Question about HP COLOR LASERJET CP 3505 N PRINTER
No magenta printing
Magenta prints as a dark orange color. No reds print at all. Replaced magenta cartridge recently. Dirty mirrors or defective magenta??
  • Jeff Hunt
    Jeff Hunt May 28, 2014
    I should add that this printer is an HP Laserjet 3700.
  • HP Master
  • 1,121 Answers
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
Posted on May 28, 2014
Testimonial: "Update: When printing from MS Word, changing text colors to red, red prints fine. However printing a photo, or image, red/magenta is bad. This leads me to believe the cartridge is fine. Also, test page and consumables level page prints nicely."
SOURCE: HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Posted on May 01, 2009
  • 619 Answers
SOURCE: printer cartridge's cyan and yellow not printing
replace w/new ink and nozzle check , if test nozzle print ok , if the same happened , head cleaning , test print , all solor solid nothing gap or blank within the color , mean good , try to print variety color picture.
Posted on Jan 04, 2008
SOURCE: HP Color LaserJet 2605dtn won't print magenta at all.
I just encountered this problem with my 2600n purchased in June2008. I'm not very mechanical and had no difficulty following the instructions providing in the link above (Feb 04, 2009) and solving the problem on my own. I have printed well over 10,000 pages on this printer and it ran like a dream until the dusty mirrors interfered with color quality. Now its back to usual top-notch quality and I'm thrilled. Thanks for the posting of service instructions for a quick DIY and saving me the expense of servicing, recycling and/or purchasing a new unit.
Posted on Nov 03, 2009
pineworks
  • 4041 Answers
SOURCE: My HP C6180 is not printing its magenta color.
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 21, 2010
Testimonial: "Thanks for you good advice. It all made sense to me and it should have worked. I found 9 others reporting the exact same problem. Craig patentQ.com"
  • 217 Answers
SOURCE: We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Posted on May 09, 2010
HP CM1015 - stil works; Magenta does not print even though full
The magenta might have been freezed, change the magenta.
Thanks.
Jun 19, 2012 | HP LaserJet CM1017 MFP All-In-One Color...
Cyan and Magenta does not print on the right side of the paper. Toner indicator shows three quarter of the cartridge to be full. Yellow and black prints are perfect.
I have worked/ serviced similar Laserjet Color Printer with same issue.
Actually, prints with faded colors or different colors are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. For instance, red color is formed by a mix of yellow and magenta toners. The color is replaced by yellow due the the partial or complete blocking of the image laser beam for
magenta as the mirrors which reflect laser beam get covered with dust and toner (which partially blocks the laser beams). Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer. Note that first magenta goes off, followed by yellow, then cyan and lastly black. This is due to the mirrors placement inside the printer. Magenta is the last one facing upwards at 45 degrees angle and gets most of the dust and goes off first.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
Mar 31, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
The color red is dull when printing
I assume you've checked magenta toner cartridge level, and tried cleaning.
If so, the next thing to do is try cleaning the scanner mirror. On these models the mirror nearest the magenta toner builds up dust the most quickly, hence why it is the first colour to fade on prints. Only use dry swabs (no solvents) and compressed clean air on the mirrors.
Nov 03, 2010 | HP Color LaserJet 2600n Printer
The Magenta colour on my 2605dn is no longer coming out properly (very faint). The cartridge was replaced by made no difference. All other cartridge colours work fine. Tried cleaning and calibrating but...
A faded magenta on this model is probably a dirty scanner mirror.
The printer design puts a fan in an area that blows magenta toner directly at the laser scanner.
The more toner on the mirror, the more faded the print.
You will need to remove the scanner and clean it.
Nov 02, 2010 | HP Color LaserJet 2600n Printer
I replaced all 3 color cartridge with origanal hp products, even after calibrations (3 times-full mode) only cyan and black are printing nicely. red and magenta colors are not printing.this is not driver...
This is a common problem with this model of printer. The scanner optic degenration is due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta toner cartridge, red tones are the first to show fading. Colours shift: purples turn blue and oranges turn yellow. The printer optics will need to be cleaned by a technician to resolve this issue as it means dismantling your printer deep into the optics to fix the problem.
Jun 07, 2010 | HP LaserJet 3600n Printer
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
This printer has stopped printing reds and oranges correctly ? they are faded. Changed the toners & no difference
Print a "Config Report" from the printers menu...If u notice that the fourth square on the left side (fourth being the bottom square) for Magenta (reds and orange) is missing or very faded, this could indicate that the optical mirrors inside the printer have to be cleaned...Design flaw. ESP..if changing toners doesn't work and your your faded issue is with Magenta (Pink, red, or orange) colours are the only faded ones...With this design flaw in the optical mirrors, magenta mirror is the first to be affected!
Hope this helps!!!! I work in the industry :)
Feb 22, 2010 | HP Color LaserJet 2600n Printer
Red prints as Orange
If this is magenta being weak (light) on all the things you print (try doing a test pritn, and a configuration page from the printers own menu system). this will be the dirty laser lens/mirrors problem that is very common with this printer.
Solution is either
Dismantle (it IS quite a lot of work, but fairly straightforward methodical screwdriver work) the printer to remove the laser unit. Take cover off the laser unit and CAREFULLY clean the lenses and mirrors. NOTE take care not to disturb the alignment of any part of the laser optics, and be especially careful with the mirrors as they are surface silvered and V easily scratched.
You can find NEW laser units on a certain internet auction site, and also (genuinely) refurbished exchange printers. Both of these two opttions will obviously save time and effort, but be more expensive.
Jan 20, 2010 | HP LaserJet 2605DTN Color Printer
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
HP COLOR LASERJET CP 3505 N PRINTER Logo
213 people viewed this question
Seeker5211
Seeker5211
