Question about Smeg SUK91MFX5 Dual Fuel (Electric and Gas) Kitchen Range
DOOR NOT CLOSING HINGE SEEMS BROKEN - Smeg SUK91MFX5 Dual Fuel (Electric and Gas) Kitchen Range
Why won't my hinged cupboard door stay closed?
Depends on type of hinge, If it swings back open after you closed it then either the cupboard is not level (old style hinge)...
Or the spring inside hinge is bad/broken and not holding it closed. If the door opens back just a bit (1/2 inch or so) see if hinge has adjustable screws.
Oct 15, 2016 | Top Knobs Hardware & Accessories
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
How do I close the door to my printer? It seems that one of the hinges is broken apart.
If it's broken, you can't get it back together and your prrinter won't work with "door" opem look for the sensor which indicates that door is open, stick it somehow so it should show door closed and used happily forever your printer. If this trick is not possible, no way, take your printer to an HP repair center and get installed a new door.
Aug 27, 2015 | HP Officejet 6310 All-In-One InkJet...
How do I repair/replace a broken door?
Hello there, you will need a new hinge and probably the inside round piece of the door. Can you upload a photo? Please indicate the
E-Nr of the machine. You can find it on the label around the door and/or at the back of machine.
Jul 02, 2015 | Bosch Washing Machines
Door open warning
Yes, the doorjam switch is either shorted or broken. This switch is on the cabin door opening by the hinges. In rare cases the pin may be self adjusting. Sometimes you can press in the pin by hand to see if it shuts off the interior light. Do not slam the door with your finger in the hinge area.
There may be a problem with the door adjustment or the hinge may be broken and you do not know it. It can be a lose or broken wire inside the cabin shell.
Feb 12, 2012 | 2004 Mercedes-Benz C-Class
RIGHT REAR HINGE ON CARTRIDGE BAY SEEMS TO HAVE POPPED OUT, RENDERING THE PRINTER UNABLE TO PRINT (LID WILL NOT CLOSE ALL THE WAY ON RIGHT SIDE).
find the switch where the door presses to tell the printer its closed.
find something to press that when you want to print then remove it when you have to swap cartridges
May 05, 2011 | Computers & Internet
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Broken door hinge
Its not hard at all,Just losen all the bolts an the door would well, fall of :)
Just check if the fridge dit not get hurt or the door,other wize go for it....
Good luck.
Sep 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchen aid superba side by side doors slam
sounds like a door closure is broken on refrig door, a 2 part door closure(cam). look under door where sits on hinge, freezer door should have as well(use for comparison as to broken or not)
Feb 17, 2008 | KitchenAid Superba Architect KSCS25INSS...
Smeg SUK91MFX5 Dual Fuel (Electric and Gas) Kitchen Range Logo
20 people viewed this question
Top Smeg Kitchen Ranges Experts
Richard Ballard
Richard Ballard
Level 1 Expert
Joseph Mueller
Joseph Mueller
ashburton
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
