Question about Panasonic TC-50PX24 50 in. Plasma TV
Stnad for tc50px24 - Panasonic TC-50PX24 50 in. Plasma TV
How to remove oven door ghe09tp
Depends on the make and model. Usually if you stnad in fron of it, open the door slightly then pull up and towards you on both edges of the door it should pull out. You may have to play with it a bit to get it out, and can be a pain to get back in. Be careful as the springs on those hingse are pretty strong.,
Sep 03, 2014 | Ovens
What size screw does a xvt423sv stnad use?
Take the plate to a hardware store and match it.
May 27, 2014 | Vizio SV421XVT 42 in. LCD TV
Stand by light on my Toshiba 37BV701B is not working
Ihave same problem did you find out how to change the led
Oct 21, 2012 | Toshiba 37BV701B 37 LED TV
2002 jetta diesel tdi turns over and fires then dies all in about 1,5 seconds. will not start.
you could have a fuel pump fault, locate the fuel filter and blead off at the bottom ( there should be a screw typ thing under the filter) once it has bled off, turn your engine over again and see if the fuel filter is filling with deisel if it is not then you have a fuel pump fault, these are unfortunatley something a novice diy cant do unless the correct tools have been purchased, also, you could do is locate the fuel injector pipe, on each indevidual pipe loosen off the nut connecting the pipe to the engine ( do not remove completley just loosen) turn engine over again and see if you are getting fuel comming out, it should come out at high presure so be aware do not stnad to close to the injector, just a couple of things to try first as there could be many things...hope thats a start for you
Feb 11, 2010 | 2002 Volkswagen Jetta TDI
Ive gotten my third xbox 360 now and neither of them worked this one now has the red ring what do i do?
if its all 4 then make sure you power cables or av cables are fully pluged in if its 3 then try the towl trick(search it up on youtube) or the thermal replace (again search up on youtube) sorry i cant be of more service there but i currently i cant acces those file at the momnent. if its just 2 rings then try tom keep the 360 with sufficant airflow on the right side. which would mean to not stnad the consel up but lay it down on its side
Jan 05, 2010 | Microsoft Xbox 360 Console
Problem
Dear Nazir Ahmad,
I think, Horizontal deflection circuit got problem in your TV. If you are skilled/ qualified technician, then open TV set because your safty is 1st priorty.
May 27, 2008 | Sony KP-61HS30 TV
Stnad by button doesnt work?
For solving your problem do the following:
1. Select Start -> Settings -> Control Panel
2. Select the "Power Options"
3. Power Options Properties window appears
4. Selec the "Hibernate" option i.e., 3rd Tab
5. Check mark for "Enable Hibernation"
6. Click on Apply
7. Click on OK
Let me know if your problem is solved and rate me as FIXYA!
May 16, 2008 | Computers & Internet
Sony Trinitron kv-32fq75b
Sounds like the either the connection from the cable/sat box is loose or the board connecting the cables to the tv is loose. If you try unplugging and then reconnecting the cables and hold the cables in tight that might give you and idea. If you hold the cables in tight and the tv works right, then you know its your board. If thats the case the Tv needs to be serviced. Otherwise you might try using some other cables.
Aug 26, 2007 | Televison & Video
Panasonic TC-50PX24 50 in. Plasma TV Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
