Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pny driver looking for a driver for pny 8 gb , not recognized by win7
Find driver for pny 64g flash
Maybe the flash drive has gone bad (belly up). Try a different usb port on the computer.
Try the Flash Drive on another computer and see if it recognizes it. If not, the drive is gone bad.
You don't need drivers for it. Think about it, did you install a driver for it when you purchased it and first plugged it in? The operating system picks it up automatically and installs the drivers through windows.
But, if you want to see if there are some drivers for it, try PNY's website.
Get online and got to www.google.com In the google search box type: "PNY Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the drivers.
Jun 03, 2012 | PNY 64GB Drive
Pny 2gb not recognized by windows vista
Try connecting it some other computers.
If it does not work at all, spend $8 to replace it.
If it does work, then it's either the "hardware" on your computer, or the Vista "software" (wrong/missing USB device-drivers).
Apr 20, 2011 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
I bought the 8 gb from bestbuy but my lg pop and computer doesn't recognise it? it cost me $30 damn it
sounds like the u might be able to update your BIOS. if your not familar with this technique have a pro do it, its easy to do at the manufacturer of your laptop or comp. website under support. downloads
The might not be an update that recognizes above 2 or 4 gb "written" in the bios. old ibm pcs had a similar drawback, also when puttin huge hard drives in a limitation in bios screws up everything
Oct 09, 2010 | PNY 8GB Secure Digital High Capacity...
Does win7 work properly on vaio vgn-nr240e
I believe it should work fine. Sony's site has good driver support for windows 7, and directions on installing Windows 7 on that machine. So it should work without any issues.
http://esupport.sony.com/US/perl/support-info.pl?template_id=1&info_id=508&8
Driver updates can be found HERE.
Mar 16, 2010 | Sony VAIO VGN-NR240E/S 15.4" Notebook PC...
I HAVE A DXG DIGITAL CAMERA. WHEN I HOOK UP THE CAMERA INTO THE VIDEO INPUT THE PICTURE IS ALL JUMPY & UNCLEAR
Here's my problem: I recently bought as in today a PNY Optima 16 GB SDHC Card for my DXG-566V camcorder. When I inserted the card into it's SD card slot (which I assure you I did correctly), and powered up the camcorder, the camcorder didn't recognize the SD card, as it was still running off of the camcorder memory! Now I know the camcorder is just fine becuase after that I inserted my PNY 8 GB SDHC Card and the camcorder recgonized the card.
Please help me out here!
Jan 12, 2010 | DXG Technology DXG-566V Camcorder
How to get a driverfor pny 8 gb flas drive for
Then you will have to use a diskette or a CD, download the driver on some other computer, unpack and copy it to the diskette or burn on a CD-R.
Go to this link to download the drivers and for further reading on Windows 98 USB storage issues.
Dec 29, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
MMy motorola razr phone deosn't recognize 4 gb PNY
The 4gb card may be larger than the maximum card size that the phone can read. The maximum may be 1 or 2gb. If its over the maximum size supported the phone wont be able to recognise it
Sep 22, 2009 | Motorola Mobility RAZR V3
Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
Jun 29, 2009 | SanDisk Sansa e260 MP3 Player
Flash Drives
Try to use a new Computer having Windows Vista, Dual core, 2 Gb RAM, and at least 160 Gb Hardware.
Your problem is solved.
He! Ha Ha Haa Haaa!
Jan 25, 2008 | Electronics - Others
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
59 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Computer Links
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
