My canon mp 230 keeps slamming to one side
Changed my rollers,fitted back the printer but it keeps slamming to one side
SOURCE: reset my printer canon pixma mp 160
reset-mp160
Posted on Oct 28, 2008
komguy
  • 2306 Answers
SOURCE: canon printer mp 510 error 5010
That is a purge system error, either you need a new purge assembly or there is a paper scrap caught in there stopping it. The purge unit is on the right where the printhead parks at shutdown and where the printhead is cleaned.
Posted on Aug 25, 2009
Soulvisitor
  • 1113 Answers
SOURCE: The cartridge bay goes crazy and slams both sides
Clean encoder strip, thin plastic strip runs width of machine pararell to silver scan rail. Ensure it is running threw carriage smoothly otherwise the light that read it is dodgy, this will be unecomical to fix unless dirty strip
Posted on Nov 07, 2009
Testimonial: "Thank you very much, I took it apart, cleaned everything thouroughly, and so far its working. "
  • 49 Answers
SOURCE: The paper keeps jamming on my Canon imageclass
this will tell you if its a toner problem:
http://www.quikshiptoner.com/catalog/canon-mf6590-toner.html#When_to_Replace_the_Toner_Cartridge_in_a_Canon_imageCLASS_MF6590_Printer
Posted on May 26, 2012
Error clear paper jam at my pixma MP 780what can I do?
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Apr 21, 2011 | Canon PIXMA MP780 All-In-One InkJet...
I have a Brother HL-5250DN printer and trying to replace the Paper Feed pickup roller assembly. Can you tell me how to take the old part out or send a diagram? Thanks, Sherry
Paper feeding kit for MP tray
(1) Disconnect the AC cord from the Printer.
(2) Press the front cover release button.
(3) Open the Front cover.
(4) Remove the Drum/toner ASSY.
Open the MP feed frame cover. (6) Remove the Holder bearing MP. Lift up the Lift arm MP to release it from the Pin of the MP roller holder ASSY. (8) Slide the MP roller holder ASSY to the direction of the arrow 8a and put it up to remove. Fig. 3-77 (9) Turn the back side of the Separation pad ASSY MP to the direction of the arrow 9a and put it up to remove. Fig. 3-78 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame Lift arm MP 7 8a 8b MP feed frame MP frame 9b 9a
(1) Put the Hook of the Separation pad ASSY MP into the MP feed frame and pull down the Separation pad ASSY MP to the direction of the arrow 1b until it is locked. Fig. 3-79 (2) Lift up the Lift arm MP and put the MP roller holder ASSY into the MP feed frame. Put the Pin of the MP roller holder ASSY into the hole of the Lift arm MP. Fig. 3-80 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame MP frame MP feed frame Lift arm MP
(3) Put the Holder bearing MP into the MP feed frame and turn the Holder bearing MP to the direction of the arrow 3c to lock. (4) Close the MP feed frame cover. Holder bearing MP Hook MP feed frame cover Front cover MP feed frame 3a 3b 3c MP feed frame(5) Install the Drum/toner ASSY into the Printer. (6) Close the Front cover. (7) Connect the AC cord into the Printer. Printer AC cord Drum /toner ASSY Front cover .
Mar 18, 2011 | Brother HL 5250DN Laser Printer
Paper is jammed--how can i release roller to access the paper
ASF paper feed
roller cleaning
- When paper does not feed properly.
- When the front side of the paper is smeared.
To clean the paper
feed rollers.
- Machine buttons
- Computer (MP driver)
2 min.
Oct 08, 2009 | Canon Office Equipment & Supplies
Canon MP 510 paper jam
I had the same problem and found a small coin in the back feeder. Remove the back coverplate and tip the machine onto its back and give it a good shake. You might be surprised at what falls out.
Apr 30, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Paper wont go through
It should the roller problem end life or hardly use.
2 solution.
1. find corect part then buy it fix it (cost too much more than your printer market value) 2. Do it by yourself change the side of the rubber it will work again. (no cost but need experienc with apart printer cost around 20-30mins if the experts deal with.)
Apr 28, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
How to open to change ribbon on a Canon mp25dv
Remove the paper tape by pulling it back out of the calculator.
Feel along the back of the calculator right below where you insert the paper tape for a ridge. Gently lift up on this ridge and a plate will lift out of the machine exposing the ribbon.
Make a note to yourself as to how the old ribbon is in the machine before removing the old ribbon. Just gently lift straight up on both of the spools and the ribbon will lift out of the machie.
When you insert the new ribbon make sure that the ribbon is feeding off of the back side of both spools. You can use a small screwdriver or toothpick etc to position he new ribbon to keep the ink off of your fingers. Make sure the new ribbon feeds around the plates on both sides of the machine and it fits behind the roller that has all the numbers on it and that the red portion of the ribbon is on the bottom.
Take the plastic plate that you removed first and insert the tabs in the front underneath edge of the case on the front and gently push the back side of the plate straight down till it smaps into place.
Refeed the paper tape back into the machine and you are finished!
Hope this helps.
Apr 20, 2009 | Canon MP-25DV Calculator
I have canon PIXMA MP
E3 error on the MP150 is a paper jam error. Make sure that there is nothing obstructing the paper going into the printer and that the feed mechanism doesn't have anyhting in it. Also run a roller cleaning from the printer software.
Nov 23, 2008 | Canon Office Equipment & Supplies
Canon MP 830- roller replacement
yeah dependin what rollers you require. depending if you can find a canon delaer who will suplly the part and fit it.
I have contacts in the ul if you need to find out more
Oct 12, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP 800 printing Issue (heavy black line on opposite side of print page
problem is when the printer does a head clean dumps large amount of black ink on to rollers. Replacement head is almost £100 and not certain to fix fault
Apr 12, 2008 | Canon Pixma MP800 All-In-One InkJet...
19 people viewed this question
jasbo
jasbo
