Question about Dell Vostro 1015 Laptop
My touchpad is not working at all
The cursor does not move when I try to move it. I have turned the lap top off unplugged it and turned it back on and it is still not working
    New Friend:
I think it is driver failure so you can reinistall the driver.to inistall use usb mouse or bluetooth mouse? i think it help you
Posted on Oct 16, 2014
  • 40 Answers
SOURCE: touchpad right and left clickers womt work
this is due to the driver missing or uninstalation of the touchpad you must try to reinstall the driver again.
for any harware problem you can check the status in
DEVICE MANAGER present in CONTROL PANNEL(WINDOWS VISTA)
for
WINDOWS XP you can search this application in windows search.
Posted on Apr 21, 2009
  • 72 Answers
SOURCE: Back arrow not working and cursor jumping around
you laptop is going through a keyboard failure.
Posted on Jun 16, 2009
  • 10406 Answers
SOURCE: i cant move my cursor
Connect a USB mouse.
Then, in Control Panel, access the 'Mouse' panel, and "enable" the touchpad.
Posted on Nov 26, 2010
drifterK
  • 4924 Answers
SOURCE: My laptop boots up but no interaction with the cursor, the yellow light near the touchpad is lit
First get to the dell support site and download the driver for the touch pad..and run it again in the laptop ..If this will not fix the issue you have to consider reinstalling the computer cause you may have a bug or something affecting it ..or open it up and check the ribbon of the pad and see if it has no damages...If you find a spare part you may change it ..if you suspect it has issues..but this is not a frequent issue and most likely it is from the driver..Either was not installed after a complete re-installation of the Operation system ..or something interfered and corrupted its functions .
Here is the link for your model ..where you can look for drivers..(select your operation system )
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&SystemID=INS_PNT_P4_5100&os=WW1&osl=en&servicetag=&catid=-1&impid=-1&deviceid=283&libid=17&typeid=-1&dateid=-1&formatid=-1&source=-1&releaseid=R81989&formatcnt=1&vercnt=6
just select the OS you use ..and under the mouse and keyboards..you will find 2 drivers for your touch pad...Download the most recent one..and run it ...into the notebook ..restart and see if it works or not ..Good luck and please rate the answer if it helps ..
Posted on Nov 18, 2011
atang1
  • 734 Answers
SOURCE: Dell Inspiron N5040 touchpad not working while charging
If battery works and ac adapter has problems that means electrolytic capacitors maybe dried up(not supplying the current needed to run the laptop) and has to be cured by using the laptop more often.
Posted on Apr 14, 2012
How do I fix my frozen mouse pad
Try pressing the Fn key (lower left ) and F7, this enables & disables the touchpad.
Jul 10, 2014 | Acer TravelMate Computers & Internet
Asus netbook cursor stuck
Make sure there is not a lock on the top middle of the touchpad that you can press to toggle the lock/unlock. if so, press it. Otherwise I would try booting up in safe mode and see if the cursor locks.
Mar 29, 2012 | Computers & Internet
My mouse has stoped workin i just turned the lap top of and turned it back on again and it wansnt working the click button does'nt work either.
If you are referring to an actual "regular" mouse, unplug it from the USB and try plugging back in again.
If you are referring to the "TouchPad" type on a laptop, usually there is a tiny button near the touchpad that you may have inadvertently shut off by hitting it. Mine is right at the top part toward the screen, but still part of the touchpad. If you can't find the little button then refer to your manual if you got one to find out where the off button is for your touchpad and turn it back on.
hope this helps, if not I will check further to see what to do!
Feb 27, 2011 | Computers & Internet
My cursor will not move on my laptop screen
The reason your cursor will not show on screen is because the laptop jammed.
To fix this,
Try to shut down properly,
Then you remove the battery and reinstall it.
Turn it on back and your cursor will come back on.
Take care
Jun 21, 2010 | HP Pavilion dv6000z Notebook
No cursor activity
Dear Sir,
Generally for compaq there is lock for touch pad you can see a moving lock below or above the touch pad. If locked the tochpad button,touch pad not sensitive.So open the lock and now you can move pointer using touch pad. see this pic
http://icerazerstudios.com/wp-content/gallery/random%20images/touchpad.jpg
there is black color button lock appear at the upper border of touchpad.
Jul 30, 2009 | Compaq Presario CQ60-204NR Notebook
Erratic movement of cursor
try to re-install the driver of your touchpad. i suspected it could be the driver issue.
May 11, 2009 | Computers & Internet
Cursor is frozen on the lap top
try using your external mouse to reinstall the touchpad driver. in almost all cases i've seen of this it has fixed the problem.
hope this helps
Jan 16, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Toshiba notebook equium A210 (not listed here) touchpad frozen. cursor not moving? help please?
try re-starting the computer; if that does not work install an external moue and try navigating withthat. If that works it is that the touchpad has been damaged; or the drivers arecorrupt
May 13, 2008 | Toshiba Satellite A135-S4527 Notebook
Dell Vostro 1015 Laptop Logo
37 people viewed this question
Alun Cox
