Question about Dryers
What shoudl I check to determine why my whirlpool WED5840SW0 is not heating?
The dryer turns on and spins, but does not heat.
    Scholar:
  • 177 Answers
Check the thermal fuse the cutout fuse & all thermostats .
Also check the heating element & check to see if it is touching any metal. It also could be the centrifical switch in the motor.
Hope this helps
Posted on Jun 02, 2014
localwonder
  • 6784 Answers
SOURCE: Dryer running but not heating. How do I check heating element?
Check the following to address this non heating issue
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jun 02, 2009
Illeagle
  • 525 Answers
SOURCE: DRUM WILL NOT SPIN BUT DRYER WILL HEAT IT'S A WHIRLPOOL
I have provided a checklist courtesy of; www.repairclinic.com
They also provide repair parts, disassembly diagrams and procedures.
You can also checkout www.homemanagement.services.officelive.com for other appliance help websites.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Posted on Jul 13, 2009
  • 76 Answers
SOURCE: whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Posted on Jul 30, 2009
Controlfrk
  • 304 Answers
SOURCE: My whirlpool dryer heat up. But does not spin.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Check for belt on drum half way back on the drum running from left to right. If belt is missing or broken replace with part number 341241 later in this process.
Looking down inside dryer on left and right see a 5/16" hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Rotate front panel to right to get it out of the way watching to ensure wiring is not damaged.
Place new belt over drum groove side down if old one was broken. Check white idler pulley for free rotation before installing in holes of floor under motor pulley. Replace with part number 691366 if rotation of pulley is not free or if it appears worn. Loop belt with ribs inward and pass through the open space in the idler arm below pulley then pass loop over motor pulley rib side down. The configuration at the motor should now look like the Whirlpool model in the image below:
Belt and pulley configuration
Grasp front edge of dryer drum and rotate counterclockwise slowly to align idler and motor pulley and to remove any twists in the belt.
Reverse disassembly process to re-assemble.
Posted on Sep 07, 2009
jsrock516
  • 5911 Answers
SOURCE: My Whirlpool Imperial Series Dryer is 4 years old. NO Heat.
It may not be the heating element causing your problem. There are other components that can fail that will cause the same symptoms. The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer will exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum. All dryers are not constructed the the same. Regardles of location, the Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace. All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
If you have any questions, please let me know. Please inlcude your complete model number (located on a nameplate around the door opening) when asking questions. I hope you find this information helpful.
Whirlpool wed5840sw0 heats up but won't spin.
If the machine starts with accepting water to the desired level and then not moving forward , it can be related to failure of the motor or the controller unit. check voltage to motor at the wash/spin cycle and if this is absent , the fault is within the processor
Jan 12, 2013 | Washing Machines
No heat while drying
If this is a gas dryer. It's possible that the solenoid gas valve has gone bad. One way to determine this is by do a dry cycle and listen to the gas and flame to start. It shoudl sound like a flame starting on a regular stove top. Once the flame starts you can hear the flame. If the flame stops in less than a minute that is an indication that the gas valves has switched off. You need to have the solenoid valve replaced.
Mar 01, 2011 | Whirlpool Dryers
Whirlpool Craetions Dryer AWZ129: No Heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 15, 2010 | Whirlpool LER5636P Electric Dryer
Dryer won't heat?
Make sure your electrical connections are correct.
Check the voltage to the dryer element and make sure you are getting 220 volts.
Otherwise I am at a loss also...good luck
I hope this helps
Oct 01, 2009 | Whirlpool Dryers
My whirlpool dryer will turn on and it still
It could be the belt or the motor. You should be able to determine which it is with the back off.
Best regards, --W/D--
Jul 31, 2009 | Whirlpool Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Gas Dryer with no heat or timer
Check the following
http://www.youtube.com/watch?v=rQV-z4f7fvA
If you need more assistance don't hesitate , e-mail us back.
Thank you Was this helpful ?
May 13, 2009 | Whirlpool Dryers
Dryer continues to run but heat fuse blows when turned on.
You would need to check the amp draw to determine if it is the dryer or your house circuit. A dryer typically draws a steady 24 amps when it is heating.
Apr 07, 2009 | Whirlpool GEW9250 Electric Dryer
Clothes dryer doesn't spin
The way most domestic clothes dryers are made, it's usually hard to determine that the heating part works without the drum turning.
But, chances are, the drum belt is broken.
Please give the specific model number of your unit for a more complete response.
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryers Logo
23 people viewed this question
Top Dryers Experts
