What format does the usb support
Some films are playing but no sound
How do I play video from a usb drive on the Proscan Model# PLDV321300. When I put it in it does not recognized the the usb drive
The USB connection on the back is likely for service. Suggest organizing photos and music and video on the CD DVD input
Hope this helps?
See manual on the link
http://legacy.curtisint.com/html/CustService/Manuals/PRO_PLDV321300_EN.pdf
Jun 20, 2017 | The Computers & Internet
What type of USB format can I use to view film on my Panasonic SA-PT460 Home entertainment system
Check your owners manual, it should list all of the supported formats for both pictures and video.
Oct 12, 2014 | Panasonic SA-PT460
How do I update to play mp4 films
USB memories formatted NTFS will read XviD videos. Ext3 or FAT formatted will copy or read XviD. MPEG4 is not supported but your TV may be able to show them directly via its USB PORT.
Sep 17, 2014 | Humax Hdr-Fox T2 500Gb Freeview Hd Digital...
Films on flash drive which format for bush 39tv
On a Bush 39TV the USB connection is only for service like upgrading software. For playing films on flashdrive you should use a propriat media player.
Regards GJ
Jun 21, 2014 | Philips 47PFL7403D 47 in. LCD TV
Hannspree hsg1075 says it plays video from USB but has no video in input menu.
Notes:
• It does not support "NTFS" and the maximum file size of a single file is 4GB.
• Progressive format jpeg files are not supported.
• Due to the compatibility limitation, not all of USB devices are able to be
displayed properly.
• Operation using USB hubs is not guaranteed.
• Due to the compatibility limitation, not all of external hard disks are able to be
detected correctly.
• Cables used to prolong the USB device must be certified as USB 2.0.
• In USB devices, video files may not be played properly if speed is not enough.
Apr 08, 2014 | Televison & Video
My hannspree tv doesnot play all the movies from the USB or i have image with out sound or i have image and sound and subs
That sounds like a codec issue. I would try to find out what video format you tv set supports. Then convert you films to suit.
Oct 23, 2013 | Hannspree XV37 HDTV 37 in. LCD TV
My hitachi tv wont play movies via usb??
this tv will only play mp4 video (MPEG-4) ONLY AND DOES NOT PLAY THE H.264 MP4 FILETYPE EITHER...ONLY TRUE MP4, BEST BET IS TO GRAB YOUTUBEDOWNLOADER (IT'S FREE) AND USE THE CONVERSION FEATURE TO CONVERT YOUR MOVIES TO THE IPAD VIDEO SETTING WITH SAME QUALITY AS ORIGINAL SELECTED...CONVERSION TAKES 30 SECONDS...BEST 100% GUARANTEED TO WORK ANSWER..I KNOW...I HAVE ONE CONNECTED TO MY 4TB HARD DRIVE.
Jun 23, 2013 | Hitachi Televison & Video
Can't play avi videos usb
Hello to all. Have twin boys staying over the holidays and they wished to view movies when they went to bed. have Polaroid 32" P32LED12 fitted to their bedroom. The tv is ok for playing dvd through it but when on using the usb drive with movies on it, it came up Invalid or Unsupported file. Have tried different movies with different formats and came up with nothing to play. So got myseld a video converter program: Wondershare video converter ultimate. On looking at the booklet from Polaroid, it says MPEG1.2, but although on converting the film to this format, the film broke up. So I took an AVI trailer and converted the trailer to all the formats on the converter and stuck this on the USB and stuck it into the tv. Out of all of them, i found that the converter format was VOB DVD FORMAT in this coverter. The film did not break up and the sound great. The film sizie was a bit smaller in frame size but this can be increased. What the converter showed after the conversion was: DVD-Video/ Format: VOB. Video Codec: MPEG-2/ Audio Codec: MPEG-2 audio. There is a settings on this converter at the lower right corner, but you can fiddle with this yourself. But to finish with, I have tried most of the films with different formats and could not get them to work on this tv, so get yourself a video program converter, put in laptop or pc and convert film to VOB. Hope this helps as there is nothing in any help on google for this tv.
Apr 03, 2013 | Polaroid Televison & Video
Hi -- i have a problem? regarding my sanyo CE26LD47-B television the tv itself is ok!,--channels etc., but it has a "usb"connnection, and i want to play my external hardrive through the...
If you were to find a film that works then look at the format of it on your PC. Converting the films that don't work to the same format should do it.
Mar 11, 2011 | Televison & Video
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
