Question about TouchStone Turok
My game won't sign on to online server.
I select public or quick match and it waits for 3/4 seconds and then says it cannot sign in? my internet connection is fine and my other games are good. ive played online once and llast lost signal half way through. please hellp
Have a problem wene i go to play turok on line it say server cant connect.yet i opened another another accont it no problem , how do i sort this problem out please help will.
Posted on Jun 29, 2009
I cant do profile pls explain again plzzzzzz
Posted on Mar 16, 2011
I can not join a game with a friend. Others can join but we can not. Y
one thing you guys can both do is turn off your system then turn off your router for 30 seconds; turn router back on then turn ps3 back on and try reconnecting with each other. if this doesnt work make sure both of you have open NAT types. Hope it helps.
Oct 07, 2012 | Ubi Soft Entertainment RUSE for...
How do i forward a port i want to play call of duty black ops but i cant find an online game, the game website says to forward these ports, TCP [80] UDP [88, 3074, 22728, 33233] but i dont know how to...
http://www.netopia.com/support/hardware/technotes/NQG_025.html
Server List (Port Forwarding) NQG_025 With NAT enabled, the IP addresses of nodes on your LAN are private since they are hidden from the Internet. IP Servers let you pass specific types of network traffic through the Netopia router's NAT interfaces. Once configured, selected types of network traffic, such as FTP requests or HTTP (Web) connections, will be forwarded to a specific host or server behind the Netopia router. Please Note: From the LAN (Local Area Network), you will also be able to access the servers that are responding to requests from the internet, but only using the internal private IP address. Access via the public IP address is not supported from a local ethernet connection. If your ISP is routing you multiple public IP addresses, you can also configure the router to forward all ports in one public IP to a designated private IP address on your LAN via Easy PAT List entries. For those instructions, see Quick Guide NQG_024: IP Mapping (Address Forwarding).
Please Note: If your router is currently running Netopia Residential Firmware with a web "GUI" configuration menu, this technote is not applicable to you. Most 3300 Series Netopia Gateways can be upgraded to Enterprise level firmware. Click Here! to purchase the upgrade key.
Related documents: NQG_039 NAT and the Basic Firewall
Firmware References:
  • v8.2 R1 (and up) - 3300 Enterprise Series
  • v5.3.7 (and up) - 4000 Series
  • v4.8.2 (and up) - R-Series
Before You Start
Telnet into the Netopia router's Main Menu at 192.168.1.1 (if using the default IP setting). If your network has a different IP addressing scheme, modify this accordingly. Click Here! for instructions on using telnet and Hyperterminal (serial connection).
Login with the user name and password. The Superuser login is required to save changes. If you are unsure of this, contact your network administrator.
Don't forget to press the Enter key to save any entries. Hitting the back space, delete or tab without first hitting enter will undo any changes.
The Esc key will take you back towards the main menu screen.
Once you have completed your configuration, you should reboot the Netopia to save and apply your changes.
The Netopia Main Menu Interface
Server List Configuration
  1. From the Main Menu of router console screens, go to Quick Menus, and select Network Address Translation.
  2. Select Show/Change Server List.
  3. Select Easy-Servers.
  4. From the Show/Change NAT Server List screen, select Add Server.
  5. Select Service and the service and port you want to allow. If your service and port are not available in the pull-down menu, select Other. Selecting Other will allow you to enter a specific service port or a range of ports since fields are provided for both a First Port Number and a Last Port Number. To allow a specific service port, the First Port Number and Last Port Number should be the same. Select Okay.
  6. Next, enter the Server Private IP Address, or the private IP address of the host/server you are forwarding the service to, and the Public IP Address you want to associate with the same host/server. This value can be left set to 0.0.0.0 if you are using the WAN IP as the Public IP address. Note: If your ISP is routing you multiple static IP addresses, other then the one used for Internet access, you may create more than one server for specific service as long as all servers have a different Public IP Address specified. For example, with two web servers on your LAN you would need to create two Server List entries for TCP 80 (www-http). Since each specific port (service) can only be mapped once using any given Public IP Address, a distinct public address must be used for each TCP 80 server list entry. It is not necessary for you to specify more than one Local WAN IP Address or Public IP Address in your router's configuration. As long as you are connecting to your ISP via a public IP address used for NAT, they are responsible for routing all other IP addresses via that connection.
