Question about Kenwood Multi Pro FP730 Food Processor
How do you remove the centrifuge base of Russell hobbs juice sensation?
Instruction manual for 32-Piece Russel Hobbs Food Processor with Blender. Model: RHFB044
Try googling (Russell Hobbs)(RHFB044)(manual) without parens.
Apr 18, 2018 | Food Processors
Have lost the spindle to. Put blades on my Russell Hobbs food processor model no Rhfp 600 . Do you have the. In stock
As this is not the Russell Hobbs website we do not as we are not sellers nor service supplier for products .
Aug 27, 2017 | Russell Hobbs Food Processors
Do you have replacement bowls for Russell hobbs food processor ?
Hi Josephine:
Fixya is not a retail store that actually sells stuff.
We mostly give free advice.
Soooooooo.....
I'd suggest that if you can't get the bowl you need through whomever sells the units, you could try checking with a thrift store (such as the Sally Ann or local hospital auxiliary) to see if you can find the appropriate sized bowl.
Cheers
Jun 28, 2016 | V_Wellcome Russell Hobbs 19000 Desire 600W...
I have a salton food processor model #FP-25 and I need too replace my lid. Can you help me
This was manufactured a number of years ago by Salton, Inc. which changed its name in 2009 to Russell Hobbs, Inc. which was then purchased by Spectrum Brands in 2010. Typically these low-end consumer products are not carried for more than a couple years and finding parts after these company changes is unlikely.
Nov 29, 2014 | Salton Food Processors
Russell Hobbs RHFB 044
Where can I get the manual for a Russell Hobbs processor RHRB 044?
May 21, 2012 | Food Processors
How do i use centrifugal juicer?
The Instruction Manual for the Kenwood FP730 Multipro Food Processor can be found online here:
http://www.kenwoodworld.com/Global/Instruction%20books%20(User%20manuals)/Food_Processors/57832%20Iss%203%20B5%20FP730%20English%20only.pdf
On page 7 you will find illustrated instructions for the assembly and operation of the centrifugal juicer.
Dec 03, 2011 | Kenwood Multi Pro FP730 Food Processor
Cusinart little pro plus
I have this food processorfor years and I love it. If you need a copy of the manual go to the Cuisinart website - they have all of the maunals listed there. But, here is the instructinos for the juicer. Good Luck. Using The Juicer
The Citrus Juicer
Attachment includes:
Strainer Basket, which
locks into processor work
bowl. It has grooved cam
on one side and smooth
locking device on opposite
side. In its center is the:
Juicer Stem Adapter,
which fits over motor shaft
of Pro Plus™.
Small cone, for lemons
and limes. It must always
be attached to Adapter
when Attachment is in use.
Slot in center of underside
fits rib on Adapter.
Medium cone, for oranges
and large cone, for grapefruits.
Both fit over small
cone.
1. Place work bowl on Pro
Plus™ base in usual way.
Hold Strainer Basket
open side up, with
locking device facing
you. Align locking device
slightly to left of locking
tab on front rim of work
bowl.
Place strainer basket on
work bowl, fitting Juicer
Stem Adapter loosely
over motor shaft. Turn
basket counterclockwise
as far as it will go, until it
clicks into position.
Turn Juicer Stem
Adapter clockwise until it
drops into position.
Check that it is down as
far as it will go on the
motor shaft.
2. Hold small cone by top
and place it over Juicer
Stem Adapter, fitting slot
over rib on adapter.
Cut citrus fruit in half and
hold cut side down over
cone. With other hand,
hold control lever in
PULSE position and
press down fruit to
extract juice. For continuous
operation, move
control lever to ON. Twist
fruit to extract most juice.
Do not allow juice to
overflow center tube of
work bowl.
To remove attachment,
remove cone from Juicer
Stem Adapter. Loosen
adapter from motor shaft
by lifting it slightly, straight
up. Hold Strainer Basket
on both sides and turn
clockwise to unlock it from
work bowl. Lift straight up.
Remove work bowl from
base and pour out juice.
Feb 03, 2008 | Cuisinart DLC-5 Food Processor
Kenwood Multi Pro FP730 Food Processor Logo
Top Kenwood Food Processors Experts
Ross Keen
Mitch Vass
Mitch Vass
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
