Abbreveation of management - Computers & Internet
What is the abreviation of epvp ?
EPVP has several Abbrevations choose one from the following according to your situation
  1. Estrada Parque Vicente Pires
  2. External Programming Vice President
  3. Educational and Programming Vice President
  4. Entry Point Variance Percentage
  5. Electro Pneumatic Valve Positioner
  6. East Preston Village Preschool
  7. Environmental Performance Verification Process
Mar 03, 2011 | Computers & Internet
What do mean the abbrevations a/con sw, htd mirr, amp , drl, p/wdw ***
second hand dealer jargon for the extras on the vehicle
Dec 02, 2010 | 1998 Chevrolet Blazer
Lba
> LBA
Either your keyboard is malfunctioning, or you have used the abbrevation for 'Logical Block Addressing' -- a scheme to access disk-drives that either have more than 1024 cylinders or 64 heads or 256 sectors, i.e., any disk larger than 8GB.
Oct 23, 2010 | Computers & Internet
Power windows won't work? Fuse? where ? Which one? 2002 toyota s corolla. what's the abbrevation??
Look in the engine compartment on the driverside there is a fuse box and a relay box. the fuses are labeled.
Apr 03, 2010 | 2001 Toyota Corolla
Brake lights
ECU is your computer so don't touch that. It might be that you have to pull each one out one at a time to check. Slow way but it works.
Apr 04, 2009 | 2006 Hyundai Elantra
1998 saturn sl2 1.9 dohc
TRS LP
TRS 3/4
TRS 2/TCC
These are the fuses for the solenoids in the valve body Inside the Transmission, they turn on & off as needed to shift.
Check all of those fuses, making sure they are not corroded or tarnished.
Make sure that your charging system is functioning properly.
Please Rate My Response! Thanks!
Feb 02, 2009 | 1998 Saturn SL
Dimmer lights won't come on. what is the abbreveation on the fuse panel for it?
You might have bad headlight bulbs or most likely high/ low switch on the steering column.
Dec 15, 2008 | 2003 Oldsmobile Alero
Computers & Internet Logo
10 people viewed this question
David Payne
David Payne
