Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Reset konica minolta c35
Manually reset waste toner full
  • Konica Minolta Master
  • 6,680 Answers
First replace the waste toner box you do not reset.
Posted on Dec 29, 2015
early1234
  • 871 Answers
SOURCE: Konica Minolta 2300DL waste box full message
remove the waste box you'll see blue knob and above there is a sensor now take a look at the waste box and find the place what goes between the sensor. you should cut off one side and clean the other sides and then use some invisible tape to fix the hole. and try again.
Place what goes between the sensor have to be clean. its not good idea to cut or remove the sensor at all because next time the box will be full you don't know that and it will brake your printer
Posted on Mar 22, 2008
Kevin Hayes
  • 167 Answers
SOURCE: C250 Waste toner
Actually you are supposed to replace the whole container.
You can order this as part of your service contract just like toner, the cost would be included.
If you are shaking it out, be aware it is VERY flamable in such a fine powdered state.
Posted on Jun 06, 2008
  • 34 Answers
SOURCE: how do i replace the
When you open the door to access the toner and waste toner area, you will see a letter "K" on the left side of the waste toner box, and a thumb screw on the right side of the waste toner box. Immediately above the letter "K" there is a raised area in the brown plastic housing. It is between the blue toner cartridge, and the waste oner box. There is a second raised area 2.5 inches at a 225 degree angle below the thumb screw on the right side of the waste toner box.
If you will place your thumbs on the raised areas and your forefingers on the white plastic rear cover of the waste toner box immediately below the raised areas and squeeze your fingers towards your thumbs, the waste toner box will come forward at the top of the box. You can then lift the waste toner box up and out of the printer.
Please squeeze carefully if you think your waste toner box is close to full as you may inadvertently find waste toner all over the place.
The two blue caps on the back of the waste toner box are to keep the waste toner in the waste toner box instead of your carpet.
Installation of the new waste toner box is the reverse of the above procedure. The new waste toner box almost snaps in place.
Here in California waste toner is considered a hazardous material and must be disposed of properly.
Posted on May 14, 2009
  • 214 Answers
SOURCE: need to reset admin code for konica minolta c-350
Hello
press utility/counter - then under the counter "details" - stop 0 0 stop 01 - now you are in service mode, - stop 0 C, and there shold be admin pwd
Posted on Oct 14, 2009
SOURCE: Waste bottle full...can i empty it and how??
Don't be conned out of your money by Konica or any salesmen. The waste bottle can easily be emptied. There is no sensor that 'gets tripped and can't be reset' this is bull*&%t. Just take the cartridge out. Go somewhere that you can dispose of the toner (make sure it's not windy !) then turn it to the 'locked' position. This opens the port, then just shake the thing back and forth for a few minutes. You can feel getting lighter. Then turn back to unlocked. Use a vacuum to remove toner from outside of cover, then a soft cloth or wipes to get it clean. Then put it back in.
Posted on Feb 28, 2010
Waste toner bottle full so replaced but will not reset and says still full
then the clear section of the waste toner bottle is not clear some toner is left blocking the sensor that monitors the waste toner level
Apr 02, 2014 | Konica Minolta New Bizhub C25 Color Laser...
Mar 22, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica minolta bizhub c35 black toner being recognized as empty
sir/mam replace the cart then might have gotten a bad one from the store
Mar 11, 2014 | Konica Minolta bizhub C35 Black Toner...
Bizhub c35 new cartridge being recognized as empty
Biz hub c35 remove waste toner botle
located below the image unit follow instrution and replace
Feb 04, 2014 | Konica Minolta bizhub C250 All-In-One...
Waste toner full
The waste toner collection box is located before the imaging unit,open the front door observ a black box,pull out and clean very very good,because in rear part of box is located one transparent window,if is not clean after assambled the box a copier say waste toner box full.
Apr 29, 2013 | Konica Minolta Bizhub C35 Multi-Function...
HI, Does anyone know a clearance for a Konica Minolta Bizhub C35 with error code 0F52, thanks
Yellow Toner Sensor malfunction. Check connectors on PRCB, inspect/disassemble/reassemble/reinspect yellow toner sensor assembly, or possibly replace PRCB.
Source: service manual.
Credentials: I am having this same code right now.
Feb 17, 2012 | Office Equipment & Supplies
WHERE IS THE WASTE BUCKET ON PRINTER KONICA 4690MF
Found this on the support site
When the waste toner bottle becomes full, the message "WASTE TONER
FULL/REPLACE BOTTLE"
Konica/Minolta Support
Go to "Ch. 7 replacing consumables" > "Replacing Consumables" > "Replacing the Waste Toner Bottle" this is found on page 165 of the user guide. This walks you through replacing the waste toner bottle.
Hope this helps. GOOD LUCK!
Oct 16, 2009 | Konica Minolta Magicolor 4690MF...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
145 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
