Question about GE Adora (DSF25KGTBG) Side by Side Refrigerator
MY GE Adora side x side's ice maker is producing ice, but is not able to dispense it "outside." When the dispenser is engaged/pressed, there is a "clunk" and then a low humming as if it is still trying to dispense. I am unable to rotate the yolk, so that is no stripped. Suggestions? Thank you.
peyton32034
  • 410 Answers
SOURCE: GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Posted on Dec 16, 2007
the dr
  • 447 Answers
SOURCE: GE Profile Side-by-Side Refrigerator Ice Maker Issue
The Computer on the Door communicates to the Main Control Board on the rear of unit via several small low voltage DC wires .Ive had this problem and is was a bad connection under the freezer door behind the toe plate (it goes through the middle of the hinge). You can try wiggling that connector, but if it still doesnt work you may have to bypass that connector with proper techniques. Unplug before cutting or splicing, If is still doesnt work than There is no other way to tell what the issue is besides replacing display board and Main board. I would try Main board first if connection is good. Hope this helps
Posted on Jan 19, 2008
  • 1073 Answers
SOURCE: Water and Ice Dispenser shorts Fridge
call ge there is a replacement program for the 05-06 sxs motherboard issue call 800-386-1215 to see if your machine is one of the machines in this program you will need the serial number of the ref before you call
Posted on Jun 13, 2008
  • 330 Answers
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Posted on Jul 21, 2008
peyton32034
  • 410 Answers
SOURCE: icemaker makes ice; door dispenser cranks, but no ice dispensed
sounds like either the dispenser motor is bad or the dispenser yoke is stripped. remove the bucket from the freezer. you will see a u shaped yoke in the rear of the disp area. this should be fairly hard to turn by hand if it turns easily then the motor gears are bad if the yoke slips on the motor shaft then you have a stripped yoke. hope that helps. peyton...
Posted on Jan 22, 2009
I have a ge adora fridge that when pressing the lever for ice makes a loud humming noise & feels like freezer wants to explode. Cab anyone tell me if they have ever run into this issue
You probably have a ice dam in your ice tray. The anger is trying to dispense if but if the cubes have frozen together and produced a large chunk of ice it cannot break up. Open the freezer door completely and lift up and pull out through ice tray. Remove ice until dam removed. Reassert tray and make sure to turn ice maker back on. It is essy to inadvertently bump switch. Try dispensing ice to see. If noise went away.
Hope this helped!
Apr 19, 2016 | GE Refrigerators
GE Adora Refrigerator. On the freezer side, water seems to be leaking from the top/back of the freezer. Not sure how it's happening, as it's usually frozen when I realize it. My housemate believes...
Hello
Check fill tube that puts water into ice maker. You may need to use hair dryer to thaw out. Look for a tube that comes out of back wall of freezer behind ice maker section. Make sure its there and pushed all the way in .This is a bad GE design. (could have fallen out)
hope this helps
Aug 16, 2011 | GE Adora (DSF25KGTBG) Side by Side...
My GE Adora Refrigerator is making ice but not dispensing it. What could be the problem?
The switch for the screwfeeder is probably not any good. With ice or not, the screwfeeder should turn when you push the handle in to dispense ice. If there is any ice in the hopper, it will get drawn in by the screwfeeder and sent out the dispenser door in to your waiting container.
Oct 08, 2010 | GE Adora (DSF25KGTBG) Side by Side...
The ice maker does not produce any ice. The power light blinks and the water dispenser in the door works, but no ice...
You have a bad connection on the ice maker switch. try replacing it. Question? is the water in the dispenser cold?.
Apr 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The water dispenser on our GE Adora refridgerator (DSS25KGRA) stopped dispensing water. The internal icemaker still makes ice and the door unit dispenses ice both cubed and crushed. Could the water line be...
Most of the time it is the half of the dual water control valve on rear of refrigerator. The part number Click Here=> WR57X10032 Usually the coil on that side will go bad before buttons or controls. You can test that side by setting a test meter on AC voltage and you should read 120 volts while someone presses dispense water on front. There are two sides one plugs into icemaker side and other water dispenser. When replaced they both come as a kit. If you would like you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Ice and water not dispensing
check the water solenoid in the back of the unit where the water line hooks up. sounds like the solenoid is not powering to admit water to the ice maker or dispenser.
Jun 01, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ice maker not making ice Adora GE
yes I have the light blinking, no ice jam, changed the water filter, so how do I get ice?
Mar 22, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Water dispenser does not put out water when pressed water is in the line to where it connects at the bottom of frige. Help : ge side by side 197d3351p012
On back of refrigerator are 2 water control valves. One is for the ice maker and the other is for water dispenser. While pressing the dispenser control does the solenoid on back buzz or produce a magnetic field? Unplug the wires from the solenoid and test the voltage coming to the two wires when you press the dispenser? Tell what you find, Sea Breeze
ccf996d.jpg http://servicepartstec.blogspot.com/
Mar 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Icemaker will not was dispense ice
My icemaker stopped producing ice. We turned off the water line to it when we went on vacation for a week. We turned the water back on when we got home and since that time it won't produce ice. We can still get water from the door dispenser though.
Nov 02, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Adora (DSF25KGTBG) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
