Question about Carrier Heating & Cooling
Override codes carrier 30 gx prodailog l on override code
Please someone give me the unlock code for Xperia GX
Each Sony Xperia GX mobile phone has an unique unlock code and it is based on the phone's IMEI number .Unlock code that worked for other won't work for you. You can get the unique unlock code for your Sony Xperia GX mobile phone from Unlock-Zone.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code.
Jul 26, 2013 | Cell Phones
What is the unlock code of Xperia GX
Each Sony Xperia GX mobile phone has an unique unlock code. You can get the unique unlock code for your Sony Xperia GX mobile phone from Unlock-Zone.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code.
My Nokia 5130 xpressmusic is not accepting security code. I know my security code. I have tried so much. What do I do?
You should contact your carrier. They may have an override code to help. If you are in the U.S. dial 611 from your phone... but you may need to be on a different phone to work through the problem... they should tell you what number to call from another phone.
Apr 22, 2011 | Lands Phones
I locked my phone by accident and now its saying "your sim cannot be accesed.please call your carrier to obtain your PUK code" is there a factory code or anyway i can override it?
No there are no override codes.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
Dec 24, 2010 | Apple Computers & Internet
Problem is showing override in error code
OVERRIDE MEANS YOU HAVE A SET PROGRAM IN THERMOST THAT HAS A TIME SETTING   SAY AT 8 PM TO TURN ON OR UP TEMP YOU MUST REMOVE THIS SETTING IN PROGRAM OR  MAKE YOUR OWN OR JUST GET A SIMPLE T STAT THAT HAS NO PROGRAMING WHICH MAKES LIFE EASY FOR YOU. THERE MAY BE A RESET BUTTON ON BACK SIDE OF T STAT TO RETURN TO DEFAULT FACTORY SETTINGS
Apr 20, 2010 | Carrier 38CKC036 Air Conditioner
Forgot my phone lock code lg env3-vx9200
If you have not changed it, then the security code is just the last 4 digits of its telephone number.
If you have changed it, though, then yes, you'll have to contact your carrier.
Jan 26, 2010 | Cell Phones
I forgot the code to open my Hardline Digital Electronic Security Safe S2120. I need help on how to open it
Comment by jwlevan September 17, 2009 5:59 pm
does she have the user override key? I found this...
User override key to open safe.
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
..might help ya out..but i'm no guru w/ safes by any means!
Sep 16, 2009 | Office Equipment & Supplies
SIM CODES
well for the sims what you do is enter any number 3 times and it will say puk blocked then ring your carrier eg optus virgin ect ect they will ask you 4 your details and give u the puk write it down incase then u will enter your new sim pin code and repeat as for the phone
ring your fone compaony provide them with you imei number under the battery and they will tell you a code something like a override code to reset the phone good luck
Jul 02, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Ricoh caplio gx 5.1 mega pixels
Email this problem to Ricoh Techincal Support Team This appears to be an internal defect.
May 26, 2007 | Ricoh Caplio GX Digital Camera
Heating & Cooling Logo
16 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
