 seconds, the motor will simply stop.
My issue and solution.
102 1499a Chamberlain LiftMaster Security Plus + 1/2 HP
I have the 1499a same as the 1355
http://www.liftmaster.com/lmcv2/pages/productmodeldetail.aspx?modelId=9578 See pg 35 of pdf
The user guide or manual has the answer . Error - Door opens but doesn't close with the remote. OR Door doesn't close, hold the doorbell (wall) button.
My issue the sensor it had a short, one of the wires broke. I stripped it and reconnect the break. Very simple, once that was done the led lit up. The light would blink 10 times prior to correcting the short. The copper wiring is very thin. When I wrapped the copper around the terminal point it broke but the casing was still over the wire I couldn't see the break. Secondly I needed to program the remote I pressed the "learn" and then I pressed the remote button the light blinked once and it was done.
Posted on Aug 18, 2012
  • Mike Aug 18, 2012
    http://www.liftmaster.com/lmcv2/pages/pr...
    See pg 35 of pdf
    button.
    remote button the light blinked once and it was fixed.
    My issue the sensor it had a short, one of the wires broke. I stripped it and reconnect the break. Very simple, once that was done the led lit up. The light would blink 10 times prior to correcting the short. The copper wiring is very thin. When I wrapped the copper around the terminal point it broke but the casing was still over the wire I couldn't see the break. Secondly I needed to program the remote I pressed the "learn" and then I pressed the remote button the light blinked once and it was fixed.
Try adjusting the force knob a little at a time and see if that helps-- insatlled new springs and i had same problem- jacked up the fore a little and orks fine
Posted on Oct 01, 2009
    President:
  • 3,197 Answers
Remove the cover and check the drive gear. It is white nylon and is probably stripped.
Posted on Jun 23, 2009
    Problem Solver:
  • 10 Answers
Sounds like the clutch in the motor is slipping, perhaps the chain is getting kinked on something. check to make sure there is nothing in the way of it and that it is on track going into the motor
LiftMaster Pro 1/2 hp 41AS050-1 won't shut. when
Check the resistance down button (There is one for down and another one for up). You may need to adjust the sensitivity. That way even if for some reason the have hard time coming down, less sensitivity may solve that issue.
Oct 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a 6 year old craftsman 1/2 HP model139.53985D garage door opener. Sometimes it open/closes fine - other times it opens or closes 6 inches at a time and stops. Springs are fine, worm gear is fine -...
Generally when the door is closing any problem will cause the door to reverse to the open position and stop. This is designed into it. You say your opener just stops when going up or down. This makes me think there is a bad connection somewhere and you are simply losing power. If this is so you should notice that all the small lights that are normally on go out. If this only occurs when the door is going up you may have a bad RPM sensor board. This is a small printed circuit board just in front of the motor.
Aug 31, 2011 | Sears Craftsman LiftMaster Chamberlain...
My 1/2 hp sears craftsman garage door opener bought in 1992 has stopped working, The motor hums when the remote or wall button is pressed but the door will not move at all. Please help
Most common cause of the problem you describe is a bad start capacitor. Remove the cover from the motor unit. The capacitor is about 5 inches long and 2 inches in diameter.
Dec 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door only raises about two inches then stops.
Check the door springs and also remove the cover from the motor unit and check the drive gear. The door spring could be broken or the drive gear may be stripped.
The sensors only work when the door is closing.
Jun 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
My door closes fine, but when opening, it only
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and may be stripped. If so you will also find what looks like white sawdust inside the motor unit.
May 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Access Master 1/3 HP garage door does not close, blinks
Most likely your door sensors are out of alignment. Make sure they are pointed directly at one another.
Apr 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens 4 inches then reverses and stops
you need to replace gear when the door is fully closed. then do your tweaking.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens only 6 inches and stuck
I would try jumping a wire across the white & red terminal to see if your safety sensors are working Properly! If your door opens you have a loose connection or faulty sensors.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
3,013 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
