Question about Samsonite Luggage & Travel
How to change lock code in TSA002? - Samsonite Luggage & Travel
2 Suggested Answers
  • 685 Answers
SOURCE: TSA002: How to change the
Try asking your questions again in the proper category since the expertise in this area is tripods and cameras, not luggage. If you ended up in tripods after starting in luggage, contact the FixYa staff to correct the problem. The other categories experts will be much better at answering your specific problem than the photo guys.
Posted on Sep 23, 2010
How can I open my TSA002 lock witch I fogot the cod.
Presumably it is a three digit code, so all you have to do is start at 000 and progress steadily towards 999. if you make twenty attempts per minute, it should take less than an hour. Unless, of course, the witch can do it by magic.
Jul 15, 2014 | Samsonite Tripod
Tsa002 change combination
Most combination luggage locks can be reset when they are open. The combination wheels can't be turned unless the lock is being reset. So either the wheels show the correct combination, or you will be able to turn them to a new combination. The lock that is "locked outside the hole" was either not relocked after inspection or it's in reset mode.
Jul 04, 2014 | Locks & Locksmithing
TSA002 - E110 Key
Ask the manufacturer.
May 09, 2014 | Luggage & Travel
How do I unlock a Master TSA002. I do not know the combination and I don't know what tools I need. I have important court papers in the safe and the spouse won't give me the combination. I know the...
Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Step 2 Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Step 3 Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Dec 18, 2017 | Master Lock 5400d: Portable Select Access...
TSA002: How to change the code? I still have the original code which is fairly simple. We want to change this now but unfortunately don't keep the booklet. TSA002: Is it possible to get a key - just...
Sep 23, 2010 | Samsonite Tripod
I have a TSA002 lock which came with the luggage bag and having set the code accidentally, I've not been able to decode it. How can the problem be solved? I know there's a keyhole and a TSA 002 key will...
http://www.youtube.com/watch?v=OfchUwkEckI&feature=related
This link actually shows a man picking a TSA002 lock with a pair of standard tweazers. You can give that a try??
Sep 05, 2010 | Samsonite Tripod
Get the numbers master dial combination lock
Buy the identical lock if possiable and return as defective and they will reset. Otherwise odds or 1 in 999,000 differant combos. This is airport baggage security lock.
Please rate. Thanks
Feb 21, 2009 | Hardware & Accessories
I want to change my Master Lock combination
open the shackle twist 180 degrees...shut it as if u were closing it into the locking device..hold it down, put in what ur new combination is..pull the shackle up and shut it into locking device, and test it out.
Jan 25, 2009 | Master Lock 5400d: Portable Select Access...
Forgot my 3 digit number lock on my samsonite bag
lost 3 digit no on samsonite TSA002 lock
Sep 17, 2008 | Samsonite Tripod
Luggage & Travel Logo
56 people viewed this question
Top Samsonite Luggage & Travel Experts
ray gallant
Tom Chichester
Are you a Samsonite Luggage and Travel Expert? Answer questions, earn points and help others
