Question about Radio Shack TRC-447 CB Radio
How to change 4 pin astatic mic to 5 pin realistic cb radio ssb+am trc -448
    Genius:
  • Radio Shack Master
  • 1,795 Answers
Buy a five pin dn adapter
Posted on Aug 09, 2014
PyroMan6x9x9
  • 150 Answers
SOURCE: Realistic TRC-474 User Manual
Unfortunatly a owner's manual is no longer available for that, but here are some general CB hint's and tips. Hope this helps. TRC-424 4-Watt Solid-State Transceiver (210-1522) Hints and Tips Faxback Doc. # 48947 NOISE Your vehicle or boat can be the cause of much noise interference. Since the receiver section of your transceiver is very sensitive, it can pick up even the smallest noise signal and amplify them. Any noise that you hear in the transceiver is almost totally from external sources. The receiver itself is exceptionally quiet. Steady high noise levels can not be totally eliminated by the internal Automatic Noise Limiter circuit (BLANKER). Noise problems can not be solved internally (in the transceiver); they must be solved at the source of the noise. If you wonder if the noise is from your ignition system, the transceiver or an external source, try this simple test. Turn your ignition switch off and set it to ACC (accessories). This turns off the ignition, but supplies power to the transceiver. Most of the noise will disappear - indicating that the source of the noise is your ignition system. This interfering noise can be generated anywhere in the electrical system of the vehicle or boat. The first step in reducing or eliminating this noise is to locate the source of the noise. IGNITION SYSTEM The most common source of noise is the ignition system. This noise can be identified by the fact that it varies with the speed of the engine. It consists of a series of popping sounds occurring at a regular rate that will vary with the speed of the engine and stop when the ignition is turned off. There are a number of things that can be done to reduce this type of noise: 1. Use only the 'radio suppression type' high voltage ignition wire. Most new cars come already equipped with this type of wire. 2. Inspect the high voltage ignition wire and all connections made with this wire. Old ignition wire may develop leakage, resulting in hash. 3. If the noise still persists, replace the spark plugs with spark plugs that have suppressor resistors builtin. Be sure to use the correct type for your vehicle. Other sources of noise are: generator/alternator, regulator, gauges and static discharge. Most of these types of noise can be effectively reduced or eliminated by using bypass capacitors at the various output voltage points. We suggest that you check your RadioShack store for a wide selection of noise reduction accessories. SERVICE AND MAINTENANCE Your transceiver has been built in accordance with RadioShack's exacting quality control standards. However, it should be treated with reasonable care accorded any electronic equipment. Avoid exposing it to severe shock, dirt or moisture. If you run into problems with the unit, we recommend you check the following: 1. If trouble is experienced with receiving. Check VOLUME On/Off switch setting. Be sure SQUELCH is adjusted properly. Is it over-squelched? Check if the unit is switched to an operating channel. 2. If trouble is experienced with transmitting. Be sure the Microphone is firmly connected to the Microphone jack on the unit. Check if the transmission line is securely connected to ANTenna Coax Connector. Check if the antenna is fully extended for proper operation. Are all transmission line connections secure and free of corrosion? Make sure you are fully depressing the push-to-talk button on Microphone. Check PA push-button setting. It must be in 'out' position. 3. If the transceiver is completely inoperative. Check the power cable and fuse (2A). If these checks don't solve the trouble, do NOT attempt repair or adjustments yourself. The unit should be services only by a qualified radio technician. Whenever possible, return the unit to the store from which it was purchased. 10-CODES Citizen band radio operators have largely adopted the 10-code for standard questions and answers. Its use permits faster communications and better intelligibility in noisy areas. The following table lists some of the more common codes and their meanings. 10-1 Receiving Poorly 10-10 Standing By 10-2 Receiving Well 10-13 Advise Road/Weather Conditions 10-3 Stop Transmitting 10-20 What is your location? 10-4 OK 10-33 Emergency Traffic 10-7 Out of Service 10-36 Correct Time 10-8 In Service 10-41 Switch to Channel 10-9 Repeat 10-99 Cannot Copy You WARNING DO NOT OPEN UP THE TRANSCEIVER TO MAKE ANY INTERNAL ADJUSTMENTS. Any internal adjustments can be made only by (or under the direct supervision of) a person holding an FCC 1st or 2nd Class Radio Operator's License. Internal adjustments and/or modifications can lead to illegal operation as defined by FCC Rules and Regulations, Part 95. Such illegal operation can lead to very serious consequences. To Be Safe And Sure: 1. You should never open up the case of your Transceiver. 2. Never change or replace anything in your Transceiver. (wr 08/04/98) Privacy Policy
Posted on Sep 13, 2007
SOURCE: Mic wiring diagram
Want to wire cobra mic to a uniden washington radio
Posted on Mar 27, 2009
  • 8 Answers
SOURCE: Looking for a free download of a REalistic TRC-474
torrent scan
Posted on Oct 17, 2009
  • 141 Answers
SOURCE: how many amps does a Reakistic CB radio TRC-474
4 amps MAX
Posted on Jan 30, 2010
  • 118 Answers
SOURCE: operating manual realistic trc 452 cb radio
Check out this link I think it will help. http://support.radioshack.com/support_electronics/15777.htm
Tom
Posted on Nov 29, 2011
Bad connection on 5 pin mic jack on realistic trc-469. Wiggle it and it'll work. But how does it come out ? Have a new 4 pin to replace it with. Can't find the break.
