Question about Coffee Makers & Espresso Machines
Gevalia coffee won't brew
Gevalia machine wont brew
  • 4 Answers
SOURCE: gevalia carafe replacement
ocelnikm, Do you want to sell your carafe? j[dot]w[dot]haas[at]juno[dot].com
Posted on May 29, 2009
  • 85 Answers
SOURCE: cuisinart Coffee on Demand?12-Cup Programmable Coffee
Hello crystalmeikl,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, crystalm. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 11, 2009
  • 13 Answers
SOURCE: The "Brew Pause" feature doesn't work
It's the spring part on the bottom of that black basket. Now that it's broken there's really no fixing it. The only thing to do is call the manufacturer (800-726-0190) to get a new brew basket. They are open on weekends, so you could call them today and see what they can do (brew baskets are covered under the 3 year warranty, btw). Just have your model and serial number and you can probably have a new one ordered in less than 5 minutes. :)
Posted on Aug 29, 2009
Testimonial: "Very helpful suggestion to call the manufacturer. I was told to try the self-cleaning, as calcium deposits could be the problem. worked like a charm."
kel1guy2002
  • 3740 Answers
SOURCE: Our office has a Gevalia Deluxe coffeemaker. It
Most likely the cycle thermostat that turns off the heating element has failed. It is supposed to reset after the it senses the water temp below 130 deg. If it did not reset or has failed it will not turn on the heating element but the clock will work fine.
By the time you ship the unit to a repair center with parts and labor and get it returned to you the cost would be as much as a new unit.
Thanks for using FixYa.
Kelly
Posted on May 13, 2010
Testimonial: "Thank you."
SOURCE: xcc-12 gevalia coffee pot wont brew.
Thermal link open. Located in base of unit mounted against the warming pad heating unit.
Posted on May 31, 2010
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
I have a Gevalia Kaffe 12 Cup Automatic Coffee Maker (Stainless Steel) Model CM-500B (Black). Date Code: S1710. (Global Marketing Corp. warrants the coffee maker, thru Gevalia) It worked perfectly for...
Hello, point
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sep 19, 2011 | Gevalia CM-500 12 Cup Coffee Maker
Why does Gevalia coffee maker leak from bottom?
Because the Gevalia coffee makers are often offered as a free or reduced price premium for purchasing Gevalia coffees they are not well made and can sometimes have a difficult to repair molding error in the reservoir. I have had very good luck with the Hamilton Beach Brew Station. It is affordable, well made, easy to keep clean and nearly foolproof.
Aug 20, 2010 | Wega Mininova EPU Espresso Machine
Xcc-12 gevalia coffee pot wont brew.
Oct 28, 2009 | Gevalia CM-500 12 Cup Coffee Maker
Gevalia xcc-12
clean with limeout, or coffee maker cleaner, I used about 1/2 cup liquid limeout 2 cups water, run through bout 2 times, be sure to run several pots water through after cleaning,
Apr 25, 2009 | Gevalia 50041 / 50443 Coffee Maker
Gevalia #XCC-12 Program Mode
Representatives from Gevalia contacted me and determined the product should be replaced with no cost to me. I expect a new coffeemake within the next week or so. Fantastic customer service - not very common any more.
Jan 11, 2009 | Gevalia 35411 / 50433 Coffee Maker
Operating instructions
I have this manual (CM500) and can scan/email it to you if you send me your email address...also I am looking for a replacement lid for my carafe for this machine if anyone is looking to get rid of theirs!
Mar 29, 2008 | Gevalia CM-500 12 Cup Coffee Maker
My coffeepot the Gevalia model above will not brew this mornign
There's a little Thermocouple that can burn out on coffee makers, it's usually mounted by the warming plate. It's about an inch long and looks like a tiny bullet. It's a safety device and should be replaced, not jumped out. Radio shack may have them.
Geno
Jan 23, 2008 | Gevalia 25280 / 50304 / 60130 / 50431...
Gevalia for two coffee maker 85188
Here is the website for all the Gevalia Product Manuals.
http://www.gevalia.com/Gevalia/customerservice/product_manuals.aspx
Good Luck
Aug 24, 2007 | Gevalia Coffee for Two 85188 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
