Question about Husqvarna Garden
How to fix wheels stuck husqvarna mower 2042
Wheels are locked up after outdoor storage, starter is gone so engine not running
SOURCE: husqvarna ct 135 mower,when attempting to engage
Hi Janet,
its the warning button on the grass collector. If the button is not pressed in fully, the machine thinks that the grass collector is off, and therefore stops the engine. I had the same problem. If you take the grass collector off, you will see the button on the top left side of the back of the mower. It is covered by a strip of black plastic that slots over it.
To fix the problem my first solution was to tape a washer onto the plastic strip, thereby ensuring that the button is pressed fully in when the grass collector is on. When I got tired of the washer continually falling out, I used a screw to jam the button in. You should be aware though, that with the second method you will be able to engage the cutters with the grass box removed. Potentially a small child (with long arms) could put his/her arm down the shute and chop fingers off etc. I have no kids, and thereby feel safe.
Posted on Jul 16, 2009
mickey813
  • 472 Answers
SOURCE: Husqvarna gth 2448t 48'' 24 hp riding mower 2007
YA IT SOUNDS LIKE YOUR SEAT SWICH IS BAD THATS THE MOST COMON THING I SEE A LOT OF LET ME KNOW IF THIS HELPS YOU
Posted on Oct 08, 2009
mickey813
  • 472 Answers
SOURCE: The rear wheels have locked up on my Husqvarna
SOUNDS LIKE THE REAR END LOCKED UP I HAVE SOME USED ONES IF YOU TELL ME WHAT THE MODEL NUMBERS ARE FROME UNDER THE SEAT I NEED ALL THE NUMBERS AND LETTERS AND ILL FIND YA ONE
Posted on Jan 06, 2010
mickey813
  • 472 Answers
SOURCE: Husqvarna LR130 burnt out starter
it has one but the way to fix it is to adjust the exahust valve thay should know that thats is how to fix that now the reason you cant find any thing on this is becous tecumseh is out of buisness thay have been out since 2008 i hope this helps you if not call me and ill help ya 918-7281822
Posted on Mar 08, 2010
Testimonial: "Thanks for the help. I'll check the exhaust clearance."
  • 188 Answers
SOURCE: I have a husqvarna riding
Could be something jamming a blade or belt. With the engine OFF and the key OUT make sure the blades and belts all move freely by hand. Clear out all grass and c**p from the blade and belt areas. You may have to remove the blade deck to do this - instructions are in your manual or download a manual from the Husqvarna website. Good Luck!
Posted on Sep 10, 2010
My huskee Lt 4200 riding lawn mower was running and just quit, now it won't start the starter engages but won't turn over.
try to turn the engine over by hand on top of the motor. if it is stuck it sounds like the engine may have locked up. make sure the starter is'nt stuck on the flywheel.
May 25, 2016 | Garden
Help! Husqvarna YTH2348 Riding Mower. Wont start, just clicks. Changed battery, solonoid, starter, and 20 amp fuse. What else should I try?
make sure the key is off and see if you can rotate the engine by hand some to make sure the engine is not locked..
It's the only thing left to try,
Jun 02, 2015 | Husqvarna Garden
Husqvarna power belt loose how to tighten
Parts and Diagrams for Husqvarna 2042 LS 96043006200 2008 11 This link will provide diagrams of the drive belt and associated parts. The diagram shows the idler pulleys and tension springs. Inspect your mower to compare all drive parts to the diagram. Hope this helps....
Mar 23, 2014 | Husqvarna Garden
Front wheel on weedeater tractor turns sideways cant steer tractor
It looks like your rack and pinion has shifted, you may have to disassemble and and return the pinion to the middle.
Oct 27, 2013 | Husqvarna Outdoor Weedeater Lrv875 Rear...
The back wheels want go cause somethings locked how do i fix that?
the hydrostatic transmission has failed. about 1200 for a new one and the mower is only worth 250 running. sell the mower AS IS on eBay and buy a new one.
Mar 17, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Husqvarna Z6127 won't start after running 30 minutes.
If the starter motor is spinning, the problem is probably the starter motor solenoid. It is basicly an electric piston mounted on the starter that engages the starter motor pinion gear to the flywheel.
Jul 31, 2009 | Husqvarna Zero Turn Mower Z5426
Garden Logo
21 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