With the CB radio off & not connected to power, check or have a friend check the contact points, at each end with a Volt/Ohm Meter.
Oct 10, 2016 | Radio Communications
I want to wire my superstar dm452 power echo mic to my realistic trc 465 am ssb and need to know what color goes to what pin?
its a 5 pin which all radshack radios are and they are all,99% anyway, wired the same . So take an old radshak mic apart at the plug and see how it is wired then experiment from there.
Apr 07, 2015 | Workman Publishing Workman DM-452-5 model...
Wire 4 pin Turner Plus 3 Power Mic for cb radio to 5 pin President Washington SSB AM Radio
the best i can find is this
red pin 5 ptt
black pin 4 ptt ground
white pin 1 mic
shield pin 2 mic ground
no connection pic 3
Jan 19, 2015 | Radio Communications
Six wire mic to a trc 495
Realistic radio mics are all , except for a few , wired the same. All you have to do is look up the wiring for the realistic 5 pin din plug . One of those wires in the mic is not going to be used the thing is which one . Connect the wires as they are mentioned in the diagram then if it doesn't work connect the last wire.
Oct 26, 2012 | Radio Shack Radio Communications
I need to know what colers go where on the mic pin for a trc 447 thank you
I don't know which mic you're trying to wire to this radio. The colors of the wires in the mic cable may change from one mic to another, so relying on the color is not reliable. Usually you refer to these connections as Pin1 to a Signal or Function; or Jack Pin1 to Plug Pin3. No one assumes a color will always be used to connect Pin1 to TX (transmit).
With that said, I found an answer on FixYa from someone that answered the question some time ago like this:
HERE IT IS THE CORRECT MIC WIRING FOR THE REALISTIC TRC 447.
1.)Audio
2.)RX
3.)TX
4.)CH.Down / Shorted to Ground
5.)Ground
6.)Ch.Up / Shorted to Pin 4
Be extremely careful when wiring this radio! pin 4 and pin 6 carry voltage shorting these to the wrong place can result in serious damage to your radio.
Lastly, since I doubt what was provided above is going to help you very much - you can review all the info ever printed by Realistic on your radio, here. There's a wealth of info on this page and you should be able to find what you're looking for in it. You're looking to find the pinouts of the radio to the pinouts of the mic.
If you ever have to disconnect a multiconductor cable from a connector, and you don't have the time or means to write the colors down, it is better to simply cut the cable - leaving all the colored insulation of wire ends soldered / still secured to the connector. When you are ready to do the replacement of the connector or cable, you've got the wiring order in place still, and can make the new connections one at a time at your leisure.
Aug 11, 2010 | Radio Shack TRC-447 CB Radio
Cb mic wiring
I have a browning golden eagle mark II. It has a two pin mic plug. I would like to hook up a astatic power mic to it. Anyone have an answer?
Oct 07, 2008 | Magnum DeltaForce CB Radio
We need a wiring Diaghram for a Realistic TRC 495 Echo Mic.
You can download it at CBtricks.com ....hope this helps....
Dec 08, 2007 | Radio Communications
Mic wiring diagram
Nov 20, 2007 | Radio Shack TRC-447 CB Radio
Radio Shack TRC-447 CB Radio Logo
142 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
