Question about Bosch 800 Plus Series SHX8ER55UC 24" Bar Handle Dishwasher With 40 dBA, 3rd Rack, ActiveTabtm
Drivers door latch - Bosch 800 Plus Series SHX8ER55UC 24" Bar Handle Dishwasher With 40 dBA, 3rd Rack, ActiveTabtm
How do I find door switch on 1995 Bonneville?
hi -door ajar switch is built into the door latch inside the door. The latch latches to the B pillar. It may be this switch or a wiring problem, or a bad drivers door module (DDM). Remove the inside door trim and check the wiring and connectors. The wires from the door switch are tan and gray/black and run to the 8 pin connector of the drivers door module. By peeling back the plastic shield, you can get to the wires for the door ajar switch at the latch. Disconnect the 4 pin connector at the latch. Test the radio now to see if it shuts off. If it does, the door ajar switch is bad.
Oct 04, 2014 | 1995 Pontiac Bonneville
Latch is locked door is open
if its a side(drivers) door latch pull the door handle and using a screw driver, insert it were the striker plate would be with the door closed and pull the latch claws out apart. then lube the latch mechanism really well.
Aug 28, 2014 | Cars & Trucks
Door latch stuck
Bend down on one knee and use one hand to hold the exterior door handle in the open position while using a screw driver to disengage the door latch by inserting the screw driver's tip into the anchor hole and push the screw driver outward towards the car.
Dec 22, 2013 | Cars & Trucks
Drivers side door wont stay shut in my 97 jetta
lube the latch up...
go to the passengers side and examine the latch... you could use a screwdriver and OPEN the latch on the drivers' door by pulling the door handle and prying the latch to the open possition... and try to close it ... repeate.
Mar 27, 2013 | 1997 Volkswagen Jetta
Latch on driver door is closed door will not latch closed
Pull the door handle and with a screw driver pry the latch to open at the same time.
Feb 27, 2011 | 1993 Chevrolet Lumina
Driver side door will not close may be a broken bolt how do i fix this
Seems as though your door latch may have closed without having the door closed.
1. Use a screw driver of any kind to simulate the door latch pin. Stick this into the latch and put a small amount of tension on the latch pulling it to the inside of the car and actuate the door handle.
What you are trying to do is get the latch to move to it open door position. It might help to look at one of the other doors latches with the door open so you can better see this demonstrated and compare with your malfunctioning door.
If this all works out - make sure you take the time to lubricate the door latch assembly to prevent future problems of this sort..
Jan 29, 2010 | 1997 Chevrolet Monte Carlo
Our driver's side door latch will not latch and close
I am taking a chance on this one because I am not sure if you mean the latch won't latch close or the door won't close. I base my answer on the door won't close one.....
With a large Philips screwdriver on the door insert the screw driver where the latch pin would be if it did close. ( You are trying to replicate the door latch post. Hold the driver there strong and have someone go thru the motions of opening the door. The screwdriver will lift the door lach up as the door is pulled away. Remove the screwdriver and close the door.
You have now just reset the latch towhere it should be.
The problem would have been the door thinks it is closedso the latch is down now. Follow the above and that resets it to be working.
hope that works for you; let me know please ash.
Jan 26, 2010 | 1998 Ford Windstar
My rear driver side door won't stay latched. If I get a latch from the junk yard for a 1995 Deville will a fleetwood door latch work? Also for the window motor on the driver side front door will they...
Have a close look at the door latch and see if it is in the lock position. If it is, pull the door handle like your going to open the door and place a screw driver or a pen in the latch and pull it open and then try to close the door and see if the latch holds the door close. The chances are good since most GM products are interchange able, the salvage Yard should answer that for you and can tell you better short cuts then any body on how to replace parts. Good luck and hope this helps, keep me posted. Be glad to help.
Jun 22, 2009 | Cadillac DeVille Cars & Trucks
2000 blazer door
The part in the door is called the Door Latch/Electric lock assembly,(If you don't have electric locks it's just called the door latch), The part in the door jam is called the striker assembly.
Jun 05, 2009 | 2000 Chevrolet Blazer
Bosch 800 Plus Series SHX8ER55UC 24" Bar Handle Dishwasher With 40 dBA, 3rd Rack, ActiveTabtm Logo
11 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
