Question about Maytag Admiral AAV7000A
The admiral washing machine works fine except on the spin cycle it wabbles wildly, like the clothes are loaded on one side. but does it even while washer is empty
  • vannahrachel Jun 23, 2009
    how do you center the snubber ring?
  • Maytag Master
  • 8,220 Answers
At its best this washer is a beast in the spin cycle. The machine must be mounted on a cement floor. It is written in the unpacking instructions. Check all springs, machine must be level. If all checks out replace snubber ring or adjust by centering snubber ring Mounted unde the transmission base.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 22, 2009
  • Dan Webster
    Dan Webster Jun 23, 2009
    Raise the base with a crow bar and wiggle the snubber till it is centered.
I have an admiral top load washing machine, when the spin cycle starts the machine makes this loud banging noise like it’s fixing to break through the sides.
You might be overloading it or the clothes are not evenly spaced or it might need to be leveled. If none of this works I will need more info to give better ideas..
Nov 14, 2017 | Admiral Washing Machines
When my admiral washer spins it sounds like the tub is whacking the sides
Hopefully it is a unbalanced load . take some items out.Redistribute the load evenly,you may have put in more that the washer should handle. Clothes should be able to move evenly through out wash. Bulky items usually cause an imbalance.
Jul 26, 2015 | Admiral Washing Machines
Balancing problems with the spin cycle
Redistribute clothes in the tub. It may take several tries. If this doesn't resolve try it with just water and no clothes load. Still doesnt resolve, there may be an issue at the upper bearing load carrying or bearing adjustment surface. A slim possibility there is something under the spinner tub, but that would interfere with the tub reaching spinout speed.
May 25, 2015 | Admiral Washing Machines
Drum wabbles more than normal. Balance
move the cloths around to balance the load better or put less in the machine
Aug 24, 2009 | Amana LW8203
Washer does not work well on spin cycle admiral aav7000aww
No you need to check ur clutch, u can check it by running the spin cycle for a few minutes then shut it off and turn machine up so u can look under it. get a spray bottle with cold water and alil soap detergent, then spray the clutch with it, if it shows or steams up or sizzles then the clutch is slipping and bad. the cluth is in the center near the tranny, should look like a round siver pc of metal about 5 inches in diameter
Jul 18, 2009 | Admiral AW22 Top Load Washer
Admiral washer, spins too slow so clothes are still soaked
The clothes being wet and the drum spinning slow are probably due to a worn belt, tilt the machine back and the belt can be removed and replaced from below with no tools.
If the machine is constantly filling with water the level pressure switch requires changing. Isolate the machine, use a knife or thin bladed tool and insert between the front panel and the top panel approx 4" from each side to release the clips, the top should lift up, the pressure switch i at the back LH side, you will see a small pipe attached to it from lower down the drum, replace the pressure switch pull off the terminals and the hose and replace using the same order of connections.
Apr 14, 2009 | Admiral AW22 Top Load Washer
Admiral is not spinninng
i would say the simple soulation to this is get the main belt tightened.sounds loose???.hope this helps.adrian
Jan 31, 2009 | Admiral AW22 Top Load Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
GE WSM2780W Stacked Washer spin cycle
With no clothing in the wash tub take the following steps:
1. remove the front cover from the wash tub
2. run a full cycle of laundry and observe the tub's behavior
Potential Solutions:
A. If the tub begins to shake wildly during a full wash cycle with no clothing in it then you will need to adjust the 3 large springs on each side of the tub until the unit is working in a more-balanced position. This is simple to do by hand. If the tub appears to be shaking too far forward, then unhook the 2 large springs in back so they are tighter. Then run a full wash cycle again with no clothing.
* note: there are smaller springs too - you don't have to adjust these to fix your issue
B. If the tub works fine with no clothing during a full wash cycle, then try to load your clothing in a more balanced fashion. For example: if your wash load is only a small kitchen or bath rug then when the unit spins it will spin off balance with a wet & heavy item on only one side of the tub.
C. If you'd like to replace the 3 large springs, I can get you the part numbers. There are specific springs for both sides of the wash tub and they are different part numbers. The full replacement of the 3 large springs can be done by hand.
thanks,
Chris I.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_6ddd78f70d3cfe52
Sep 24, 2007 | GE WSM2780W Stacked Washer / Dryer
Machine not spinning due to uneven load balance although clothes are loaded evenly initially
I suggest you stick to the maximum load capacity (or less) of the machine; and not over-load the machine with clothes.
Apr 14, 2007 | Haier XQJ50-31 Top Load Washer
Maytag Admiral AAV7000A Logo
320 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
