Question about JBL CREATURE II Computer Speakers
Jbl stopped working - ok for 'n' years - lights on but will not play --any ideas-- leads checked solid - Realtech board
3 Suggested Answers
cyberware
  • 196 Answers
SOURCE: sound card compatible with jbl media 2000
Realtek Sound Card is very much compatible with windows 7 ans let me inform you that Realtek is all time including compatibility with jbl media acoustic research based organization and there is no conflict yet with microsoft based platform and softwares What might have happened is either there is infection in system that you may cure by running 3 aplications 1trojan remover,combo fix and malawarebytes ---these are free and safe Next stage is to check the driver compatibility and suggested solution that is a default solution by windows 7 if you dont find any just browse the device manager in control panel and see that your sound card does not have any yellow highlight or red cross on it If you find any download the compatible drivers from the manufacturers website Thanks And Regards Kindly rate this solution
Posted on Feb 23, 2010
jim4984
  • 797 Answers
SOURCE: w4e were given jbl speakers
You should not require an drivers. The speakers should just plug in an work. Note that almost all computer speakers need external power to get an volume out of them. Some may output a whisper without power but most just remain silent. The output of most audio cards in computers are designed to drive mini headphones like an iPod or other MP3 player.
If you are having a problem with the speakers, please explain in detail the problem.
Thanks, Jim
Posted on Jul 04, 2011
I have a goodman furnace with a solid red light. Says normal operation, but ignitor does not light. Unplugged ignitor and still solid light. Could it be the circuit board or something else? Blower
Usually you can visually inspect the igniter, looking for any cracks or breaks in the element. The best way to check it is with a volt meter to see if your getting the 120v to the plug itself, putting your leads in each of the prongs on the plug. If you are not getting the voltage, it's usually the board. Make sure all connections are tight. The heating sequence will be: 1. Inducer motor starts 2. You will hear a click from the board, it telling the igniter to light. It should start to glow. 3. Next click will be the gas valve opening and flames on. 4. Blower motor starts. Hope this helps!
Nov 13, 2012 | Goodman Heating & Cooling
My JBL plays but it cuts the play back frequently like it plays and stops, plays and stops, plays and stops so on .Whats the problem. Please help
Until this is fixed, I would not use it or you may blow up a speaker... Make sure you check that you are using BALANCED audio interconnect cables, either XLR or TRS balanced cables AND that ALL interconnected equipment is poowered by the SAME receptacle... yes you have to run extension cords, but the pro's do it to avoid ground bounce damage to their equipment. Use ONLY three wire power cords.
Aug 06, 2011 | JBL New Jbl Prx512m 12 Powered Monitor...
I have a pair of JBL S412P speakers and the powered subwoofer just stops working and then a month or two later it starts working again and then goes out again. The lights on the bottom don't light when...
The fact that the LED's also go on/off points to a power supply fault.
First check the mains power plug for the power-pack, as if it's supplied by 2-pin 2 amp type, the adapter contacts could be loose.
If not this, or directly into speaker, check DC socket, or a cracked internal board track or dry solder-joint.
Jan 31, 2018 | JBL S412P Main / Stereo Speaker
I have a jbl sub that has worked perfectly for a few years and I havent used it in a few days. When I tried to use it there was no sound but the power light is green...what could it be? I checked the fuse...
Check that the audio source is feeding the sub is wired correctly and that there is no problem with the leads if you still have no joy and you have a multimeter check that the speaker isn't blown allthough it would be very odd if it was it still rules it out. after this you could be looking at any number of problems IE bad joint on the circuit board blown parts the list is endless try the simple sollutions 1st
May 16, 2010 | Audio Players & Recorders
XBOX360 No Audio, No VIdeo, Solid Green Light
the G.P.U has more than likely detached from the main board.
the x clamp mod is more of a diagnostic procedures than an
actual repair function. The G.P.U will need to be re-flowed to
the main board then lightly but firmly clamp to the board
then stress tested (force it to run hot for 15 min shut off and
repeat 3 times)
that's it
Aug 23, 2009 | Microsoft Xbox 360 Console
Buzzing sound coming from my jbl creature speakers no music
Try this Double click on the volume control icon in the system tray.Click on "options"--"Properties".Select Line-in and Mic.Mute them. I hope this solves your problem.
May 14, 2009 | JBL CREATURE II Computer Speakers
JBL CREATURE II Computer Speakers Logo
61 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
