Question about Husqvarna 160 CC Honda OHC Engine 21 in
Why will my blades not turn
Everything else is working but i cannot get the blades to turn on 160cc honda push mower they will not engage
  • 10865 Answers
SOURCE: Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Posted on Sep 14, 2009
jyackle5
  • 8197 Answers
SOURCE: I have a Honda push mower with a twin blade. I
The more slinder blade goes on second. I just looked at mine and it was second or closest to the ground when on all 4 wheels.
Good Luck
Posted on May 02, 2010
  • 100 Answers
SOURCE: My Honda 160cc lawn mower
Has probably broken flywheel key ..... putting it out of time
Posted on Aug 14, 2010
SOURCE: lawn mower husqvarna problem
I have an XT721F self-propelled, auto choke Husqvarna mower. The first time I used it this season it ran for a short time and then just quit on me. I have since emptied out all of the gas and have replaced it with high octane 91, and have also added Seafoam to clean out any other issues. I mowed two weeks ago with no problems and went to mow again today and only made it through 2/3 of my back yard and the mower stalled out on me again. What's going on?
Posted on Jun 28, 2011
  • 14 Answers
SOURCE: blades wont ingage
I would check the belt, the pulleys and the tension of the pulleys. Any of these could be the cause of your issue. Hope this helps!
Posted on Jun 14, 2012
Selfpropelled portion stopped working, replaced broken belt,have correct p/n for new belt,belt is slack ,self propelled not working
There should be 3 pulleys one on the motor on top of the blade, one on the axle for the wheels and one that goes to your cable to engage that pully and tighten the belt, take the cover off that hides the axle and pull your handle for the self propell and see if its tighting, some mowers have a little adjuster to tighten the cable on the self propell handle or even on the cable itself, did you make sure to run the belt between the guides over the blade, let me know what you find so we can further help
May 15, 2016 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Tractor shuts off when clutch is engaged craftman 22 hp 50" mower
I had the same problem. My problem was something was preventing the blades from spinning, so the 1st thing you can do is check to make sure your blades turn, and test this while the mower is off.
While it is a pain, you can also take the deck out and check to see if this help and you are able to freely turn the blades. If everything is working properly, you should be able to turn the blades by hand.
In my case, I has a stick jammed into the belts and pulley, so when I would engage the blade, it would cause my mower to stall when it tried to engage the belt.
Hope this helps.
Dave
May 29, 2014 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Scotts L2048 lawn tractor deck wont engage
You need to check the wires from the clutch, with the ignition on pull the pto switch out there should be a 12 volt supply at the wires if not replace the pto switch, if you have 12 volts then it is the clutch itself, they are not realy repairable, so may need a replacment.
Jul 16, 2013 | Garden
Lawn mower idles low
Find a screw touching the linkage on the carb. Turn that screw to speed up the idle.
May 29, 2013 | Husqvarna 7021P 21-Inch 160cc Honda GCV160...
Just bought this mower honda hush arena 21 " push mower and it throws clippings all over the deck, why? Looks like its coming from the side outlet
See if the side outlet needs a plug underneath to keep the grass inside the deck to be mulched. A lot of mowers have these plugs but this one might have not been installed.
Jan 19, 2013 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
I have a 2006 Cub Cadet Push mower with a 5.5 160cc Honda Engine. I have never had any problems till last week. The engine started racing while mowing. I stoped the engine and checked the oil and air...
Replace engine, only 1 yr. warrenty. Engine about $119 at Harbor Freight. Easy to change out. all Harbor Freight engines are Hondas. Bolt pattern same. 160cc or 190cc will work. Remove blade, remove mounting screws, replace engine. Carb may be the same for throttle connections. Reinstall blade. 10 pulls required to start engine 1st time. 1 pull after that. Pull 1/2 way 4 times 1st to prime even if you use the primer bulb. Ensure oil is full, 30w oil. Excellent engines good for 7-8 yrs with proper maintenance. Observe cable connections before old engine removal. Take pics.
Sep 14, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Honda harmony 215 sx blades will not engage
Tighten blade nut. Shaft maybe bad, bad motor.
May 06, 2012 | Honda Garden
Blade won't stay engauged
It is very hard to say without knowing model, but if it is a Honda Harmony than I would look towards the the cable that controls the blade engagement. If your model is equipped with a blade engagement lever most likely yours is controlled by a cable also and it only needs to be adjusted correctly. Good luck!
Oct 18, 2009 | Garden
My blades wont engage and just hear click sound?
No permanent solution, but you probably can get by once by "riding" the clutch engagement lever - pushing it only part way forward and holding onto it.
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Husqvarna 160 CC Honda OHC Engine 21 in Logo
16 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
