Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
How to remove printhead - Kodak EASYSHARE 5500 All-In-One InkJet Printer
There's a problem with the printhead
Try this approach to fix the printhead problem:1. Open the printer cover > remove the ink tanks > open the printhead latch > remove the printhead > close the printhead latch.2. Visit the Lexmark website to download and install the Lexmark Pro700 Series Firmware Update.3. After the update is successful, open the printer cover > open the printhead latch > re-install the printhead > close the printer cover > if no error appears, continue with normal installation steps for cartridges. If error still appears, try to remove and re-insert the printhead firmly.
4. Try to print again to verify that the problem is fixed.
Should the error persist, it could be that the printhead itself is faulty. If that's the case, please contact Lexmark Technical Support for further assistance.
Feb 08, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
You just sent me a replacement printer and the instructions asked me to remove the printhead. I do not get insturctions on how to do this by going rto www.kodak.com/go/printheadsupport. I have removed...
Well, I don't think FixYa sent you the new replacement, but it was supposed to be sent by Kodak I guess. Anyway, here's the instructions on how to remove/install or in other words, how to replace the printhead.
  1. Verify that the printer is turned on and there are no error conditions.
  2. Open the printer access door and allow the printhead carriage to move to the center position.
  3. Remove the black and color ink cartridges.
  4. Disconnect the printhead by pressing the button in the upper-left corner of the carriage, then remove the printhead.nonontech_386.jpg
  5. Insert the printhead into the carriage.
  6. Place your thumb over the target label and push in firmly with your right thumb until you hear a loud snap.
  8. Insert the color ink cartridge into the printhead.
  9. Press down on the color ink cartridge until you hear it click into position.
  10. Repeat Steps 8-9 for the black ink cartridge.
  11. Close the printhead access door.
*Follow upto step 5 to remove the printhead, I just included the remaining steps for your information.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 09, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Unable to align cartridges on Canon Pixma MP600 all-in-one printer. When trying to print many black streaks obscure printed area.
This sounds like a printhead problem.
The first thing I would try is to clean the printhead. Remove the cartridges and store them (stretch a piece of plastic electrical tape over the ink cartridge hole to keep the ink from drying out).
Remove the printhead and set it in warm distilled water and let the printhead sit overnight.
Remove the printhead from the water and blot the water with a clean lint free dry cloth (do not rub the printhead and contacts, or damage could occur. Set the printhead aside to air dry.
Once the printhead is dry, reinsert the printhead, remove the tape from the ink cartridges, reinsert the ink cartridges. Test print. This should clear the problem.
We can try a more aggressive cleaning solution of the distilled water doesn't clear the problem.
Let me know if you have any more questions. Thanks.
May 18, 2011 | Office Equipment & Supplies
Replace print heads. How?
REPLACING HP PRINTER, PRINTHEADS
Follow these steps to replace the printheads in your printer.
  1. Press the Power button (c00636182.gif ) to turn on the printer.
  2. Open the top cover.
  3. Press and hold the Resume button (c01219285.bmp ) until the carriage moves to the left. CAUTION: Be careful not to proceed until the carriage is on the left side of the printer. If the carriage does not move to the left automatically, turn the printer off and back on and then try holding down the Resume button (c01219285.bmp ) again. The printhead can be damaged if the carriage is not all the way to the left for installation.
  4. Lift the printhead latch. Figure 3: Lifting the printhead latchc01290070.gif
  5. Lift the handle of a printhead and use it to pull the printhead out of its slot. Figure 4: Removing the old printheadc01295543.gif
  6. Shake the new printhead at least six times while the printhead is still in its packaging. Figure 5: Shaking the new printheadc01134519.gif
  7. Remove the new printhead from its package, and then remove its orange protective caps. Figure 6: Removing the protective capsc01134520.gif CAUTION: Do not shake the printheads after removing the orange protective caps.
  8. Insert the printhead into its color-coded slot (the label on the printhead must match the label on the printhead latch). Press down firmly on the printhead until it snaps into place. Figure 7: Inserting the new printheadc01290071.gif
  9. Pull the printhead latch all the way forward, and then press down until the latch engages. Figure 8: Closing the printhead latchc01290072.gif
  10. Close the cover. Figure 9: Closing the coverc01290073.gif
  11. The printer should align the printheads automatically in a few minutes, printing an alignment page. If it does not, go to the next section to align manually.
Align the printheadsIf you installed the HP software, use the instructions in the left column below. If you installed a Plug and Play driver or other driver, use the instructions in the right column.
Mar 05, 2010 | HP Office Equipment & Supplies
How do i remove old printhead and install new one
Replacing the printhead If your printhead is damaged or broken, you may replace it yourself.
  1. Make sure your printer is turned on.
  2. Open the printer access door by lifting from the recessed hand-holds on the sides of the unit. autourg00977009id2130369.jpg
    The printhead moves to an accessible position for handling the ink cartridges. The ink cartridges are seated in the printhead.
