Question about Alcatel lucent supporttotal 5010 1yr h/w sup omnicore 5010 80110200
How to factory reset omnicore 5010
I have forgotten the password and cannot login
How to retrieve my password
If you mean by retrieve, find out what it is, that will required you remembering it as there is no retrieval method available. If there were, it would make the password rather useless, don't you think?
You will need to reset the router to factory defaults using the reset button to clear out the forgotten password. Connect your PC directly to the router using an Ethernet cable. Open a browser. Login using the default IP, user id and password for the router. Assign new password, then save and re-login with new password. Then reconfigure router to get things back to normal as all settings were reset during factory reset process.
Jun 04, 2014 | Linksys Computers & Internet
Reset password on asus rt n12 router
The only way to reset a forgotten password is to factory reset the device using the reset button on the rear of the router. You will then need to login using the factory default user id and password. After that you must completely reconfigure the router as all internal setting will be reset to factory default.
Jan 07, 2014 | ASUS Computers & Internet
Netgear wireless router login
The easiest method would be for you to factory reset your router and re-configure it. It's ok in a home setting to write the password on a piece of tape and stick it on the router. To reset, press and hold the button on the back of the router labelled reset. You will need a toothpick, paper clip or pin to press the button.
Dec 14, 2013 | Computers & Internet
Forgotten password reset
BIOS or Login password? If a Login , try a Factory Recovery, if you have a Recovery Partition.
Apr 25, 2013 | Toshiba Satellite Pro L300-EZ1004X...
Laptop has a login password that i dont know and i want to reset to the factory settings
You can try to logon use "administrator" account with no password, sometimes this can help.
An efficient way is to create a Windows password reset USB/CD with Windows Password Breaker to reset the forgotten password to blank.
Feb 08, 2012 | Computers & Internet
What is my password
The default password is
password
If you have changed the password and forgotten, you may reset the router to factory settings by pressing the reset button on the rear of the router for about ten seconds, until the test light blinks.
This resets the router and will allow you to login and make changes using these credentials-
username: admin
password: password
Jan 07, 2011 | NetGear WGR614 Wireless Router
I need to et my user name and logon domain i dont rmember them . i just got my lap top repaired and need to reconnect to my router
Router Login: http://192.168.1.1
Login Name: admin
Login Password: password
>If you've forgotten the Router password, then press the Router Reset button (a small point) located next to the Ethernet port to restore the Router to factory settings.
>Please click on Wireless and click on Security to check the Security key for the Network.
>If the Router is reset to factory settings, then it is required to enable the Wireless feature under Wireless settings and enable the Security key.
Good Luck!!!
Jul 02, 2010 | NetGear WNR2000 Wireless Router
I forgot my user name and logon domain
If you've forgotten the Router password, then press the Router Reset button (a small point) located next to the Ethernet port on the Router to restore the Router to factory settings.
After resetting the Router to factory defaults, use the default name and password.
Login Name: admin
How do i unlock my Belkin N+ B25764
Are you trying to login and change the wireless settings?
If you have forgotten the login password you can RESET the Belkin back to the factory defaults and configure it again.
THEN
Power up the Belkin and press the RESET button for 7 secs.
The default login password is blank.
Dec 11, 2009 | Belkin (F5D7230-4) Router (587009)
Forgot password have reset but still wont let me in.
First reset again your router to factory settings, just in case. Do this by pressing the tiny button at the back of the router with a pencil, this works for most of the routers. Then check the router manual or go to factory website and find out default setting for admin and password. some router works with 'admin'/'admin' or 'admin'/'1234'. check factory website.
hope this helps.
Feb 14, 2008 | D-Link AirPlus DI-524 Wireless Router
Alcatel lucent supporttotal 5010 1yr h/w sup omnicore 5010 80110200 Logo
29 people viewed this question
Top Alcatel Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
