Question about Jacuzzi Whirlpool Bathtub Computerized Massage Jets Built-in Heater SPA Hot Tub FM MP3 CD Model 657WH White
Why does my hot tub flash 616 on control panel
Flashes 616
2 Suggested Answers
  • 80 Answers
SOURCE: "Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
There are two things you can check, there is a tranformer that plugs into the main circuit board(usually a four wire plug). Unplug and check pins for good connection and then reconnect There are usually one or two fuses inside the control box mounted on or near the circuit board. Turn off power to spa and pull fuses and check continunity. This is a good start.
Posted on Aug 19, 2009
When the pump goes into high speed, it draws too much power(dims the lights) but maintains the lower speed. When the pump button is held down to shut off the system, the readout says off but the pump...
most tubs this size are fead with 240 volts power , im betting yours is . the symptom you describe is a condition that would occur if only 120 volts (half power) were reaching the tubs controller
id have a pro pool tech confirm this as water and power are dangerous to mess with if your not 150% sure in how it works
Sep 04, 2013 | Belize Spas Belize Oval II Hot Tub Spa -...
I have a Breammaker X-Spa_dition. The tub appears to be working (The jets run) and it appears to be heating (it is currently 99 degress where I live, so no way to tell as the tub is just boiling in the...
I just started my up for the season, and the same thing happened. I removed the side panel and on the control box attached to it are a wiring plug and wiring jack similar to a phone jack plug. If you unplug these and clean them with some alcohol, it fixes the problem. Sometimes dust and small debris gets in there and interferes with the connection. It's a good idea to do this once a year. Hope this helps!
Jun 09, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
What does the code LF stand for? It keeps stopping half way through the wash cycle and flashes this code.
LF is for long fill.
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Check the following:
? Is water supply connected and turned on?
? Are hose screens plugged?
? Is water entering the tub?
If all these are good and water is going in fast (both hot and cold) you may need a service company to come out and take a look
Apr 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error codes flashing
Hi, This is mainly due to control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually..
Apr 13, 2010 | Frigidaire PLD4375RFC Dishwasher
Dream Maker Hot tub - Display is blank - no #'s - flashes 4 times
Hard to say without being there. Two things to check though. First be sure the new board is the correct one. Many times parts will change and replacements will have special instructions for retrofitting.
The other thing to check is be very sure the plug on the new board lines up with the receptor. On a multi pin plug if the pins don't line up you can get just the problem you describe. I hope this helps, sorry it can't be more.
Feb 28, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Kenmore model 417-44052400 front load washer error code E04 (5 vertical LED flashes & beeps and 4 start led flashes. I ran the diagnostic test, it dose everything up to tumble, it won't tumble or...
Take the front lower panel off 2 or 3 screws you will see the pump.You will see a black "baffle" atatched to the pump.squeeze it feel a sock?Take the boot loose and clear.Only other thing would be the motor control board back let hand corner replaced many of these when tubs dont move.I hope this helped.
Nov 17, 2009 | Crock Pots & Slow Cookers
Jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Sep 24, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Jacuzzi Whirlpool Bathtub Computerized Massage Jets Built-in Heater SPA Hot Tub FM MP3 CD Model 657WH White Logo
Top Jacuzzi Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Jacuzzi Audio Player and Recorder Expert? Answer questions, earn points and help others
