We have a portable floor model Matag air conditioner and the drain water light is on and the air conditioner won't function. How do you drain the water from it? I can't find a tank to remove and empty.
  • margie939 Jun 23, 2009
    Thanks so much, without a manual we were dumbfounded. Our old one had a removeable tank and that was what we were looking for. Your prompt reply is much appreciated. Margie Carter
  • 854 Answers
Hope this helps
Posted on Jun 23, 2009
I dont know where the reservoir is in my air conditioner, is there a hose to hook up to drain the water becuase now it is leaking on my floor
On the Air-To Air Model, the majority of the moisture is supposed to exhausted out the exhaust hose and out the window. However, if it is extremely humid, the water collection tank will capture what is not exhausted. There is no hose, To drain it, there is a removable drain plug on the back of the unit, down near the floor level. You can either drain it in a low sided pan, that is capable of holding at least 1 quart of water. Or you can disconnect the unit and roll it to a floor drain (if you have one) or out doors to drain the water.
I hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | DeLonghi Air-To-Air Portable Air...
How to drain the air conditioner commerical cool portable
Janie, since you didn't mention what brand and model number portable AC you have, I can only give you general directions.
On most unit's the drain plug is on the rear of the unit just above floor level. Some have a short section of vinyl hose that can be attached to assist in draining the water in to a pan or bowl. Others don't. However, you can use a low sided pan of bowl that will hold at least 1 quart of water and drain directly into it. Be sure the unit is turned OFF and unplugged, before attempting to drain the water. The other option is to disconnect the exhaust hose(s) and roll the unit to a floor drain or outdoors to drain it.
Aug 01, 2011 | Heating & Cooling
Hi, I just purchased this used. It was working fine for one day, but now it won't turn on. Can u help? Haier CPN12XH9 12000 BTU Portable Air
If the water collection tank is full, it will not turn ON. Since you said the unit worked fine for one day and now it won't turn ON, more than likely, that's the problem. After draining the tank, the unit should reset itself and turn ON like it should.
The drain plug is on the rear of the unit, just above floor level. You can either drain it into a low sided pan or bowl that's capable of holding up yo a quart of water. O r roll the unit to a floor drain or outside to drain it. If you choose to drain it into a pan, turn the unit OFF & unplug it, before draining it.
Jul 25, 2011 | Haier CPN12XH9 Portable Air Conditioner
I have a portable air conditioner model LP0711WNR. My issue is when I drain the air conditioner, it only drains about one cup of water. Then, when I turn it back on it and use it, after about an hour it...
The easiest way, is to tilt it over slightly when you drain it. But, be very careful doing this, as the unit has caster wheels and you don't want it to get away from you. If you have a helper, so much the better. Remember to always turn the unit OFF & Unplug it, before draining the water from the tank.
Jul 21, 2011 | LG LP0711WNR Portable Air Conditioner
Kenmore portable air conditioner Model 484.35338 serial no AP0000320252 made in spain code X5RKMFE709/01 quit running after 4hrs run. DRAIN WATER light is on. How is the water drained?
The drain plug is on the rear of the unit, just above floor level. You can either drain it into a low sided pan that can hold a least a quart of water. Or roll it to an area, where you can allow it to just drain. If you drain it in place into a pan, be sure to turn the unit OFF & unplug it, before draining the water.
If you have misplaced your Owner's Manual, you can get one online from Sears Parts Direct.
Hope this helped you and thanks for choosing FixYa.
Jul 21, 2011 | Kenmore Heating & Cooling
My amcor air conditioner is leaking water all over the floor. I drain it and it will only last less then 24 hours till it turns off, leaks all over an needs to be drained. Help!
I figured out the problem. My Amcor portable started leaking after the fill light came on for the first time in years. After doing some research I saw that it uses the water to cool some other part of the system to evaporate out the exhaust. So I took the ******* apart and messed with things. Finally I started pouring water into different trays and noticed it would not drain down from the top tray even when running. So I removed the top part and found the drain hole. Blasted that sum ***** with some compressed air and WAMMO it works again.
-madmanmarz
Jul 06, 2011 | Amcor PLM-14000E Portable Air Conditioner
We have a soleusair portable heat pump air conditioner PH5(S) series. The tank full light is on and won't go off. We have drained the unit and still the light stays on. We are trying to use as a...
Remove the water tank and look or feel up to where the float is at and see if it is stuck in the raised position. This is what is keeping the light on and not letting the compressor start.
Jun 20, 2011 | Soleus Ph5-13r-35d Portable Air...
Maytag model m6p09s2a*b leaks water doesn't
Make sure it's mounted correctly..the back of the unit shopuld be slightly lower than the front or water can leak over the pan in the front.
Oct 10, 2009 | Maytag Portable Air Conditioner M6P09S2B
My air-conditioner is leaking a lot of water onto the floor.
You may jst have a stopped up draon or drain pan. If you can get to thesmall whole that it drain out of. **** it out with a shop vac. If you have one. Russ
Jul 26, 2009 | Pelonis KCD-25YI Air Conditioner
Heating & Cooling Logo
196 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