  3. Pinch the latch on the ink cartridge with your thumb and forefinger and lift it out of the print head. Remove both ink cartridges.
    caution.gif CAUTION:
    Insert the ink cartridges into the newly installed printhead as soon as possible to prevent any drying of the ink.
  4. Unlatch the printhead by lifting the rectangular latch on the top of the printhead.
  5. Remove the old printhead from the carriage .
  6. Remove the new printhead from its bag.
    Do not touch copper contacts on the printhead, as this may damage it.
  7. Remove and discard the black plastic casing and the orange protective cap.
  8. Place the new printhead into the carriage.
  9. Push firmly against the target label on the printhead until you hear it click into place.
  10. Re install the ink cartridges. As needed, see Replacing ink cartridges.
  11. Close the printer access door. The printer should now complete a printhead calibration to ensure that it is ready to for normal operation.
Nov 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Remove printhead
The User Guide (PDF installed on installation) has specific instructions, summarized below:
1 Make sure the EasyShare AiO is on.
2 Open the printer access door. The carriage moves to a center position.
3 Wait until the printhead is idle and silent, then pinch the pinch latch on the ink cartridge with your thumb and forefinger and lift it out of the print head. Remove both ink cartridges.
4 Unlatch the printhead by pressing the button in the upper-left corner of the carriage
5 Remove the old printhead.
6 Remove the printhead from its bag
7 Remove and discard the clear plastic casing and the orange protective cap.
8 Place the printhead into the carriage.
9 Push against the back wall of the printhead until it clicks into place.
10 Reinstall the ink cartridges.
And you are done!
Mar 25, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How do I remove old printhead and install a new one?
open the access door at the top of the printer
Remove the ink cartridges
Put your finger in the upper left corner of the printhead ( inside)
you will feel a small latch rigth there push it upward
the printhead will loose and you may now remove the printhead
Jan 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printhead problem (black/yellow) on HP L7780
When you removed the paper it's possible your damaged it and that's why the message is not going away. Did you try to put the cartridge back in to make sure it had not come out of position and just remove the power cord for a minute then plugging it back it.
Here are the steps to make sure you properly change the cartridges and the heads...
Install the ink cartridges and printheads Step one: Install the ink cartridges All four ink cartridges must be correctly installed for the HP All-in-One to work. Follow the steps below to Install cartridges:
  1. Open the ink cartridge cover.
  2. Remove each ink cartridge from its package.
  3. Align each ink cartridge with its color-coded slot and then insert the ink cartridge into the slot. To ensure proper contact, press down firmly on the cartridges until they snap into place.
  4. Close the ink cartridge cover.
Figure 1: Installing cartridges c00841893.gif 1 - Open the ink cartridge cover. 2 - Remove the ink cartridges from the packages. 3 - Install the ink cartridges. 4 - Close the ink cartridge cover. Step two: Install the printheads Follow the steps below to install the printheads.
  1. Open the top cover of the printer. Figure 2: Open the top cover c00848391.gif
  2. If the carriage does not move to the left automatically, press and hold the Resume button (c00847980.gif ) for three seconds. Wait for the carriage to stop moving.
  3. Remove the cardboard cover from the printhead carriage. Figure 3: Remove the cardboard cover c00848392.gif
  4. Lift the printhead latch. Figure 4: Lift the printhead latch c00848393.gif
  5. Before installing a printhead, shake the printhead up and down at least six times while the printhead is still in its packaging. Figure 5: Shake the printhead while it is still in its packaging c00847983.gif
  6. Remove the new printhead from its package, and then remove its orange protective caps. CAUTION: Do not shake printheads after the caps are removed. Figure 6: Remove the printhead from its packaging, then remove the orange caps from the printhead c00847984.gif
  7. Insert the printhead into its color-coded slot. The label on the printhead must match the label on the printhead latch. Press down firmly on the printhead to ensure proper contact. Figure 7: Insert the printheads in the correct color-coded slots c00847985.gif
  8. Pull the printhead latch all the way forward, and then press down to ensure that the latch is properly engaged. You might have to apply some pressure to engage the latch. Figure 8: Close the latch c00848394.gif
  9. Close the top cover. Figure 9: Close the top cover c00847987.gif
Step three: Align the print heads Whenever you insert or replace a printhead, the printer automatically aligns the printheads to ensure the best print quality. If the printer does not print the alignment page automatically, start the alignment process manually. To start the alignment process manually:
  1. Press the Setup button on the control panel Setup and the number 6 on the keypad or scroll to Tools .
  2. Press 4 on the keypad or scroll to Align Printer . The alignment process starts.
Dec 01, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Error message re printhead.
To resolve the error condition:
  1. Open the printer access door.
  2. Remove the color and black ink cartridges.
  3. Remove, then reinstall the printhead
To reinstall printhead follow the link.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Nov 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Need instructions for putting in a new printhead
Hello ahieser,
To remove the old printhead, you need to remove the ink cartridges first. And then remove the printhead by pushing the button at the top of the printhead while disengaging it from the carrier.
^_^
Nov 12, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
35 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
