Question about Hagen Optima Aquarium Air Pump A-807
How to replace replace diafragm - Hagen Optima Aquarium Air Pump A-807
After increase volume of Altec lansing T612 voice are break
Also the crossover inside the Altecs must both be controlled.
The diafragms of the tweeters replaced, thats in most cases easy to do selfmade . look for examples on youtube .
What is Clipping Understanding Amplifier Clipping Clipped Signals
Sep 12, 2016 | Altec Lansing Audio Players & Recorders
Error maeesge and no auto focus
What message? if an FEE, perhaps you forgot to put the Diafragm marking to the greatest figure (22 or so) and forgot to put the lock on.
Next time, I think it could be very helpful you tell what error you see. Nobody needs to guess what you see.
Feb 04, 2014 | Nikon D80 Digital Camera with 28-80mm Lens
Trying to find a Tweeter Diafragm only (not the magnet) for my Jamo 300ex pro, 20136??
Yes tweeter 20136 has the Jamo Diaphram part 25209.
I have this part in stock.
If you want one I can be contacted on jb@qualifi.com.au
regards
John
Nov 16, 2011 | Jamo A-210FS Speaker
I have a Nikon D80 that reads "ERR", won't take photos, but shutter still fires. I tried cleaning the contacts, and still I get the ER msg. Help?
Does your lens have a diafragm ring, A ring with numbers on it like 22 16 11 8 5.6 3.5. Set this ring to the maximum. I hope this helps.
Aug 14, 2011 | Nikon D80 Digital Camera with 18-135mm...
Hello. I just bought a Pentax me super with 1.4 very cheap and in very good conditions. There's just one problem. The problem lies in the mount of the lens. I guess it's called aperture ring? When...
Take the lens to a repair facility. When you've recovered from the shock of the cost, look on Ebay for a replacement. FYI, it may be better to get an f1.7 lens instead - far far cheaper, and the f1.4 was notorious for less than optimum optics wide open. You'll only lose half a stop or so, which is negligible.
Mar 04, 2017 | Pentax ME Super 35mm SLR Camera
How to connect the two little hoses of the air valve (diafragm valve) of the 3.7 L, V6 engine
do they make this vehicle as a petrol version ?? i have just been working on one all day and its a diesel ,never seen a petrol variant of this vehicle and didnt know they made one only diesel manuals ,and one diesel automatic i have seen
May 20, 2011 | 2006 Kia Sorento
I have nikon d200 i see in lcd one message that says "Err" ?
Does your lens have a diafragm ring? Set this one to the maximum, for instance 22. Maybe this will solve your problem.
May 02, 2011 | Nikon D200 Digital Camera with 18-70mm...
The diafragm it´s closed not
I dropped the camera and got the same problem, until I read somewhere in this site that open the camera and then tapping on the ring around the lens while power on and off several times, it will work again. I did for me. I took it apart with phillips screwdriver and I used a hard rubber caulk spreader to tap it; it has some weight but will not damage the lens if its it by mistake. Try this and will be surprised. I am the 3rd person I have read that solved it doing this. Web ready Video is good in this camera. Good luck.
Oct 29, 2010 | Pentax Optio MX4 Digital Camera
I just replaced the piston ring on my poulan chainsaw it now has good compression but im not getting any gas to the piston area and if i shoot starting fluid to it. it dont even hit and try to start. i...
the engine is not sealed properly
check the gasket(seal glue)at crankshaft and other gaskets
check the carburator,clean it,inside there is a fine gas filter,check the needle,the diafragm,the fuel pump,the gas tube from the gas tank and the gas filter from inside the tank.
regards Mihai71
Nov 26, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Hagen Optima Aquarium Air Pump A-807 Logo
81 people viewed this question
Top Hagen Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you a Hagen Fish Expert? Answer questions, earn points and help others
