Question about Kenmore Refrigerators
Howdo I expose the refrigerant lines to find a freon leak
    Director Badge:
    Uploaded 100 video answers.
  • Kenmore Master
  • 488 Answers
need to charge with leak dye, charge it back up. next time it leaks out, you will be able to see leak dye at the place where leak is at.
Posted on Oct 10, 2015
How do you charge the maytag refrigerator model # mbr1955br
you call a repair shop and have it done professionally .
Aug 24, 2016 | Maytag Refrigerators
Stuff in freezer is thawing. Outside edge of freezer and center divider between refrigerator and freezer getting very hot to the touch. This comes and goes.
this refrigerator had slow leak. last time 6 month ago, another tech from our company was there and charged refrigerator with freon and leak dye. now i found leak dye with special light in the drain pan, spayed with soap - bubbles come out. Replaced that drain high side line. Hope that helps.
Feb 09, 2015 | Refrigerators
I have a Mini Split Airconditioning Unit and I found a leak at the flaring where my Suction Line comes the Condenser. How can I fix the flare. Must I isolate freon first somewhere in the system so as to be...
There is seldom a means by which the refrigerant can be isolated in this type of system. Moveover, since the system has had a leak, the refrigerant in the system is no longer usable. It is made of HFC-125, HFC-32 and HFC-134a in specific proportions. When a leak occurs, these components will leak at separate rates and the remaining refrigerant (if any is left) is no longer capable of doing the work of a virgin refrigerant.
Refrigeration flare fittings are 45° and are made with special tools. While there are 'washers' that can be inserted into the fitting when it's exposed, they are not that effective all the time. Remember that the pressure at the condenser part of the system can well exceed 300 psig.
The refrigerant, Genetron 407C, is the replacement for HFC-22. It has no 'replacement' per se.
It's my opinion that this is an issue for a reputable HVAC technician, and not a homeowner. To do the job properly, you would need a new filter/drier, flaring tool and torch if the line is not long enough for it to be re-flared and reconnected, vacuum pump and virgin refrigerant. I would bet that the location of the leak is such that the system is all but flat at this time, and you need a precisely measured amount of refrigerant to re-charge the system.
If you've not yet done so, TURN THE SYSTEM OFF to protect the compressor from damage.
Jun 28, 2011 | Heating & Cooling
Fridge and freezer both stopped working.Lights still on.
check lines for leaks, check all components. If the compressors kicks on then check lines if the compressor doesn't then that's a potential problem as well. If everything; lines, compressor and expansion canister are looking good then your out of freon, it is the gas that is used to transfer heat from the compartments to outside. Having no freon further tells you that you have a leak, since freon is expensive depending on how much your appliance requires, its best to check everything first before you start removing parts from the appliance
Jun 01, 2011 | Frigidaire 20.6 cu. ft. Top Freezer...
Can freon be added to an under the counter unit?
Freon can be added to any unit, but you e going to have to take the unit out to exposed the back where the component are located. Why do you think that you need freon. Unless the line was punctured. it unlikely that you would need to add freon, Is it not getting/keeping cold. Problem might lie elsewhere like in the thermostat. Hope this helps.
Feb 09, 2011 | U-Line 15R Compact Refrigerator
Air condtioner has a bad smell causing headache
Whether as a gaseous or liquid coolant, Freon aids in refrigeration, air conditioning and maintaining aerosol contents under pressure. Not only can this toxic chemical expose the earth to excessive ultraviolet rays, but the substance can also sicken those who inhale it in an enclosed atmosphere.
Detecting the signs and symptoms of a Freon leak will protect lives, ground water and air quality.
Cardiac arrhythmia can signify the presence of leaking Freon. A person without a history of irregular heartbeats might suddenly detect heart palpitations and faulty blood circulation upon exposure to a Freon leak. The blood circulation problems may also lead to numbness in the limbs.
General Illness
  • A Freon leak can cause nausea, headaches, bouts of regurgitation and general disorientation. Confused thinking and trouble walking or coordinating movements also may result. Severity of illness depends on the amount of Freon released and the length of time exposed. A fire department can provide solutions and guidance for anyone detecting a Freon leak and suffering from its effects.
  • Jan 15, 2011 | 2002 Toyota Avalon
    6 Year old GE side by side - freon line corroded and leaked
    I am a tech that has worked on many ge ref's and have never seen GE do anthing outside of the units warranty. this is a common problem on ge units
    Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    SMALL OUTDOOR BEER REFRIGERATOR DOOR LEFT OPEN OVERNIGHT IT STARTED DEFROSOTNG AND THEN ACTED LIKE IT BULIT UP PRESSURE AND BLEW OUT AIR OR REFRIGERANT AND DOES NOT COOL ANYMORE
    Hi, absolutely there's refrigerant (freon) leak check your condenser and evap. for rupture (broken lines) also check for oil, presence of oil means, refrigerant (freon) leak, plug ref, and listen, for hissing sound inside and outside of ref. try to locate leak, or call mechanic, repair leak, change filter drier and recharge, if your evap punctured, you should immediately disconnect ref, and dry all water from evap, prevent water from entering system, could damage compressor, or if water get into compressor, you will have to change compressor oil. yes, you surely have a refrigerant (freon) leak.good luck.
    Aug 12, 2009 | Refrigerators
    I just had freon put in my car about a month ago now its blowing out heat what is the problem i have a 2002 ford taurau. please help i cant deal with the heat
    There can be only 2 reasons for it to do that either your A/C lines have a small leak in them and all of the freon has escaped or your A/C compresser has gone out if you can still here a click every once in a while when the a/c is on then the compressor is still good. But here is the thing if there is no freon in the lines your compressor wont come on either.
    Jun 09, 2009 | 1994 Volvo 850
    Fridge exposed to cold temps.
    No there is no reset button. It could be the internal fan has gone bad or the compressor is shot. Unless you have bumped any lines and caused a freon leak.
    Jan 22, 2009 | Kenmore 64522 Top Freezer Refrigerator
    Refrigerators Logo
    56 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal DeAngelo
    dweatherby
    paulcarew
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
