Question about Holman Kitchen Appliances - Others
Why conveyor stoped in 10 min - Holman Kitchen Appliances - Others
2 Suggested Answers
  • 205 Answers
SOURCE: Compressor run 10 min then
OK I am guessing this is a modular drive. Fault 39 is an IGBT fault on phase U and 40 is an IGBT fault on phase V. Unless you are experienced it's best to have a qualified service tech do the repair. However here are my thoughts. The IGBT fault may be caused by a dirty air filter located in the side panel. It's some where around 10" x 12". If the electrical panel filter is dirty you don't get enough cooling. The IGBT's get hot and over temp. causing the above fault codes. Check the filter and replace if needed. Next in top of the electrical and drive compartment is a fan. Make sure it is operating properly. If the fan is not operating again you get no cooling air for the IGBT's. I have seen customers open the panel doors and put a large fan blowing on the drive to cool it. I don't recommend this due to the fact the air is unfiltered and can get dirt into the drive and cause damage!. However some customers have to run and take the chance. There are also other items that can cause these faults. But as I said before determining whats wrong can be very technical. Does the display show any other # after fault 39 or 40 like 39 - 3 or 40 - 2. If so this gives additional info on the fault and tests to perform like checking the ID board or interface board. Good luck hope it's a filter.
Posted on Sep 08, 2011
My samsung blu ray home theather does not play blu ray dvd''s, first time that i used it, it did played like for 10 min long, but then the image stoped and did not wanted to play any more, i t
Players often when the optical pickup in them is either dirty or beginning to fail will first have problems with blu rays because of technical standards are much more refined for the blu rays.
Apr 23, 2012 | Samsung BD-C6900 Blu-ray 3D Player
Engine starts and stops ticking
Sounds like oil pressure problems to me. Check to make sure your oil level is correct. If the oil level is OK get the engine checked by a professional.
Mar 24, 2012 | Chevrolet S 10 Cars & Trucks
Compressor run 10 min then stoped with VSD Fault39,or 40. I can reset, but the compressor run only after 30-45 min. He run another 10 min,then stoped again
Sep 08, 2011 | Ingersoll Air Tools & Compressors
My 800DX car not starting when it is hot i.e. after driving 15 to 40 km it does not start. After cooling for 10-15 min it starts normaly.
If the car is dieing on you as you drive and it has to set a bit, Most likely your fuel filter is stoped up. As you drive it stares up all that crud in the filter and the suction will pull all sedaments untill its stoped up. once it is turnd off the pressure is released and always the sedaments to settle untial you try to drive again
I hope this is helpfull
Nov 28, 2010 | Mahindra Scorpio Cars & Trucks
Dacor Preference range oven stoped working
You can try turning the breaker off to the unit for 10 minutes or so but if that does not work you will need a new control board to fix it. they usally range from 100-200 dollars.
Let me know if you have any other questions.
Phil
Apr 10, 2009 | Dacor Preference RSE30SS Electric Kitchen...
Have a apw wyott conveyor toaster, conveyor randomly stops
I had a similar problem I changed the Rear Bearings in the belt & Check the Fan motor in the rear which houses the conveyer Motor wheather it is working or not it could be the fan not working and over heating the motor the last thing is the screws that hold the conveyer motor are too tight as the motor is self adjusting.
Jan 17, 2009 | APW Wyott AT-Express Conveyor Toaster
Fridge is cold but always runs.
CHECK THE DOOR GASKETS ON THE FREEZER AND FRIG.,IT SOUNDS LIKE THERE IS A AIR LEAK SOMEWHERE,LET ME KNOW-MIKE
Nov 01, 2008 | Refrigerators
My ps3 keeps stoping after about 10 min
put in frezzer 4 2mins only put in bag
May 06, 2008 | Video Game Consoles & Games
Proline plc218w not freezing
Try unplugging for 10 Mins and then Plug it Back in see if That works Tech
Jul 19, 2007 | Kenmore 56722 / 56724 / 56726 / 56729
Kitchen Appliances - Others Logo
Top Holman Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Holman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