Conclusion
You have now configured your router for TCP/UDP port forwarding. If you have a switched connection (ISDN or Analog), you will need to either disconnect and reconnect your Internet connection, or restart your router for the Nat Server List changes to take effect. If you wish to filter traffic for your static IP mappings, please see the following Netopia Technote:
NQG_039: NAT and the Basic Firewall
Nov 12, 2010 | Netopia CAYMAN 3387W-ENT CABLE/DSL...
Error creating session. wind i go online or multiplayer willnt read or go online
Hopefully this will help solve your problem:
1. Press and hold down the power button located at the front of the PS3 console, until you hear a first beep, then eventually a second – before the console shuts down, then let go of the button;
2. Now press and hold the button again until you hear a first beep, then a second beep then eventually a quick double-beep, then let go of the button;
3. The TV screen should now display a six option menu, where you can select what’s required, i.e. `Restart System`, `Restore System` etc. `Reset System` should only be used after other attempts with the other options, as your game saved data may be lost. If you play Modern Warfare 2 online, then this won’t be affected as your data is saved on the Sony Server.
4. During any of the above actions, your best having your handset controller connected to the PS3 via the USB cord, which includes pressing the `P` button when required (located between `Start` and `Select`).
These actions should help solve `freeze` problems and others such as update errors etc – which restrict you starting up or playing your console.
Don’t hesitate to contact Sony UK if required, who are very helpful. Their UK number is: 0844 7360595
Good Luck!
May 17, 2010 | Activision Call of Duty Modern Warfare 2
Randomly Signs me out of Playstation
It usually means your internet is to slow if you have satillite internet then it wont work.
Feb 14, 2010 | Sony Playstation 3 (PS3) Console
Cant connect to online game servers
Check your online gaming server to see what ports or sites need to be opened up. The RTFM, Read The Flippin' Manual. Here's a link to the manual for your router.
http://www.zhone.com/support/manuals/docs/62/6218-A2-ZB23-10.pdf
Good luck! :)
Sep 23, 2009 | Zhone (6218-I2-200) Router
SONY PS3 how fix the error 80028E01
error code just means that Sony is having server issues. wait 30 min and try again. sometimes they get bogged down on release dates of games.
or
One solution that worked for me:
When trying to get online you may get an error 80028e01 .
What I did was try various DNS server addresses until one WORKED!
Look here:
Free fast Public DNS Servers List
http://theos.in/windows-xp/free-fast-public-dns-server-list/
I used:
Service provider:dnsadvantage
Dnsadvantage free dns server list:
  • 156.154.70.1
  • 156.154.71.1
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
Game server and my IP address
First option is to forward ports where your friends can connect to. The second option is to put your computer in DMZ. These options can be found on the router settings.
Jun 17, 2009 | Apple AirPort Extreme Wireless-N Wireless...
Cant connect to ea servers mercs2 ps3 I am on psn signed in it says cant connect to ea servers
I've just fixed this problem...
We bought a 2nd ps3 with mercs2 yesterday and had the same problem on the new system, even when using the other copy of mercs2 from my original ps3.
This 100% worked for me;
I loaded battlefield, bad company on the new system and accepted EA's online terms.
Then i started a quick game multiplayer match (don't be surprised if it doesn't connect 1st time as that occasionally happens anyway).
Then i quit bad company, banged in mercs2 and "jus like that" the freeze is gone and you can play online.
I have also read that this works with army of two also but i can't confirm that.
Have fun!!!
Apr 18, 2009 | EA - Electronic Arts Mercenaries 2: World...
Playstation 3 online problems
Firstly if you connect to the PSN via wireless router, the router maynot be able to cope with the BIT rate that is needed to play the game.
My suggestion is:
- That you are hard wired to the internet - i.e connected via a modem cable.
- Go to your ps3 system menu and check the internet connection.
(the PS3 will now check IP address etc and say that is enabled)
- If this is the case (which it should as you can connect to the internet browser)
- This time disconnect the modem cable and turn off the PS3 (in that order).
- Turn on the PS3.
- Carry out system check it will be unable to give a success as your not connected.
- Once complete reconnect cable and ensure that wired connection is selected.
- Carry out check again.....success should be shown.
(the reason you do this is to get both PS3 and server to communicate as if they have never met before so it sets up a new partnership)
- Insert Disc and Enjoy
- I hope this has helped????
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Can't play online
I know on a game i had, It had 2 separate logins, you first log in to the PS2 Network, THEN log in to the EA network, Its frustrating indeed but once your logged in twice, you can play.
Nov 24, 2008 | Sony PlayStation 2 (PS2) Console
TouchStone Turok Logo
319 people viewed this question
Top TouchStone Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a TouchStone Video Game Console and Game Expert? Answer questions, earn points and help others
