Question about JVC AV-32WF47 TV
How do I set it to channel 3 or 4 without the remote??
I need to run cable directly to the TV but without the remote I am unable to set the TV to channel 3 or 4
  • 3 Answers
SOURCE: I dont have a remote ! how do i set the TV to the dvd player?
there should be a set of controls on the front of the tv that you can change the channels and settings from there
Posted on Dec 13, 2007
  • 86 Answers
SOURCE: tv/remote input problems
Try plugging your cable box in using a/v cables (red,white,yellow) and see if you have a picture on a different input from the box. If so, go into your general settings in the box and change the output channel to 4 instead of 3. Then try your TV on 4 and see if your picture comes in. I have seen TV tuners go out on just one channel before.
Posted on Feb 24, 2008
budmrtn
  • 11361 Answers
SOURCE: Setting Up AV-3220 Without Remote Control (or manual)
You can download the manual here:
http://tv.manualsonline.com/search.html?q=JVC+AV-32230+&submit.x=20&submit.y=14
Posted on Nov 02, 2009
gopakumarg43
  • 74459 Answers
SOURCE: I accidentally hit the menu button on my tv and
Hello
You have hit the channel skip function to on. Go to menu and come towards functions where you can see channel skip. Keep it to "off" position. Now it is in "on" position.
Posted on Oct 16, 2010
SOURCE: We bought a used AV-32D305. It didn't come with
I HAVE G.HANZ PROJECTION TV. AND THE PICTURE IS NOT CLEAR AND IT HAVE SO MANY COLOURS , IT NEED TUNING. HOW TO ADJUST IT
Posted on Mar 25, 2011
Have a used Emerson tc1375a hooked up to cable only gets channel 3 and 4 picture is great. Does it need to be reset or what can I do
Usually a TV must be set to either channel 3 or 4 to receive a TV service provider such as cable or Direct TV. The service provider now controls your channels and broadcasts on either channel 3 or 4. You choose channels from what ever equipment they gave you which is usually not the remote that came with your set. You may need to check the way you are set up. If you are using an antenna go into the menu on the TV and make sure it is set to antennae not cable. This may also be the problem. Good luck.
Feb 19, 2015 | Emerson Televison & Video
We have followed every letter in the manual but have been unable to program channel 2 on our TV.  This channel is a legitimate channel on our other TV that's connected to a cable box. In the...
I would try two things here---first with the remote for the set direct enter with the numbers on the remote 02 and enter to see if set will go there and second connect a different set to that connection to see if same issue or not.
Dec 02, 2012 | Televison & Video
I can only get channels 600 through 900 which I have never see before.I cannot get regular channels or cable channels.It is not a flat panel t.v.Q1435A is the model number
Hi -
If you have a cable TV line connected directly to the TV, an antenna or a cable box connected by coaxial cable, I would suggest running the automatic channel scan (AUTO-PROGRAM) again:
1. Press the AV key on the Advent remote control repeatedly until TV is displayed in one corner of the TV screen. If you don't have the Advent remote, use the TV/AV button on the front of the TV.
2. Press the MENU key on the advent remote or the front of the TV to open the on-screen menus.
3. Use the CH+/- keys on the remote or on the front of the TV to highlight PRESET then press VOL+ to select.
4. Use the CH+/- keys on the remote or on the front of the TV to highlight ANTENNA then use the VOL+ key to select either AIR (for antenna) or CABLE.
5. Use the CH+/- keys on the remote or on the front of the TV to highlight AUTO-PROGRAM then press the VOL+ key to start the automatic channel scan.
Once the channel scan is complete, the TV should automatically return to viewing the first channel found during the scan. Do not press the MENU key during the scan or the scan will not complete.
If you are using a cable/satellite receiver and it is connected to the TV by any means other than a coaxial cable, you do not need to run the channel scan. You should simply select the correct AV input using the AV key on the remote or the TV/AV key on the front of the TV (see step 1 above).
If you have done all of the above and you are still unable to get the channels on your TV, please post back for further assistance. You can reply to me by clicking on "Add a Comment" below your question. Please let me know whether you are using a direct cable line, antenna or cable box, etc.
Regards,
BElectric
Mar 26, 2011 | Televison & Video
I have a mitsubishi tv model cs27200 and I dont have a remote. I got a universal remote but it wont bring up the menu. I need to program the channels for cable. I only get local channels without bringing...
You would need to look up how to program that remote to your specific tv. I would look up the owners manual if you dont have it for the remote...and follow the instructions for it. However, you will have to directly use the tv to program it to the cable. The universal remote will only change the channels and volume for you. Use your menu button to bring it up, make sure its set to cable and not antenna, and use your channel + and - to navigate through the menu and vol + to select your option
Nov 20, 2010 | Televison & Video
I have a JVC tv model AV 27495. I hooked it to the cable with the cable cord. I can only get cable 2 channel. I can't access any channels. What do I need to hook into the cable? Do I need a box since...
Yes, with the Direct TV box it did all the tuning and your TV had only to be on one channel, normally ch 3 or ch 4. Now that it is not there any more your TV tuner must do the work. You now will have to tell the TV to search for channels. Use your remote and TV menu to do this. You will be able when the search is complete to see some of the cable channels but other premium cable channels you won't be able to see without a cable box.
Sep 12, 2010 | JVC Televison & Video
How do I change the tv channel without a remote? I have cable and need to put the tv on channel 3, but do not see how to do this. We lost the remote
look u cant chane directly to channel 3,,,there is a solution,,jst do it mannually from the buttons available on the t.v
Aug 30, 2010 | Symphonic SC1302 Combo
Sony KV-20S40 stuck on channel fix
I have just got a kv-20s43 and your best bet is to try to restore settings, here, To reset TV to factory settings, turn the TV on, Then, while pressing the reset button on the remote control, press POWER on the TV. The TV will turn itself off, then back on, the original settings wiill be restored... definition: ch. fix- 2-6: Select when you want to control all channel selection through a cable box. Select the appropriate channel(usually 3 or 4) and use the cable box's remote control for channel selection. VIDEO: select from available inputs when you have connected video equipment and you want your TV fixed to it.
Feb 01, 2010 | Sony KV-20S20 20" TV
My daughter brought her tv home from college without the remote. I'm now trying to hook it up to digital cable. It needs to be on channel 3. When I try to manually change the channel to 3 using the...
The easiest will be to make sure that the cable box is on and sending out a signal to Channel 3 and auto-programming the set. Channel 3 is skipped because the last time it was auto-programmed, there was no signal on that channel.
Dan
Jul 10, 2008 | Televison & Video
Magnavox Model # RK 5530 AK02 TV
Can you get to inputs on your tv ? I would use these inputs rather than channel 3 because you'll get a better picture using the inputs rather than the tuner. They are in the back Yellow for video and red and white for audio. But without the remote you can go into the menu to see if you can manuel program your channels but most of these sets you can't do that . www.replacementremotes.com might have your remote should you need one . Good luck
Mar 01, 2008 | Televison & Video
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
JVC AV-32WF47 TV Logo
19 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
