Question about Garden
Stihl FS45 2 cycle string trimmer. Bought in 5/06 Cutting head came off while cutting. Flexible shaft still has squared off end so it doesn't seem to be broken. What holds the cutting head shaft with the threaded end to the flexible shaft?
Dealer says shaft has broken. Stihl had a problem with some FS45's doing this. They are trying to have it repaired under warranty.
Thanks for the response.
Posted on Jun 24, 2009
How do I remove the drive shaft in a stihl pole trimmer HT101
take the cutting head off --loosen the housing at the base
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
Sep 26, 2014 | Stihl Garden
Why doesn't the cutting head on Stihl F38 trimmer spin?
Maybe the cutter head has come loose from the shaft. make sure the head is engaged to the drive tube properly
Jul 09, 2014 | Stihl Garden
Managemylife com sears
The shaft that is inside the tube that runs from the motor to the rotating head can be damaged and no longer seat properly. The shaft is flexible and is about 20 individually would worse and pinched to a aware shape at both ends. The ends can unravel and create your issue. If the case it is not worthy of repair.
May 19, 2014 | Garden
Ht 131 shaft keeps slipping out of cutting head
make sure the gear hed is engaged on both the outer shaft and drive shaft at both engine and cutting head end. Check the square drive section that is in the plactic moulding hasnt been pushed too far into the shaft meaning its not engaging properly.
Apr 15, 2014 | Stihl Garden
Stihl fs 55r head won't turn
Check drive shaft. Some models have a flexible cable drive shaft that is prone to breaking. also make sure the drive shaft is engaged in the clutch drum and in the gear head end.
Mar 25, 2013 | Stihl Garden
Troy Bilt TB575EC cutting head hard to load, now doesn't spin.
Remove the cutting head spool and see if you have old grass stuck around the shaft area that could be causing to cease your shaft..
Mar 03, 2018 | Troy-Bilt 4 Cycle Straight Shaft String...
Ref: Stihl FS46 string trimmer. Broken Flex shaft.
Remove orange sheild,remove single screw holding head in shaft then grab head with pliers and twist side to side until complete head is free.You should then be able to grab part of shaft.On power head loosen screws {about one turn each} that hold two white case halves near trigger,I think there are four,then there is a single torx screw on the bottom of lower case half in the middle that must be taken out to allow tube to be removed.Romove flexshaft from top.Check 4 plastic burnt to flexshaft,if there is you must replace tube liner as well,usally around bent part of tube the liner will go bad.
Nov 27, 2009 | Garden
Stihl fs 45 trouble getting the cutting head to engage
repair shop shortened shaft just a touch to take up slack in drive cable
Aug 02, 2009 | Garden
Homelite strin trimmer head wont rotate
The only way to access the bottom of the metal shaft is to break it. This is fused on at the factory. It sounds like your flexshaft has twisted in two. Remove the flex shaft from the engine end and see if it is in one whole piece or is damaged in someway. If it rotates at the top but doesn't rotate at the string head this is probably the problem. However, Homelite no longer offers just the flex shaft for purchase. You would probably have to purchase the shaft and the tube as a unit.
But if you are saying the spool and string is not turning at the bottom it could be that the cup which holds the string has worn and can not longer be turned by the shaft. Replace the cup that holds the string.
Another possibility is that the shaft have moved forward, away from the engine and just need to be jammed back in, and retightened (the handle grip and the boom clamp).
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Cannot disassemble Troy-bilt trimmer head
There is a round, rotary black part between the metal piece to which the cutting head attaches and the outer plastic seat of the cutting head. There are two square slots, each about a quarter inch wide, on opposites sides of the black piece. Slide an Allen wrench or something similar firmly into the slot. Holding the Allen wrench in a stable position, turn the outer plastic ring of the cutting head (it has scalloped edges that can be gripped firmly) counter clockwise to unscrew the cutting head from the bolt on which it is mounted. Be careful with the tool (e.g. Allen wrench) used to hold the black piece steady, as it is plastic and could be damaged by the edge of the tool.
Jun 07, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Garden Logo
1,313 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
